Projects 1963LeSabre Brake Issues
Discussion in 'The Hokey Ass Message Board' started by Anthony Herrera, Nov 16, 2024.
  1. proportion
    0 vote(s)
    0.0%
  2. residual
    1 vote(s)
    100.0%
  1. Anthony Herrera
    Anthony Herrera
    im keeping the drum/drum system for now! as its a budget build and my first ever build lol
    i drove it for 2-3 months with no issues and now the booster went bad
    replaced shoes all around , got my self this new dual master cylinder and booster and filter checked it to match my vehicle
    https://ebayvehicle.com/app/31PS
    bled the entire brake system about 2 times lol
    i tried to connect everything like the original system
    so i blocked the two left sides with plugs and connected the one brake line onto the new master and connected my original sensor
    my vehicle has one brake line connected to the master and goes down connected to a Tee line
    and well i thought i was good but im still getting spongy brakes ! pedal feels nice and firm as it should but as soon as i turn the engine on it goes completely flat!
    not sure if i forgot to add something ? not sure if that proportion valve i believe it’s called was supposed to go on ? really lost lol
  2. Budget36
    Budget36
    Your link doesn’t work as you expected, well not for me anyways.
    Why the new MC if the booster went bad?
    Johnny Gee and Anthony Herrera like this.
  3. Anthony Herrera
    Anthony Herrera
    came all together as one is all
    Johnny Gee likes this.
  4. SS327
    SS327
    Are the brake shoes adjusted properly? When you bleed again does any air come out? How are you bleeding them?
    Anthony Herrera likes this.
  5. Baumi
    Baumi
    So you connected your single line system to a dual master, using only one port? Did I understand this correctly? Can you post a photo of what you have?
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ This is how I’m seeing it as well.
    We need actual photo’s from you, not a link from where you bought your supplies from to get a better understanding.
    firstinsteele likes this.
  7. Pictures... we like pictures... :D
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
  9. BJR
    BJR
    So you didn't like the responses you got so you posted the same question again?
  10. Anthony Herrera
    Anthony Herrera
    naaa lol new to this page was trying to figure out where and how to post lol
  11. Budget36
    Budget36
    Kinda at the top right of your thread, click on “watch thread” set it up to notify you-how you want.
    Then click on the notification and it brings back to the first unseen reply.
    Easiest way to find a thread you started.
  12. Budget36
    Budget36
    IMG_1180.png See under your poll vote thing?
  13. Anthony Herrera
    Anthony Herrera
    yes shoes are adjusted and no air comes out when bleeding . bleeding w car off, pump 5 time and hold the pedal down while i bleed each side
  14. Anthony Herrera
    Anthony Herrera
    thanks for that boss!
  15. Anthony Herrera
    Anthony Herrera
    yes this is exactly what i think i did as well lol
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ll say very little but I have to ask. How did you bleed the rear circuit??? IMG_3380.jpeg
    SS327 likes this.
  17. Anthony Herrera
    Anthony Herrera
    that one line that’s connected from master cylinder goes down to Tee line i’ll go take a pic right now
  18. Anthony Herrera
    Anthony Herrera
  19. Budget36
    Budget36
    Does that mean you don’t have a separate front and rear circuit?
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I understand what you’ve done. What I’m asking is, is there zero air left at the rear circuit of the master cylinder?
    SS327 likes this.
  21. SS327
    SS327
    That ain’t going to work there sparky. Split the front and rear brakes and get a chevelle proportioning valve and plumb it correctly. Or better yet find one from a GM B body 67 and up and use that.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    In theory it can. But never engineered to be used that way. Also if op got into an accident where braking would become an investigating issue. Well, op would be SOL.
    SS327 likes this.
  23. dave agosti
    dave agosti
    I believe the second unused chamber of the M/C is the problem. I think both chambers need to have bled pressure.
    You are so close, eliminate the tee, and connect front and rear lines to the M/C.
  24. If they are both bled then it should work but at this point may as well split them
  25. Anthony Herrera
    Anthony Herrera
    okay will do !! i will need to add 2 10Lb residual valves to each line correct? one for front and rear?
  26. I'm not big on proportional valves myself. On something like this car, I would go distribution block.
    It is a lot less complicated. I have CPP one in my car. Summit sells a similar one for a little less. It takes a hydraulic brake light switch.
  27. Illustrious Hector
    Illustrious Hector
    As SS327 and bobss396 have pointed out, you need a distribution block. Proportioning & residual valves are for cars with under floor master cyl. Distribution blocks have 2 inlets to accommodate the 2 coming out of the m/c and 2 outlets to feed front and rear. Lose the light switch, both m/c outlets have to go somewhere.
    There's 6 inches of snow on it but I can take a pic of the 64 Wildcat I changed to a 2 compartment m/c
    bobss396 likes this.
  28. Nope this is completely wrong, wether or not a brake system needs proportioning or residual valves is not dependent on master cylinder location.
  29. Sharpone
    Sharpone
    57 Fargo I’ve been watching brake threads for a while. I plan on replacing the single pot MC on my early Dart with a dual reservoir. One question I’m still unsure on is when do need a residual valve. I understand the proportional valve - I think - my understanding is that with a proportional valve you can dial in front to rear bias.
    Thank you
    Dan
  30. Residual valves main purpose was to prevent air entrance into the wheel cylinders upon brake release. So any drum brakes should use 10# residual valves unless the wheel cylinders have cup expanders. Now if the master cylinder happens to be below the wheel cylinders or calipers then they can be used to prevent brake fluid from running back to the master.
    If you search a thread I did for tech week a few years ago it’s explained in there. I believe it was 57 Fargos brakes 101. Some thing like that!
    Budget36 and Sharpone like this.
