Technical fuel regulator?
Discussion in 'The Hokey Ass Message Board' started by miller, Nov 11, 2024.
  1. miller
    miller
    from New Jersey
    Hi, need some help. What fuel regulator should I use for an electric pump that can put out up to 9 psi? Thanks
  2. Fuel regulator huh? Must be a gas. Hehe.
  3. lothiandon1940
    lothiandon1940
    ..Need to know more about your carb situation.
    Tim, Hillbilly Werewolf and squirrel like this.
  4. MCjim
    MCjim
    from soCal
    The venerable Holley should be fine.
    Holley Fuel Pressure Regulators 12-803
    Part Number: HLY-12-803
    swade41 likes this.
  5. miller
    miller
    from New Jersey
    sorry......350sbc 2 barrel. thanks for the info and replies.
    dana barlow likes this.
  6. swade41
    swade41
    from Buffalo,NY
    Read the specs on the pump, it may be factory set at 7
  7. alchemy
    alchemy
    I also recommend a Holley like shown above, but they come in at least two pressure ranges. You need to know what the carb needs, not so much what max the pump can put out.
    lothiandon1940 likes this.
  8. 19Fordy
    19Fordy
    Buy the Holley diafragham for that regulator that resists the modern gas.
    Mr48chev likes this.
  9. jimmy six
    jimmy six
    9 psi. 350-2 barrel? Get a Carter and don’t worry about one. 5 psi and a 5/16” line. IMG_0403.jpeg
    57Fury440, Just Gary and jet996 like this.
  10. krylon32
    krylon32
    from Nebraska
    Go Holley if you need one. For God's sake don't buy one of those dam rotary dial regulators.
  11. Mr48chev
    Add in NOTHING made of plastic. It's not if they will ever break but when. I have to agree 100% with Jimmy Six though, why the hell spend extra money on or buy a pump that puts out that much more pressure than you actually need or want rather than the Bubba factor of saying you have that pump?
    lothiandon1940 and Unkl Ian like this.
  12. 1971BB427
    1971BB427
    from Oregon
    I use the Holley 3 port pressure regulators on everything I build whether it's an electric fuel pump, or mechanical. I use a pressure gauge also, and set mine for 5.5-6 psi output. I've seen far too many mechanical pumps that put out well over the pressure most carb needle seats can handle, and resulted in flooding carbs. There's really no reason to ever need more than 6 psi on a street carb/engine setup.
  13. snoc653
    snoc653
    from Iowa
    Something to consider. Yes the regulator can limit the pressure but can the pump handle the back pressure and the extra load created by it. You might need a regulator with a return. This can be a lot of extra plumbing and work for little gain since your setup clearly doesn't need 9 PSI. You also need to figure out a kill switch for the pump in case of a leak or accident that could allow fuel to keep pumping.
    '51 Norm likes this.
  14. miller
    miller
    from New Jersey
    Thanks for all the replier. Miller
  15. Jack E/NJ
    Jack E/NJ
    from NJ
    One too many hose barbs used in the pump kit above. No hose between the pump & carb.
  16. Doublepumper
    Doublepumper
    from WA-OR, USA
    ^ Not when the pump is mounted in rubber. The hardline will hamper isolation.
    1971BB427 likes this.
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    Line loops are used for isolation, not hose.
  18. Doublepumper
    Doublepumper
    from WA-OR, USA
    ^Nothing is perfect. Loops can crack from metal fatigue, caused by long term vibration:)
    2OLD2FAST likes this.
  19. alchemy
    alchemy
    I’ve tried about half a dozen electric pumps and mount them all with rubber isolators on the bolts and a short bit of hose on each side. Still have noise but probably less than if it used hard line into it.
  20. ClarkH
    ClarkH
    Malp***i Filter King. Combo filter and regulator. Well made, looks right.
  21. 1971BB427
    1971BB427
    from Oregon
    I always use hose to isolate, or to make maintenance easier on my cars. But I keep with NHRA limits of less than 12" of hose. From frame to engine I have a short 3" piece from hard line to hard line for isolation. At my rear electric pump and fuel filter I have 4" between each so they can be maintained, or replaced easily.
    Even hard loops can eventually fracture from vibration in some situations. And I really don't want coils at the fuel tank, pump and filter setup.
