Hot Rods Lets Hear it for the Odd Rods!
Discussion in 'The Hokey Ass Message Board' started by Jive-Bomber, Nov 14, 2024.
  1. Jive-Bomber
    Jive-Bomber
    MODERATOR
    Jive-Bomber submitted a new blog post:
  2. [​IMG]
    Big, handsome cars. It takes vision to see a hot rod in this. Very cool.
  3. papa's 39 koop
    papa's 39 koop
    20211225_164916.jpg 20211225_164839.jpg Here's a 29 coupe for sale .Been sitting for at least 4 yrs at a antique shop in Independence,Mo. Located off 23rd st and N.River. just sitting there 20211225_164916.jpg 20211225_164839.jpg 20211225_164916.jpg 20211225_164839.jpg 20211225_164839.jpg
  4. alchemy
    alchemy
    I’m working on a touring project sitting on a ‘30 Whippet frame, and titled as such. Will have some more familiar sheetmetal replacing the missing fordor body, but still a Whippet grille. Powered with a Ford A motor.
  5. papa's 39 koop
    papa's 39 koop
  6. papa's 39 koop
    papa's 39 koop
    Sorry for the duplicate pics guys..
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Just tap the refresh button when ya don't see your post.:)
  8. autobilly
    autobilly
  9. DDDenny
    Gasser 57, hfh, twenty8 and 10 others like this.
  10. You can click the EDIT button at the lower left side of your previous posts. From there you can select and remove the duplicate image links and save the others. You can also click on the DELETE button to remove your entire post, after a short explanation why.
    The EDIT and DELETE functions are accessible only to you on your own posts.
  11. Jive-Bomber
    Jive-Bomber
    MODERATOR
    I've pontificated before that Henry Ford's frugalness led to '28 - '32 Fords being the dominate hot rods.
    Ford was the only major car company to still use transverse leaf spring front suspension throughout the 1930s (and all the way up to 1948).
    All the other cars had parallel leaves which made two big horns stick out forward of the grille shell. A Ford was easier to lower in the front, and looked even prettier with the fenders removed.
  12.
    Outback and jet996 like this.
  13. Bandit Billy
    Bandit Billy
  14. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
    That turned out weird ^^
  15. Okay, A better photo of it and a little more current. Still under re-construction.
    hfh, Outback, 31 B'ville and 4 others like this.
  16. Bdamfino
    Bdamfino
    from Hamlet, NC
    Tom Senter did that piece in RnC, called "Hairflow", about Rodding DeSoto Airflow's, with a artist rendering that MATCHED a Airflow featured in a late '70's era issue of Hot Rod! Blown and flamed! Thanks to the Larry Wood Nash, I've got a major soft spot for resto rods, but any and all Un-Fords are cool, in any style.
    Outback and Ragged Edge like this.
  17. WC145
    WC145
    from Maine
    My friend's 1920 Hudson
    hfh and jet996 like this.
  18. jet996
    jet996
    from WY
    IMG_4336.jpeg 1927 Chandler -IIRC it had a 389 Poncho in it.
    Outback and Rawrench like this.
  19. Outback
    Outback
    from NE Vic
    Australia got quite a few Dodge Hot Rods in the early days
  20. twenty8
    twenty8
    1931 Essex Super Six
    1928 Buick Coupe
    1924 Hudson 5 Passenger Coach
  21. You don't have to explain why you delete something. It's not like someone's going to read those messages.
  22. 41 GMC K-18
    41 GMC K-18
    I have one of those Durant Radiator shells, I bought it at the Portland swap-meet years ago, not knowing what it was. I may have to find the "D" that goes with it as well.
    Gasser 57 and jet996 like this.
  23. jnaki
    jnaki
    Hello,
    In 1959, I took this short film of an unusual Altered Coupe. It was not a Ford or Chevy, so the next step in selecting the model and year was going to the standard, #3 car manufacturer, Chrysler Corp. The 32 Dodge has rear opening doors. The 32 Plymouth has front opening doors as in the film. The rear windows are narrower than the Model A or 32 Ford 5 window versions. So, the closest identification resorts back to a 1932.
    Jnaki
    If you have a 31 or 32 Plymouth fender-less coupe, lets see some side photos to compare in real life photos. The small windows and front opening doors would be the closest to the Altered Coupe photo from 1959 at Lion’s Dragstrip.
    But, the original altered 5 window coupe did have some unusual never before seen “right hand- steering” via an opening in the right passenger door. So, there are only a few models of front opening door coupes with odd shaped small windows. It was the only one of that particular model of… race car we saw for the years at Lion’s Dragstrip, in those early days… YRMV
    jet996 and 41 GMC K-18 like this.
  24. Saw this in Iowa this past summer and it's early 60's Studebaker powered to boot, double odd ! IMG_2772.JPG IMG_2771.JPG
  25. Most odd rods really don't look good. Some do come out looking pretty nice though. This one looks good, but could really use a taller rear tire.
    41 GMC K-18 likes this.
  26. WGA
    WGA
    Grew up in East Oakland near the Durant factory, which GM took over. My grandfather
    had a Durant into the early 50's,
    https://localwiki.org/oakland/Durant_Motors
    GM also had a plant in Oakland on 73rd ave, which was torn down and moved to
    Fremont, which NUMMI, and now Tesla.
