Technical New 327
Discussion in 'Traditional Hot Rods' started by Mikey67, Nov 13, 2024.
  1. benchseat4speed
    benchseat4speed
    from Golden, CO
    You don't have a turd. 336hp @ 5700 is right on the money for a 10.5:1, dual plane, single four, stock 291 headed 327 with a mild cam in it.
    Sounds like a perfect driver engine. Put some miles on it, seat the rings, and it'll run even better.
  2. gary macdonald
    gary macdonald
    I’m pretty sure those pistons you pictured are cast , so be careful with the rpms and nitrous if you shoot it again .
  3. rj cromeenes
    rj cromeenes
    Sounds to me like a well tuned tunnel ram would fix it.
  4. DDDenny
    And not a TR-1 either!
