Art & Inspiration Tech School Students Doing Good
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Nov 7, 2014.
  1. Sharpone
    Sharpone
  2. bobss396
    bobss396
    My HS had a great auto shop. We worked on anything from lawnmowers to outboard engines (there were 2 test tanks, one rated to 200 HP), to car engines.
    There were 5 or 6 engines on stands that we worked with. We did tune ups, compression tests, etc. I later wound up with a good running 332 Ford engine.
    Since then, the shop was largely dismantled and the big thing is the annual robotics compe***ion.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I like this vintage hand lapper. It precesses in a stutter step fashion as it rotates the valve.
    brEad, deathrowdave, Sharpone and 2 others like this.
  4. Fortunateson
    Fortunateson
    Oh I like that! Since my Dad was a stay at home dad and my mother went out to work I've never understood or believed that "woman's work" BS. Anything involving strength can usually be worked round...
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    To paraphrase Archimedes,
    "Give her a lever long enough and a fulcrum on which to place it, and she shall move the world."
    deadbeat, brEad, Sharpone and 2 others like this.
  6. Another success.
    broken water neck bolt. IMG_3106.jpeg welding practice panel.
    students measure and cut the 24” panel in half. Prep and spray a weld thru primer. Punch holes on one end for MIG. Resistance spot weld the rest
    Then cut some of the resistance welds apart.
  7. Jeff34
    Jeff34
    I have the same one. Turns both directions, but more in one direction than the other so it's not just reciprocating, but rotating at the same time. Cool design.
    Really love what you're doing for these kids. We have some great HS programs where I live for kids who may not want to go to college, but get into a trade. We have good auto shop programs at our HS, and a great program at our Junior College.
  8. Cruiser skirt mods
    Students first time to do this. Not bad. He’ll get better
    Looks better than my first try.
    Here’s some resistance welding
  9. Squablow
    Squablow
    What exactly is the "pencil trick"?
    Sharpone and anthony myrick like this.
  10. Use the carbon as a guide coat.
    You can use it to dial in body lines
    Squablow and Sharpone like this.
  11. Got a little more done
    we’ll make a new fuel line and put a kit in the carb. Thinking about running this s**** yard air cleaner IMG_3300.jpeg
  12. Fabricated a PS pump mount
    some plate and an old gm pump mount.
    Moved the alt to the other side IMG_3746.jpeg IMG_3787.jpeg IMG_3782.jpeg students built the air cleaner mount today and just about finished the alt mount.
    Okie Pete, flatheadpete, rod1 and 9 others like this.
  13. Automotive students rebuilding some 60s drum brakes
    new stud is on the way.
    wrapped up the alt mount on the 292.
  14. Sharpone
    Sharpone
    What’s the 340 going in? Cool
    Dan
    Truckdoctor Andy likes this.
  15. Swepline Dodge SWB truck
  16. Sharpone
    Sharpone
    Excellent
    Dan
  17. What is the 292 going into?
    Sharpone likes this.
  18. 61 c40
  19. 26Troadster
    26Troadster
    to bad that 340 doesn't have the w2 heads, still a great engine. the old purple shaft made for a nice performing setup.
    anthony myrick and Sharpone like this.
  20. The cleaned one was worse than the other one shown IMG_4813.jpeg soaked in CLR, red scuff pad followed by a 3m black cleaning disc
    brEad, Squablow, Okie Pete and 4 others like this.
  21. flatheadpete
    flatheadpete
    from Burton, MI
    These kids are damn lucky to have you around.
    brEad, Uncle Ronn, bobss396 and 5 others like this.
  22. 26Troadster
    26Troadster
    anthony, thanks for what you do for these kids/young adults. maybe this year we will cross paths at one of the shows.
  23. The before pic of the actual cleaned hub cap.
    50/50 mix of CLR and water. Soaked probably a couple days total
    even removed the majority of the remaining paint.
    The inside after 24 hours
    We first only poured the CLR on the inside and planned to blast the outside but after seeing how well in inside did, I bought more and submerged the cap in a plastic covered container.
  24. Sharpone and anthony myrick like this.
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Careful where you leave stuff soaking. Had a soup can half full of CLR and water like you made up. The vapors rusted anything metal near it.
    Squablow, Sharpone and anthony myrick like this.
  26. We got it in a covered plastic tote
    Plan to do manifolds for the Merc next
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If it’s a sealed cover know that it g***es out creating pressure. Is it enough to pop the top???
  28. I wouldn’t call it sealed completely
    Just a cheap tote from the dollar store
