Hot Rods Chopped closed cab model a
Discussion in 'The Hokey Ass Message Board' started by Jess Rockatansky, Nov 12, 2024.
  1. Hey guys and gals trying to get some inspiration for my build, got me a 29 pickup and I'm building a traditional style hot rod but don't care for that east coast tall top look, I want a mild chop I'm 6 feet tall so can't go to low, help me out please! What's the best chop and how do I go about doing it? 20241106_105233.jpg
    Tow Truck Tom and RAT "T" like this.
  2. alchemy
    alchemy
    Mock up a seat and some pedals and steering wheel, then sit in it. The only way you’ll know.
    dana barlow, ClarkH, jaracer and 5 others like this.
  3. 49ratfink
    49ratfink
    I say give it a Bonneville chop and drive with your head above the roof... don't forget your leather helmet and goggles
    Cooon and Jess Rockatansky like this.
  4. I'll put my seat in it and mock up a steering column tomorrow and measure my head room!
  5. alchemy
    alchemy
    Since you’re tall and these trucks are short, don’t be fooled that lowering the seat will give you more room. Doesn’t work like that. Might gain some room by thinning the seat back, but leave the base in place.
    ClarkH, 51 mercules, Kiwi 4d and 4 others like this.
  6. Pass The Torch
    Pass The Torch
    I'm 6'2" and have one I'm building. The chop kills the proportions (in my opinion), but that's not the question. You run out of room real quick; never mind if you need a recessed firewall... I would say that the amount of chop will equate to the distance you will be able to drive it comfortably.
  7. Just Gary
    Just Gary
    Be really careful you don't chop it too much.
    -A pickups are really tight.
    -Lowering the seat puts your **** closer to the pedals, thus reducing your leg room.
    -Plus there's no room to recline the seat; your back is vertical, which is uncomfortable on long trips.
    -Finally, if your ch***is has any rake, that will further reduce your vision out the windshield.
    Hope this helps.
  8. Corn Fed
    Corn Fed
    Mock up will only get you close. Before you get excited and actually start cutting you really ought to build your ch***is, get pedals mounted, steering column hung, and seat made.
    My A pickup is very tight and it is not chopped, not channelled, and doesn't have a recessed firewall. I'm 6-1 and can I only handle about an hour at a time driving before I need to get out and stretch.
  9. 05snopro440
    05snopro440
    Really good point about the rake affecting visibility!
  10. 05snopro440
    05snopro440
    I really like the 28-29 closed cab pickups and roadster pickups. I am building a roadster pickup with a stretched cab because I'm 6'2" and if I don't fit comfortably in it then I won't drive it. I've sat in closed cabs with the seat and pedals done various ways for more room and they're all too small for me.
  11. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    There it is:cool:
  12. Dago 88
    Dago 88
    Although mine is a ‘30 model & is a different ball game it may give you an idea, it is chopped 2 & 1/2 inches. IMG_3316.jpeg
    EVL401, dana barlow, Dino 64 and 4 others like this.
  13. flatheadpete
    flatheadpete
    from Burton, MI
    I like 'em stock roof height myself.
  14. twenty8
    twenty8
  15. denis4x4
    denis4x4
    from Colorado
    You can buy extended 28-29 cab corners and rework the top wood to give a better profile. These corners are 6-1/2" longer than stock
  16. 05snopro440
    05snopro440
    Full fendered 28-29 closed cab pickups with a good stance are just the best.
  17. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Chopping screws up the proportions. There are cabs that look better after a chop but the 28-29 pu cabs aren't one of them. The black one flatpete shows is a textbook of how to build a 28-29. Check out the 28-29 pickup Jack Linden from Prescott AZ built a few years ago. It says it all. Leave the sheet metal stock and slam them on the ground. Just thought of another, windshield wiper Bob from Newport Engineering has been driving a stock bodied/slammed 28-29 for decades. It's powered by a Chevy II 4 cylinder. A couple years ago he made the trip to the LARS pulling his gennie teardrop camping trailer. I've done several slammed customer ch***is for 28-29 trucks using the 4.3 V6, plenty of power and they fit between the stock firewall and radiator under a stock hood. Good luck.
  18. chickenridgerods
    chickenridgerods
    from DSM, IA
    The '28-29 CCPU just doesn't lend itself well to being chopped. Any chop has to be a very subtle one to work well. Super easy to screw up the proportions as @krylon32 notes.
  19. Just Gary
    Just Gary
    Case in point:
    @Jersey Suede 's CCP.:cool:
    SOHC427, charleyw, jet996 and 3 others like this.
  20. 05snopro440
    05snopro440
    Dino 64 and Just Gary like this.
  21. 05snopro440
    05snopro440
    jammer and Just Gary like this.
  22. Hitchhiker
    Hitchhiker
    I'd like to do a 28-29 pickup with just the above windshield header panel removed and corresponding amounts of the door frames and back of cab.
    I have not been able to talk @ClarkH into it.
    ClarkH and gimpyshotrods like this.
  23. I'm considering leaving it unchopped I put the seat in it today and sit in it, it's pretty close as it!
  24. It will definitely have a rake, considering leaving it un cut the more I look at it the more it grows on me
    lurker mick likes this.
  25. clem
    clem
    05snopro440 and Jess Rockatansky like this.
  26. 05snopro440
    05snopro440
    That type of subtle modification is what was done to the truck we were discussing in the 3 posts directly before yours.
  27. alchemy
    alchemy
    Short people got no reason…
    …not to chop their A. Everybody else should leave them tall.
    A Boner and 05snopro440 like this.
  28. gimpyshotrods
    gimpyshotrods
    Make the top of the door gl*** even with the top of the windshield gl***.
  29. twenty8
    twenty8
    There's a good boy. Look at it a little bit more, until that urge to chop it goes completely away .....
    These trucks look way better tall.;)
    1933_willys_77, jet996 and 1biggun like this.
