Technical Building a N/A performance 8BA flatty
Discussion in 'Traditional Hot Rods' started by Jnotsogordo, Nov 10, 2024.
  1. Jnotsogordo
    Jnotsogordo
    If this is the wrong board for this post please direct me to the right one, I feel like this could be a fun topic.
    I have recently come into possession of a solid 1953 8BA flatty I build engines for hotrods and resto mods for a living so I’m not afraid of doing my own work on this thing but it is my first flathead. I’ve been trying to do some research on what can be done to this engine platform to build a little more HP than 95 on a good day. Turns out there’s really not much from this decade on the topic (at least that I can find and yes I used the search function so don’t be an ***hole.)
    I’m thinking bored and stroked: how far can I go overbore, I’m thinking 4.125 stroke?
    Navarro heads with a little work don’t to the chambers, spark plug spacer?
    Flat top or domed pistons?
    Isky racing cam (I mean obviously)
    multi 97’s is super cool so I may look at that set up too
    MSD ignition
    S10 T5 and a ford 8 inch with some tall gears?
    What do you guys think the best combos are, what ideas do you have, what advice do you have? I don’t want the “just build a SBF or BBF instead” answer either
    This engine is either going in a period HotRod like a shoebox or late 20’s early 30’s car or truck or I wanna build a lakester and go for 200mph on the salt flats
    Toms Dogs likes this.
  2. tubman
    tubman
    If you look hard enough on this forum, there is a lot of information about just this subject; it is a little disorganized though. Another good source is "The Ford Barn" forum. Several members there are really on top of the game about this. I would start researching "pop-up" pistons and porting if you really want to get serious about this. The secret is getting them to breath while retaining compression.
    Toms Dogs and Budget36 like this.
  3. NoSurf
    NoSurf
    There is a ton of info on this board and in several books out there.
    As @tubman said, I feel the key is the balance between breathing and compression. When building a good reliable hotrod flatty, doing all the little things really adds up.
    Screenshot_20241111_012600_Amazon Shopping.jpg Screenshot_20241111_012714_Amazon Shopping.jpg
    Spooky, Okie Pete, wheeldog57 and 5 others like this.
  4. 19Fordy
    19Fordy
    Ron's book will prove very helpful. Plus go over to www.fordbarn.com and post your question.
    This has been discussed at length.
    Spooky likes this.
  5. Mr48chev
    The main difference between working on a flathead to get extra performance out of it and working on a later overhead is time . Primarily the valve train is going to take more time to deal with than a sbc or sbf. I think I have five or six flathead books including the Tex Smith - Ron Ceridono one that I have had for probably 40 years. up on the shelf behind me. That one is easy to read and great for a guy building a mild street motor but a couple of he others might be better for a much higher performance level.
    Spooky likes this.
  6. Budget36
    Budget36
    Didn’t (may mess up the screen name) JWL do a book with dyno pulls and what works and what doesn’t?
    hotrodA and alanp561 like this.
  7. tubman
    tubman
    John W. Lawson ("JWL") was the man. He started with a bone stock rebuild (making a little over 80 HP) and went from there.
  8. tubman
    tubman
    A lot of knowledge doesn't just transfer over. Only a flathead requires the block to be modified in regards to the engines breathing ability.
  9. Toms Dogs
    Toms Dogs
    from NJ
    Here's a video for reference ONLY ... (Extreme Mod's) !! :D:rolleyes:
  10. 34Phil
    34Phil
    A good quote when this was 1st posted on the HAMB
  11. Toms Dogs
    Toms Dogs
    from NJ
  12. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    My last flathead(have built over 10 just for myself) was a .080 over bore with stock stroke,mild cam/.350 lift,Edelbrock slingshot with 2 —97’s and a big oversized K & N air filter for a 6 cylinder Porsche(3 cyl on each bank). I spent extra time enlarging the exhaust ports particularly on the ends where they exited the block and purchased a big port intake gasket and enlarged both on the block and on the matching intake. Dyno results showed I did well as had 150 h.p. At the flywheel and my no fendered 32 cabriolet highboy with t 5–5 spd and 3:89 Detroit locker nine inch Ford with coil overs ran 80 mph in the 1/8 at the drags. All this from a 73 year old man and no stroker. Flatheads Forever!!! P. S. I only relieve the intake side on the block approx .080 and don’t touch the exhaust side because it is expelled under pressure;I feel this is better than a “true” full relief. The intake and exhaust valves were both 1.6 and not the standard 1.5. (ATTACH=full]6237700[/ATTACH] IMG_2200.jpeg IMG_1915.jpeg IMG_1743.jpeg IMG_1621.jpeg IMG_0723.jpeg IMG_0649.jpeg
  13. Talk to Vern Tardell and get his flathead book.
    Spooky and Jnotsogordo like this.
  14. Bandit Billy
    Bandit Billy
    Flatheads need superchargers like a Jew needs a yamaka. I'm not talking about Frenzels or McCullochs, Either the big ScOT or 471. Oh, and buy the book from Joe Abbin and follow it like the Torah. He used the little Holley/Weiand induction blower and still made north of 300 HP. Oy vey, and loosen the purse strings, this is going to get expensive. Shalom!
    Spooky, rmcroadster, BJR and 6 others like this.
  15. Jeff34
    Jeff34
    Vern is currently building my '51 Merc 8BA. 4" stroke. .125 over, ported and polished. Balanced. Chevy SS valves, Edelbrock heads, Eddie Meyer intake, 2X 97's. Isky 400 Jr. Mallory dual point dist. He's not planning to dyno the engine when he's done, but he thinks it will be good for ~150hp. I don't plan to dyno it either, but I can give you my **** dyno review when I've got it going.
    Spooky, GordonC, Jnotsogordo and 3 others like this.
  16. Bandit Billy
    Bandit Billy
    That sounds like very realistic expectations if not a bit conservative. Strap that thing in a frame, wheel it down to the dyne, put er across the rollers. But take my advice, go for a coffee and a slice of Jameson while they beat on it. I couldn't watch.
    Inquiring minds want to know. :cool:
  17. RodStRace
    RodStRace
    Sorry, gotta be the a hole. IF you work on engine machining for a living, you would know that you sonic check the block you have to see what's possible. You can have any piston you want custom made, but if this isn't in the plans, you check what's available. Those are the limitations.
    The parts, machining and care taken for a street driven car is going to be a whole different game compared to a top speed engine. This sounds like dreaming. It's okay to dream, just don't yank our chains.
  18. mkubacak
    mkubacak
    The first time I read this I interpreted it as "a Jew needs a Yamaha". In my mind I saw a Hasidic Jew on a crotch rocket.
    chlsnk, Spooky, Just Gary and 3 others like this.
  19. Bandit Billy
    Bandit Billy
    It makes me want to build a full face with peyotes glued to it.
    Spooky, GordonC and mkubacak like this.
  20. ronnieroadster
    ronnieroadster
    Some interesting input from the HAMB members. Being one guy who has actually accomplished a bit with some flatheads all of which have been machined and built by my son and I. There's a lot that's possible to making good power without adding a blower. Our experimenting at Speedweek 2024 has shown what's possible when rookie driver Carley Moody set a record doing such a thing at just under 160 MPH with the outside air temperature over 100 degrees and the density al***ude almost 8000 feet. To get the required speed needed to run fast you need to figure out how to get the engine to pull RPM. Most flatheads running on the salt have a limit to what they pull for RPM. If your able to get a combination that pulls at least 5500 RPM at the third mile with at least 160 MPH speed your now getting someplace. Very few Ford flathead V-8s can do this finding someone able to build an engine for the street and possibly for a 200 MPH lakester is a very difficult task to find and unfortunately will be very expensive.
    Now if a blower is added then 200 is possible but to do it you need to have an engine that will survive for four or more miles each p*** turning 6500 RPM. Example at Speedweek 2024 mile five exit speed was 221 MPH our little stock block Ford flathead ran a total 34 miles this year setting 3 records with 25 of those miles all over 200 MPH. The engine survived to run again. It can be done but it takes many months of work and years of dedication.
    Ronnieroadster
  21. gary macdonald
    gary macdonald
    2-3 deuces look good but for reliability and horse power, a single four barrel is my favorite go to .
    Get some good books , build torque .
    ekimneirbo and deucemac like this.
  22. dan c
    dan c
    IMO, a cam is the biggest "seat of the pants" improvement you can make. just don't get carried away. if you're looking at a daily driver, a max1 should be plenty. hotter ones will run great at high speeds, but are gutless around town.
    ekimneirbo likes this.
  23. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Middle of the road build for a good street pounder.
    4" Merc Crank is a must.
    Isky 1007b grind, its a 400jr without the issues in the lower midrange where the torque is dead.
    Johnson adjustable lifters
    Relieved block from valves to cylinder
    Flat top pistons .125 over bore.
    Minor port work, mainly exhaust and gasket match.
    9" Clutch with larger springs, cut down flywheel for less weight to spin.
    Do not run a Max1 cam, they are a waste of money if you want it to sound like it has any balls at all.
    This is my 59ab stock stroke with a 1007b cam. Straight piped. With the exhaust its even better.
    https://youtube.com/shorts/uuNMTibl_ss?si=AZCvq2jNNcsoK_-O
    Spooky, Foot, dan c and 6 others like this.
  24. Jnotsogordo
    Jnotsogordo
    I’m not a machinist, I build street performance LS/LT’s for resto mod style stuff I understand porting and polishing and a good valve job but a flathead of any kind is a different beast from a modern LS/LT platform engine
  25. Jnotsogordo
    Jnotsogordo
    This helps a lot! It’s an either or kind of thing I’m not trying to get the best of both it will be one or the other
    how much does gearing and tire size play into getting anywhere close to 200 on the salt NA or boosted
  26. ronnieroadster
    ronnieroadster
    What we do is first determine what mile marker are we trying to get the MPH at. Mile three we run a lower gear miles four and five we run a taller gear the idea is to reach the highest RPM at the mile marker. We have three different tire diameters available this along with the gear will be the final detail to get the speed needed as long as everything is working correctly. At Bonneville there's a number of steps needed before you can run beyond mile three. The most important being a speed of 175 or higher at the 2-1/4 mile mark on the short co**** which is timed to mile three. If your able to exceed this speed at that point then you are now allowed to run on the long co**** where you can now run up to five miles.
    Ronnieroadster
  27. Since this is your first flathead, I highly recommend building a healthy street engine . . . it will teach you a lot about the whole process, ***ociated work, costs, time, etc..
    Having a blown flathead is a whole heck of a lot of fun, but obviously a lot more money (just add $6K to the build).
    In the end, you really need to decide the budget you want to work within as just about anybody who starts building these things figures out (the hard way) it takes 3x the money and 3x the time they imagined at the front end.
    Also, how many "go fast goodies" are a must on your end? Intake, cam heads, ignition, induction, etc, etc, etc..
    Once we know more about the $$$ you want to invest and your expectations and direction, then it will be easier for some of us old flathead dogs to point you in the right direction. Also, the decision to be NA or blown is a very important one on the front end.
    Best of luck . . . get back to us with some more info . . . and you'll get a lot more feedback.
    B&S
    woodz and stubbsrodandcustom like this.
  28. jcb50
    jcb50
    My 39 has an 8BA, 1/8 over bore, 4 in crank, 1.6 SS valves cam, Chev dissie, with 2 97's on a Eddie Meyer manifold made 209HP with 299 ft lbs. Now has a 470 cfm 4 barrel for simplicity. Have driven over 10k miles, great package.
    Bandit Billy and Jeff34 like this.
  29. Jeff34
    Jeff34
    Dayum! What cam? My build is almost the same and we’re estimating 150-160hp. Does the 4 bbl help?
  30. Bandit Billy
    Bandit Billy
    Post up a pic of your 4 bbl flattie.
