Projects 41 Ford pickup finally got it home and pictures pictures
Discussion in 'Traditional Hot Rods' started by joel, Jul 19, 2017.
  1. joel
    joel
    That's a cool tach mount for sure. I stumbled into some luck when I flipped the insert over and started sorting through the parts that came with the gauges. The u bracket for the speedometer cleared the bottom row and the top row u clamp is modified so it rests on back side of the dash and helps hold the panel tight. Now I am thinking I could silicone the panel to the dash instead of more clamps.
    Thanks BB
    Thor1 and Bandit Billy like this.
  2. pprather
    pprather
    Just a suggestion on gauge layout.
    Fuel and coolant temp are the two watched the most on a long cruise.
    Put them both on the same side, or both in top row. I like top row as eyes on speedo can easily see both.
    Oil pressure and volts get less attention while driving.
  3. joel
    joel
    I'll have to wait until I get the cab back on and the column in. Maybe by spring but thanks for the suggestion.
    pprather likes this.
  4. Dick Stevens
    Dick Stevens
    I always feel that the most important gauges to see are the Oil Pressure and temp so I want them where they're easily visible. But that is a personal decision on what you want where you can see them easily.
    John Heckman and pprather like this.
  5. joel
    joel
    3 months since my last post. The damage to the windshield area on the cab set me back and pissed me off. I can't solve problems without a clear mind. Here is a picture of the start of the repair.
    The damage from mouse piss is growing.
    Some t******* to do and spot welds to cut on the pinch weld. I think I will have to make the patch in 2 pieces.
  6. Bandit Billy
    Bandit Billy
    Maybe make a little door in the bottom of that that drops down to hold your sungl***es and garage door opener.
    Like this but not for a toyota
    Thor1 and loudbang like this.
  7. joel
    joel
    Interesting idea, but right now , I'll be happy with a patch that didn't warp the pinch weld so the windshield seal doesn't leak.:)
  8. neilswheels
    neilswheels
    from England
    Feel your pain, I'm currently repairing both sides of the body above the door openings, and the top corner of the windscreen frame due to rodent infestation, just when I thought I was done with the rust. Keep going, you'll get there
  9. That's funny Joel. Pretty much every hot/street rod event I've attended over the years where it's rained had most (if not all) the attendees sopping up windshield, side window, door seal or cowl vent seepage with towels, shamwows, paper towels etc. Some more than others.
  10. joel
    joel
    I think mice are worse than regular rust : neither is good.
    My coupe windshield doesn't leak , but the cowl vent does a little and at the top of the vent window you can see daylight..... can't go through a car wash for sure.:)
    Thor1 likes this.
  11. joel
    joel
    I finally got a patch for the hole above the windshield. A neighbor from about 40 years ago said he could make it in one piece by shrinking it. He did it. He was in grade school when his parents moved out of the neighborhood and I hadn't seen him since. Turns out , he is a real car guy and meatal finisher.
    All I had to do was a some t*******.
    The hole before t*******.
    first tacks; I wanted the fit tight front to rear so the weld wouldn't pull the pinch weld IMG_2773.jpg
    All the edges lined up and finish weld started. I'm going to tig the little notches on the pinch weld flange. The big vice grips are holding the roof side of the pinch weld in place against a piece of angle iron .
  12. joel
    joel
    I finally got the patch above welded in and welds dressed.
    Then, I found 2 holes just above the upper hinge mount. Piece made and welded in and working on dressing weld.
  13. Mart
    Mart
    Good solid repairs, Joel. It was advantageous that you were able to get the cab upside down.
    osage orange and Kelly Burns like this.
  14. joel
    joel
    Absolutely, Mart; when I'm welding I have to get my face pretty close to the work. The rotisserie is borrowed and the oowner is going to need it back soon.
    osage orange likes this.
  15. joel
    joel
    Dressed the hinge weld and found more pin holes. I also touched up a factory weld that was partially cracked.
    I need to do a little more on the one in the last picture.
    Okie Pete, The 39 guy, Thor1 and 2 others like this.
  16. joel
    joel
    Finally removed a rusty piece of cab skin.
    With the cab upside down, I can see better and not use a step stool. I added a piece of steel ,tacked between the rotisserie mount arms, to hold the door gaps that exist when the cab is right side up. This happens due to the clearance in the rotisserie parts that allow for their adjustment.
    First cut away and lots of t******* and fitting to come.
    I don't know how this is going to come out and fortunately, the front fender will hide a lot of the patch seam. Fingers crossed.
  17. warhorseracing
    warhorseracing
    from cameron wv
    It will work out. It is only metal so do not overthink it but rationalize. Remember when you do one thing with metal something else will inevitably also happen. Take your time. do not get frustrated. You can always cut it back out and start over just don't get frustrated. You will have some compound curves to content with so, take your time.
    Outback, Algoma56, The 39 guy and 2 others like this.
  18. joel
    joel
    I know you're right, but the words are great to hear. Thanks for following.
  19. warhorseracing
    warhorseracing
    from cameron wv
    It is always interesting to see how other people attack a problem that arises. Helps one to learn something new every day so life doesn't get boring. ;)
    Outback and The 39 guy like this.
  20. joel
    joel
    Stay tuned; I should have the first patch fit and ready to tack in soon. I'll have to re-hang the door to check fit of the patch.
  21. joel
    joel
    Lots of welding and grinding, but some progress.
    I decided to add this piece from the patch panel. The re-inforcement that was here is for mounting the front fenders if the cab is used on the big trucks. Otherwise it's useless and leaves 2 open holes under the pickup fenders.
    The nasty hole in the pic (left-center) is a mounting hole for the front fender on the pickup. At least it was on mine. I think I'm about ready to tack the rest of the patch in place. Thus the copper weld through primer. On the other side, I'll do the panel all in a one piece patch.
  22. The 39 guy
    The 39 guy
    It's good to see you posting your project progress again Joel!
    Kelly Burns and anothercarguy like this.
  23. Bandit Billy
    Bandit Billy
    I don't recognize that hole in the cowl. I see why they made it though and agree to leave it. What do you think about reinforcing it though, maybe clean it up and weld a washer in the back? So it isn't just sheet metal.
  24. joel
    joel
    Yes, BB, that's the plan. I've run into a possible snag after tacking the last panel in place. I may have to back up on this side. I'm considering going to the other side to see if I can see what I missed. Opportunities.
    Here is the gap. Although badly rusted, the original had no gap; which makes me think the patch is too far out. It does line up with the door skin pretty well.
    The filler piece is because I ran out of metal.
  25. The 39 guy
    The 39 guy
    Sure would be nice to buy a patch panel that is an exact fit....This isn't one of them. You have a few opportunities for slicing and hammering to get those those panels to line up... You will figure it out!
    Bandit Billy and Outback like this.
  26. joel
    joel
    You're right Sam. The fact that the fender covers most of the repair may save me.
    warhorseracing likes this.
  27. joel
    joel
    I realize there is supposed to be a cage nut near the bottom of these repairs. I can't get the fender on the cab because the rotisserie arms are in the way. I'm going to make a pattern off the fender bolt holes; I'm thinking if I use tin it may be more accurate. I'd better do that before I finish the panel repair.
  28. The 39 guy
    The 39 guy
    That should work. I like to use clear plastic sheet to transfer holes from one panel to another.
    Dick Stevens likes this.
  29. joel
    joel
    I like that idea, Sam. I had another idea last night; I could mount the running boards to the rolling ch***is and mount the fender using the holes in the fenders and boards and tie the inner fender to the stock yoke with the yoke bolted to the front crossmember. This might produce a measurement that I can use on the cab. If the plastic transfer lines up with my guestimate dimension, I'll feel pretty good.
    Bandit Billy likes this.
  30. The 39 guy
    The 39 guy
    That is a lot of work! But should give you an accurate measurement. Isn't this fun?:)
    Bandit Billy and anothercarguy like this.
