Hot Rods XO/PP Bonneville project
Discussion in 'The Hokey Ass Message Board' started by john mullen, Dec 28, 2017.
  1. saltflats
    saltflats
    from Missouri
    Thanks for the education. I play with 409's so this is new to me.
  2. john mullen
    john mullen
    Preparing to fab up the carb linkages 20241111_150511.jpg 20241111_150334.jpg 20241111_150157.jpg 20241111_150151.jpg
  3. Mitchell Rish
    Mitchell Rish
    from Houston MS
    How I've missed this thread/ build I don't know but I must say this. You Gentlemen are impressive.
    Dyno Dave, chryslerfan55 and D-Russ like this.
  4. john mullen
    john mullen
    20241118_152835.jpg 20241118_152830.jpg 20241118_152825.jpg Linkage coming together
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  6. D-Russ
    D-Russ
    They're 55s.
  7. Needs a pair of Cherry Bombs. Hehe.
  8. pprather
    pprather
    It looks like a trophy, sitting on the desk.
  9. D-Russ
    D-Russ
    It is, kind of. :)
    Dino 64, chryslerfan55 and pprather like this.
  10. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I didn't see a blower or turbo inlet - SO what are the spring s and burst panel / door for ? Also what is the advantage to bushing the lifter bore down to use the y block lifters ? Wider foot so a more aggressive ramp / or take advantage of the cam profile you have ?
    Again impressive. :cool:
    AmishMike and chryslerfan55 like this.
  11. D-Russ
    D-Russ
    You may have noticed the top plate on the intake is removable. The burst panel is for potential future supercharging – we can just swap out the top plate. And yes, the y-block lifters give a wider foot for more aggressive cam profiles.
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Blowers for everything. And I’ve never seen a case where it wasn’t for the better. I drove all the way across the country to get mine back IMG_2072.jpeg
  13. john mullen
    john mullen
    Thinking about the upcoming Holiday
    Season. I wish to express my/our
    Thanks to all the many friends we have made along the way on these Land Speed Racing journey. There are way to many to list but I haven't forgotten a single one of you. I am truly blessed. Thank you all for being a part of our journey. May you all be blessed in the coming Holidays.
    John Mullen and Team 640.
  14. D-Russ
    D-Russ
    Here are a few photos of John Decking the block today. 15:1, here we come!
  15. john mullen
    john mullen
    Ok GMC 302 guys
    Do any of you have a sorce for the freez plugs used on the 302 online six.
    Part numbers would be helpful.
    Thanks
  16. Gofannon
    Gofannon
    You should be able to measure them and buy them individually. That's what I did on my 270. Rock Auto , Summit etc.
    I'm not sure what's going on with this engine. Using the core plug holes for extra coolant flow?
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I suggest br***. It is disconcerting to find a leaking corrroded steel plug at the race track.
    BTDT, more than once.
    D-Russ likes this.
  18. Wes Gray
    Wes Gray
    Measure and see if it corresponds to a NPT pipe size, tap it and install square or socket pipe plugs. I have screwed cast iron plugs in SBC decks before decking.
  19. Wes Gray
    Wes Gray
    Would there be any advantage to running with the tailgate down?
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Mythbusters episode says NO.
  21. john mullen
    john mullen
    Putting the final touches to the inside of the block with Glyptal paint sealing up the pores in the cast iron block 20241207_134235.jpg 20241207_134559.jpg 20241207_101310.jpg 20241207_112535.jpg
  22. john mullen
    john mullen
    Fabed up a water pump adapter to supply water thrue the side of the block
  23. john mullen
    john mullen
    More photos tomorrow of the water pump
  24. john mullen
    john mullen
  25. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Now that is "outside the box thinking", and I'M digging it!;)
  26. jimmy six
    jimmy six
    Many GMC’s at Bonneville have used this style system when they have a crossflow head. The Meziere pumps today are way more efficient along with many others than we used from JABSCO. I’ve used 2 or 3 of the expansion holes and used various sized orifaces to get the coolant flow correct. We didn’t use much dyno time to perfect because of running fuel so it was done mostly on the fly with exhaust temp. John is doing an excellent job with his engine and I’m sure the results will show it.
  27. john mullen
    john mullen
    On behalf of team 640 I want to wish everyone a merry Christmas and a happy and prosperous new year.
    Please remember the reason for the season.
  28. seb fontana
    seb fontana
    from ct
  29. john mullen
    john mullen
    The day after Christmas begins the final ***embly of the 302 GMC. The crank is in and torqued to 110 pound feet the rear seal was tight when installed but has loosend up with rotation of the crank ***emble. The ***embly lube is very thick and sticky when it's cold lol 20241226_145553.jpg 20241226_145607.jpg
  30. Like, groovy man.
    Dyno Dave and Just Gary like this.
