rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. The first band slides on by hand. Its a spacer.
  2. 19Eddy30
    19Eddy30
    from VA
    Ok , so it would also give/ provide more of a contact surfaced area for the bearing to ride against,
    I am wondering if my
    M-W Modular 10inch is same way, I never have taken apart ,
    It was shipped compleat,
    I should went with Full Floater
  3. Before oven cleaner and buffing and after. 20241017_101005.jpg 20241102_145122.jpg 20241102_153912.jpg
  4. A sneak peek on how it might look. 20241104_172223.jpg 20241104_172529.jpg 20241104_172637.jpg
  5. The tubs are three pieces that are welded together. Alot of time was spent on the english wheel. Beads were rolled in for strength. A lip was rolled into the edge. The tub will be cut 1.5 inches from the edge. It will be welded to the body. The rest will have dzues fasteners holding the main section in place. This way i can have them powder coated for durability. I can remove them to work on the suspension.
    The kill switch was relocated. The brake lines are done.
    A die needed to be made for the dzues fasteners. Three holes need to be drilled. One hole needs a taper. The die will locate all three. The hard part is over. It should be done soon. Then off to the body shop. 20241115_164617.jpg 20241115_164632.jpg 20241115_164640.jpg 20241115_164659.jpg 20241115_164722.jpg 20241115_164740.jpg 20241115_164756.jpg 20241115_164806.jpg
  6. I sent the mag to FIE for servicing. I wanted my boxes and coils checked out. They passed with flying colors. So I sent the mag in. They found a broken wire and a split shaft at the key way. They said the bearings were crunchy and the rotor should be replaced. It's all back together and in the mail.
  7. Calkins
    Calkins
    It's good to have a smoking gun, instead of more questions! Glad that Spud found something that would explain what was going on.
  8. They said the vibration would cause the intermittent shutting off. You want to find something but nothing expensive. I will have a complete back up for the chaos. Justin are you going?
  9. Calkins
    Calkins
    I will be at Eddyville. Possibly Mo-Kan. I'm not sure on the rest. It depends on the Extreme Top Fuel schedule. I'd like to hit most of Jimmy's races if possible. I would also like to hit Bowling Green and Tulsa.
    bchctybob, porkshop and racer-x like this.
  10. I think i lost all of my followers since this thread got moved. It's not hardly worth the time to post anymore. Follow me on Facebook. My info is public. Anyone can see it.
    enloe, trad27, Limacharlie48 and 5 others like this.
  11. Dick Stevens
    Dick Stevens
    I don't think you've lost your followers on here, if you just go to facebook or instagram only you'll lose me :(
  12. richard souza
    richard souza
    from sbc
    X2
  13. Some of us are not on FB, and only on here. I know your time is valuable, but please consider keeping this thread active. It’s one of the best here, and I would miss it. Thank you.
  14. Harv
    Harv
    from Sydney
    Still following you from Down Under. Hope you keep posting please - learned a lot, and still more to learn.
    Cheers,
    Harv
  15. wrenchbender
    wrenchbender
    I still follow along I’m not a Facebook user but I’m sure I’m the only one like that these days
  16. DDDenny
    Well Brian, you know you have friends.........we've come a long way together!
  17. 19Eddy30
    19Eddy30
    from VA
    My self , No F B , I G , Tik..
    I also miss Nitro Madness ,
    Would like to see Off Topic grow more of********** H -Rs & Modern Nostalgic
    Looking rides,
    I also noticed in last few weeks since move to off topic , Not that many
    post/replies ,
    Your Thread is first I added to a watch list for up dates , I said in pass My take on changes From dual fuel has taken away from car , But I under stand the need , Hard to keep engine happy !
    Two different fuels requiring different tolerances ,
    I only Know of 2 that have done the Dual fuel , first around mid
    50s a 32 Roaster FH & you ,
    I under stand the Quest to go fast Modern parts needed ,
    enloe and chryslerfan55 like this.
  18. chucktown
    chucktown
    The HAMB is the closest I come to a "social media" site and the main reason I keep coming here is to follow your thread. I was a regular on both Inside Top Alcohol and Classic Funny Car boards until they went the FB route. I lost access to the community that feeds my technical/racing appetite, so I hope that you continue posting here!
  19. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Brain;
    I'm not on here as much anymore(life has required a bit too much input lately, but that, well, is life. :) ), checking only a few threads I like, but I do like yours. I know you walked a fine line in posting before, but OT should alleviate the worries/concerns about getting post(s) deleted, so that's good. Still appreciate the time & info you post. One of my favorites. If it matters...
    I also am not on "social media". I may get forced into it soon(as a place to sell), but it'll be severely limited, by choice. Also, a good portion of the value I find in the HAMB, & a few other similar sites, is that info & pics(at least now) are saved. Instant gratification might be nice - to a point - but when the info also lasts but an instant - it's borderline worthless & for any practical value - pointless.
    I do hope you keep posting here.
    Marcus...
  20. tomcat11
    tomcat11
    ^^^X3? Brian, you have always provided detailed Nitro and other tech as well as some really entertaining stories that I think people here have really enjoyed. It's been a window into a world that many folks never get a chance to see or learn about.
    Many of us are not into those other platforms or social media in general so, hopefully you will keep us in the loop here. Nice work on the updates to your car by the way. I have no doubt you will achieve your goals.
    Tom
  21. Tim
    Tim
    from KCMO
    I wonder if when a thread is moved if we have to re subscribe/ comment to get update notifications?
    those wheel wells turned out fantastic I
    Hope you keep posting.
  22. 19Eddy30
    19Eddy30
    from VA
    Look to right of thread , if watching it will show sunglass & your Lightning volt will be lite ,
    Also option to be emailed to new post
  23. My subscription to this thread survived the move to OT, no action needed on my part.
    427 sleeper likes this.
  24. Dick Stevens
    Dick Stevens
    No, you don't have to resubscribe. I still get notifications
    chryslerfan55, porkshop and Tim like this.
  25. mohr hp
    mohr hp
    from Georgia
    Hate to see you go Brian, I quit Facebook a couple months ago, other than Marketplace. Your posts are always very interesting to me.
    chryslerfan55, bchctybob and porkshop like this.
  26. TFoch
    TFoch
    I'm not on Facebook. I hope you continue the thread please!
    porkshop likes this.
  27. milwscruffy
    milwscruffy
    I still get email notices for this thread. To be honest, this thread was OT from the word go and be happy the Mods turned a blind eye and let it go as they did. It getting moved to OT should not have any effect on the amount of traffic it gets and not sure why he would stop posting. It is what it is.
  28. SimonSez
    SimonSez
    This thread still comes up in my Unread Thread list just the same as it always has.
    427 sleeper and milwscruffy like this.
  29. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes, the notifications stayed with the thread. I still read it everytime there is a new post. Just don't have anything to add to the conversation. All very interesting, but WAY OUT OF MY LEAGUE!
    chryslerfan55 and 427 sleeper like this.
  30. I too enjoy your posts. I only have FB to use Marketplace and I must be really old cuz I have never been able to understand how Instagram works. I click on something I like and in less than a minute I’m in a different world that I can’t even fathom! Please keep on keeping on here!
