Projects 4BANGER mild HotRod
Discussion in 'Traditional Hot Rods' started by Deutscher, Nov 12, 2024.
  1. Deutscher
    Deutscher
    from Germany
    Hello, I wanted to introduce myself and my 4-banger.
    My name is Harald, Harry is my nickname, and I'm from Braunschweig, Lower Saxony, Germany.
    Now I want to build what I consider a traditional hot rod, keeping its engine and most of its ch***is. It will have a Legacy roof,
    a front axle from the '32, and will be lowered further with the springs.
    I'm also installing a Volvo M40 transmission, but we'll keep the torque tube.
    The engine will be completely overhauled.
    I bought a '31 coupe that was roughly ***embled for shipping to Germany.
    Here's where we start, let's get started.
  2. Deutscher
    Deutscher
    from Germany
    The Bench is ready.
  3. Deutscher
    Deutscher
    from Germany
    This is what it could look like, the photo was taken by some friends racing on the beach in Rømø, Denmark. If your friend is reading this, it's a great car.
    Greetings Harald
  4. 51 mercules
    51 mercules
    Welcome aboard! Have family south of you in Straubing. Looks like a fun project. I like bangers. I have a 29 Roadster with a banger. Keep us updated on your project.
  5. Deutscher
    Deutscher
    from Germany
    Thanks, I will do that.
    Regards Harald
  6. Jeff34
    Jeff34
    Nice car! Congrats!
    chryslerfan55 and winduptoy like this.
  7. The37Kid
    The37Kid
    Welcome to the HAMB! Looks like a nice solid car to start with.
    Bob
    chryslerfan55, winduptoy and Outback like this.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
  9. Outback
    Outback
    from NE Vic, Oz
    Welcome aboard, I've got a rpu with a banger, fun times to be had :cool:
  10. Deutscher
    Deutscher
    from Germany
    [​IMG] [​IMG]
  11. Deutscher
    Deutscher
    from Germany
    Thank you for the nice welcome, it is my first contact with a Model A. Now the roof structure is in progress and for this I have to dismantle the upper roof frame, the front head section and the sun visor were already missing, the roof frame is being rebuilt in box tube, sheet metal strips have to be welded all around the roof cutout, off we go
    Paint was also added again
    Greetings Harald
    LCGarage, catdad49, Dannerr and 18 others like this.
  12. Deutscher
    Deutscher
    from Germany
  13. Deutscher
    Deutscher
    from Germany
    There was still a hole in the quarter panel, I made a patch, I don't have all the fancy machines, so I hammered the outline onto a piece of steel beam. Greetings Harald
    LCGarage, catdad49, Dannerr and 16 others like this.
  14. trikejunkie
    trikejunkie
    from Scotland
    Your car is starting to take shape ,I run a 4 Banger coupe too....................daily driven in Scotland UK I even get waved at from the local police(who probably dont know it should have fenders on it!)Check out The Sacramento Coupe on Youtube. 356360815_748022530666148_3345166135451280075_n.jpg
  15. Deutscher
    Deutscher
    from Germany
    I did, you built some great things,
    I like it, it looks like a lot of fun.
    Greetings Harald
  16. Deutscher
    Deutscher
    from Germany
    We removed the body from the frame, now the Model A gearbox could be removed and the Volvo M40 gearbox with truck bell housing could be installed, it fit surprisingly well, all the screws went into their place, the conversion kit contains everything you need for operation.
    The conversion kit is available here in Germany, a stroke of luck.
    Now put everything together, shorten the output shaft, insert the bearing and press in the adapter universal joint and put everything together, drill a hole and cut a thread in the shaft and the original screw from the Model A is in its place.
    LCGarage, catdad49, treb11 and 22 others like this.
  17. Baumi
    Baumi
    Hi Harry, welcome on board! You ´re doing a nice job on your A. I used to have a 30 coupe with a G28T banger, it was a blast. I wish I had known about the Volvo transmission swap back than.
  18. Outback
    Outback
    from NE Vic, Oz
    Nice work, what era is the Volvo gearbox? 3/4 spd? Did these have O/Drive?
  19. Deutscher
    Deutscher
    from Germany
    Hi Baumi, are you still driving your 30?
    A Model A with a G28T is a great car, my engine is currently at the repair shop and is having bearings installed.
    From the 1961 model year, the new M 40 gearbox was installed together with the B18 engine in the PV (Buckel) and P120 (Amazon) models.
    The M41 has a Laycoc overdrive, but the torque tube has to be m***ively rebuilt for this, or switched to an open drive.
    The M40 is a fully synchronized 4-speed gearbox.
    The last gear is the same - 1/1, but the gear ratios in the other gears are more evenly distributed in the M40.
    Model A:
    1. 3.12:1
    2. 1.85:1
    3. 1:1
    M40:
    1. 3.13:1
    2. 1.99:1
    3. 1.359:1 or 1.362:1,
    4. 1:1
    Greetings Harald
  20. Baumi
    Baumi
    Harry, it was a car I gave to my Dad. He drove it for a few years and somehow lost interest and wanted an RV instead, so the A went to another home and he bought a RV. 61 buick 117.jpg
  21. Deutscher
    Deutscher
    from Germany
    Wow, that's a great gift, it's a shame your dad wanted something different,
    you can't force someone to be happy.
    You have a nice workshop.
    Before the Model A, I spent 2.5 years rebuilding a '62 C10.
    Here is the link to the build
    https://67-72chevytrucks.com/vboard/showthread.php?t=829782
    Greetings, Harald
  22. reffiesj
    reffiesj
    Great start. Following along!
    winduptoy and Deutscher like this.
  23. Okie Pete
    Okie Pete
    Welcome to the HAMB Diggin your A
  24. Model A Gomez
    Model A Gomez
    I'm a fan of Ford 4 Bangers, had a 30 pickup with a B motor, Winfield head, Mallory distributor and an Ansen intake with a Holley 94. Used it as a daily driver for years and finally sold it, Just started on a 29 Roadster pickup with a banger in it, Snyder's 5.5 to 1 head, Burns manifold with a Holley 94 and a 50's Mallory dual point with centrifugal advance. Was going to be a quick and dirty build without a complete tear down but got out of hand and just set the engine back in the frame.
  25. Deutscher
    Deutscher
    from Germany
    A very nice roadster pickup, I like it.
    My engine is still at the engine repair shop and is having bearing shells installed, there are already a few parts waiting to complete the engine.
    Greetings Harald
  26. Model A Gomez
    Model A Gomez
    The RP looks better than it was, it was cobbled together and when I started fixing things it ended up as a bare frame. This is the third banger powered Model A I've done, 29 Special coupe stocker, my avatar 28 Special Coupe with a flathead V8, 30 Pickup with the B motor and later an inserted A motor, 30 Sport Coupe with a flathead V8 and the Roadster Pickup. I still have the 29 Coupe, 30 Sport Coupe and the Roadster Pickup, too many cars but sold a couple over the last few years. Guess I stuck on Model A's, really like what you did with the top on your coupe, good job on the patch panel! It's easier to build a Model A over here, lots of parts available and can get them in a couple of days, I see a lot of nice cars built in Europe.
  27. Deutscher
    Deutscher
    from Germany
    These are beautiful vehicles, so they have a lot of experience.
    I still have a lot to learn with the Model A, it only exists in my head how it should look when finished.
    Now the ch***is and brakes are to be reconditioned and the 32 axle is to be dismantled and reinstalled in the coupe, that will be exciting.
    Greetings Harald
  28. Deutscher
    Deutscher
    from Germany
    Today, something that is a trivial matter for most people,
    I took off the rear brake drums, what a battle, I won.
    A knife puller, heat and a hammer were my friends, both sides off and I was able to inspect the brake,
    well, we're going to completely replace everything, I'll order the front one at the same time,
    the axle on the left has worn out and ruined the pads too. Tomorrow I plan to remove the spring and pull out the axle, we'll continue....
    Greetings Harald
  29. burl
    burl
    from Minnesota
    Realy like those volvo 4 speeds this will be my fourth conversion. First time saving the torque volvo 3.jpg race car.JPG tube
  30. Deutscher
    Deutscher
    from Germany
    I had saved your conversion together with Marcus's at the time, but it was out of reach because I wanted to keep the torque tube.
    The 4th conversion you've done now, wow.
    The racer will be great, with the shortened wheelbase it is of course difficult to keep the torque tube.
    I'm doing the 1st and I know nothing about hotrods, I'm growing into it and letting myself be inspired by you. Greetings Harald
