Technical Flathead Oil Line Question
Discussion in 'Traditional Hot Rods' started by 32 Dave, Nov 16, 2024.
  1. 32 Dave
    32 Dave
    I have a firewall mounted bee hive filter with copper hard lines from the block to the filter and also from the filter back to the oil pan. The lines are @10 years old and the line from the block (oil pump) to the filter started leaking at the compression nut on the engine block.
    I will replace the line and the fittings but wondered if I should use a flexible line rather than a hard line. My thinking is that engine vibration may have caused the fitting failure over time.
    I like the hard line look but could put a short rubber line from the engine block to the supply line to absorb vibration
    What do you flathead's think, any recommendations
  2. BJR
    BJR
    Or you could put some vibration loupes/coils in the lines to absorb and spread out the stress.
    V8-m, alanp561, Jack E/NJ and 2 others like this.
  3. alchemy
    alchemy
    Engines vibrate. Make sure you have flexible lines between the engine and any other component not mounted to the engine.
    Lots of coils spread the vibration over a longer area. Is that good enough? You won’t know until it fails.
  4. Okie Pete
    Okie Pete
    More coils the cooler the engine will run
  5. 32 Dave
    32 Dave
    thanks The line had a loop in it but it is thick wall copper tubing and not very flexible. I will install a flex line this time
  6. ct1932ford
    ct1932ford
  7. ct1932ford
    ct1932ford
    Toms Dogs, Xman, seb fontana and 2 others like this.
  8. MojoRacing
    MojoRacing
  9. 32 Dave
    32 Dave
    Great looking set up ct1932ford but I wanted to keep the look less high tech. I ended up getting a rubber hose made at Hydraulic Hose here in Austin that will connect to IMG_2809.jpg the copper line I was using
    Thanks for all the input and suggestions
    V8-m, leon bee and ct1932ford like this.
  10. ct1932ford
    ct1932ford
    I used Racetronix fittings and hose. Size 8AN
    It’s just under 1/2”id
    seb fontana and MojoRacing like this.
  11. Bandit Billy
    Bandit Billy
    I didn't know fatheads had oil lines. Learned something new, or old. :cool:
    Toms Dogs and Ziggster like this.
