Technical Cadillac 390 in Shoebox
Discussion in 'Traditional Customs' started by Chop50, Nov 15, 2024.
  1. Chop50
    Chop50
    Hi All,
    Has anyone installed a 390 Caddy in a 50 Ford Shoebox? I have an adapter to a Ford Trans but oil pan looks that it could be a problem. Front cross-member has already been cut down to fit a Ford 429 but thinking steering linkage could be a sticking point.
    Thanks, Steve
    bchctybob likes this.
  2. 42merc
    42merc
    The fix 50 years ago was a dropped tie rod.
    Someone will provide a photo.
    warbird1, bchctybob and bschwoeble like this.
  3. Okie Pete
    Okie Pete
    I saw one in a shoebox once . The bottom radiator hose was run through the frame to the radiator . Be sure to check the radiator hose placement .
  4. bchctybob
    bchctybob
    A Cadillac in a shoe box, that’s a cool classic combination. Motor mounts and dropped tie rods were readily available back in the old days. I’m not sure if anyone makes them now but you could always do your own. I had to do one for my Stude pickup with a Pontiac. I split the difference, dropped the tie rod some and modified the oil pan a little. I used a piece of a sway bar with the same diameter as the transfer bar and made a quick fixture to hold the ends in the correct relationship. If you don’t feel comfortable welding it, take it to a professional welder.
    Okie Pete and Moriarity like this.
  5. Dave G in Gansevoort
    from Upstate NY
    Frick Motors used to build them for customers. Called them Fordillacs.
    Stan Back, Okie Pete and bchctybob like this.
  6. Early caddy in a shoebox was common enough that when AMT released their 1/25 scale 49 Ford model kit in 1962 it included a three deuce caddy engine option
