Back in the late 60's I worked at a bodyshop that bought cars that had engine fires to fix up and sell. We would make sure they were not locked up, put new carbs, hoses, vacuum lines, and wiring harnesses on them. Never had one that didn't run after we did that. But these were cars that just had engine fires. Not cars that burned in a garage or other building, which get much hotter.
Got the engine home, heads look good but the number 2 cylinder has a bad gouge in it like a ring busted. So I'm scrapping the block and keeping the heads for future projects.
I bought a burnt corvette once. was using for parts, I sold the transmission,to a friend, he brought it back, because close inspection you could see everything that was bolted together was warped? The fire got that hot! JUNK! so, look close!
> >cylinder has a bad gouge> >gouge is so deep that wouldn't clean up. > >am> > I ain’t skeered of a scratched cyl > > Post a picture of gouge if possible.
