Technical 56 olds rear brakes get hot
Discussion in 'Traditional Hot Rods' started by Grease Junkie, Nov 9, 2024.
  1. Grease Junkie
    Grease Junkie
    I have a 56 olds
  2. 1biggun
    1biggun
    Is there push rod free play on the mastercylinder ?. There should be.
    saltflats, pprather and Grease Junkie like this.
  3. Grease Junkie
    Grease Junkie
    Yes.
    saltflats likes this.
  4. jimmy six
    jimmy six
    A 56 Olds with manual brakes…… a first for me. I did a lot of brakes while working at a Sears Auto center in the early 60’s and never remember see one.
    Grease Junkie likes this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Here in the Very conservative Midwest I recall many cars of that vintage with manual brakes , steering & transmissions
    SS327, jimmy six and Grease Junkie like this.
  6. Grease Junkie
    Grease Junkie
    Mine is all manual. No power brakes no power steering no power windows. Only options it has is automatic and 4 barrel carb.
  7. Mr48chev
    Brake shoes have to have a slight drag on the drums if they are going to work right.
    Adjust them up so that you can't turn the wheel and back them off 11 clicks. That has worked for me for 62 years since I was taught to do it that way in high school auto shop cl***. You may be looking for something wrong when there is nothing wrong.
    You are still going to have the drums get hot if you drive it and use the brakes, that is a given as friction creates heat. They will be too hot to touch but shouldn't too hot.
    The best thing I can suggest is to pull the drums off and take a serious look at the shoes and see if first there are signs of uneven contact. Going back to Johnny Gee's post look real close at the surface of the shoes to see if they have been dragging in one spot rather than having even contact.
    Tow Truck Tom and Grease Junkie like this.
  8. Grease Junkie
    Grease Junkie
    This is what the shoe wear pattern looks like.
    The primary shoe looks like contact st thr ends.
    Secondary shoes looks like full contact.
    Is the arc difference on thr primary enough to make them get hot and hard to adjust correctly?
  9. Grease Junkie
    Grease Junkie
    I have a new master cylinder from kanter installed
  10. Grease Junkie
    Grease Junkie
  11. jaracer
    jaracer
    I'm not sure what you are showing. You need to set the shoes in the drum, holding them against the drum at the middle of the shoe. You should be able to fit a 0.005 to 0.010 feeler blade at each end of the shoes. I never put shoes on a vehicle without checking the shoe to drum fit.
  12. Doublepumper
    Doublepumper
    from WA-OR, USA
    ^ If they're off some, you can use some 80 grit inside the drum to shape them up. If they're off a lot, the paper won't work too well.
  13. Grease Junkie
    Grease Junkie
    Trying to show the wear pattern.
    I'll put them in the drum and feeler Guage them like you said.
  14. Grease Junkie
    Grease Junkie
    The wear pattern on the secondary shoes looks even and the primary looks like it's not touching the drum in the middle.
  15. BJR
    BJR
    Just so we are on the same page, primary shoe is in the front and has the short lining.
  16. tb33anda3rd
    tb33anda3rd
    by the shiny spots it looks like the shoes are barely making contact. I wonder if the, non worn in rear brakes, are trying to do all the stopping. what do the front shoes look like?
  17. Grease Junkie
    Grease Junkie
    100%
  18. Grease Junkie
    Grease Junkie
    I don't have any pictures of the fronts at the moment. I believe they look good? I haven't had any problems with the front. When the brakes are cold it feels good, and I can lock the fronts pretty easy. Everything seems fine. After about 10 miles the rear brakes start to squeak, smell hot and are very hot to the touch. It becomes harder to lock the fronts and i feel the rears doing more stopping than they were cold. Fronts are warmish or cold, never hot.
  19. Grease Junkie
    Grease Junkie
    I'm using chevy c/10 drums and 228 shoes from O'Reilly.
  20. Grease Junkie
    Grease Junkie
  21. Grease Junkie
    Grease Junkie
    Had the front off today. This is what they look like.
  22. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Just sayin' since we haven't 'cooled it' yet.
    Wether attached or not......;)
    Rust inside the parking brake cable hook-up sleeve could give a problem.
