Dan Glover mid-engine gold 57 chevy from Yucaipa California
Discussion in 'The Hokey Ass Message Board' started by chevrolet150, Aug 7, 2009.
  1. snoc653
    snoc653
    from Iowa
    If the car was sold out of state the vin might still be in the system. Just because Cali doesn’t keep them doesn’t mean everyone dumped the smog exempt cars. Just a thought.
    Kelly Burns likes this.
  2. rusty valley
    rusty valley
    Most states dump the records after the car has not had new tags purchased for a period of time. My state, Mn, its 7 years. It used to be if you had an old paper registration , what you get when you buy plates, that was enough to get new ***le no matter how old if its in your name. Now, thats no good and they consider it no record after 7 years period. So, Dan's car records would depend on what state it went to sleep in
  3. Dan Glover
    Dan Glover
    The problem is no one has the VIN.
    The car went from California to Wisconsin, then to Indiana, and who knows where
  4. Arnie53933
    Arnie53933
    Maybe show up in 2025!!
    SS327 and Kelly Burns like this.
  5. Dan Glover
    Dan Glover
    :rolleyes:
    SS327, 427 sleeper and 51 mercules like this.
  6. seb fontana
    seb fontana
    from ct
  7. MrGasser
    MrGasser
    from DETROIT
  8. porkshop
    porkshop
    from Clovis Ca
  9. porkshop
    porkshop
    from Clovis Ca
  10. Dan Glover
    Dan Glover
    The web page link would be helpful
  11. porkshop
    porkshop
    from Clovis Ca
    Dan @Keyz28 would have to do that. He posted it. I just wanted to be sure you saw it. Shure looks close to the red car it became.....
  12. guthriesmith
    guthriesmith
    porkshop likes this.
  13. Keyz28
    Keyz28
  14. Keyz28
    Keyz28
    Also says its a narrowed Pontiac rear which may be another giveaway.
  15. Dan Glover
    Dan Glover
    I don’t have FB so I used my wife’s . Still can’t see anything except the black 55
  16. Dan Glover
    Dan Glover
    Looking at the red ‘57 closely I believe I see A arms on the front. This would indicate this is the wrong car. Mine didn’t even have any way to mount A arms
  17. Dan Glover
    Dan Glover
    Also this red ‘57 has a stock dash. Mine was removed.
  18. Keyz28
    Keyz28
    I know one of the easiest cars to pull off the frame and maybe due to common rust the most taken off are tri fives. Dashes are an easy fix also. But i figured as the builder you may recognize some personal mods to the hull.
  19. Dan Glover
    Dan Glover
    When I sold the car there was no hint of rust, but many years have past. If T has photos of the rear end that will revel a lot.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    Here is a pic that Dan posted on page 3 of the rear axle. it looks now though that the latest red car has a narrowed rear end and has wheel tubs.... may not be many fingerprints left after 50 years. If it is the car there should be holes in the rear floor pans where the seats were mounted and evidence of a lot of floor repair where the original setback engine sat, and evidence that the dash has been replaced as these were originally spot welded, it would be tough to duplicate that. Has anyone tried to contact the seller and ask these questions??
    LOST ANGEL, porkshop and Kelly Burns like this.
  21. Keyz28
    Keyz28
    Thats a Pontiac rear axle. I live about 125 south of Stl and about halfway to Stl is the start of the horrible rust belt. Tri fives suffer badly even where I am.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    I live in the heart of the rust belt. Surely a "special" car like that would have been stored winters....
    porkshop and seb fontana like this.
  23. Stan Back
    Stan Back
    Good ol' Stl.
    Love Seattle,
    oh, St Louis,
    er, Salt Lake,
    Stockholm? -- never mind.
    oldsmobum, flatheadpete and porkshop like this.
  24. SS327
    SS327
    Dan, does the cowl and firewall look right? Frames are easily changed on these cars these days. Cage look close?
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    Dan's car did not have a cage
    porkshop and SS327 like this.
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    Can someone that has access to the ad make contact with the seller and get a phone number so Dan can call and ask questions about the car to figure out if it is his old car????
  27. Dan Glover
    Dan Glover
    I’m sure most of you notice that the car shown is a BelAir and not a 210. Yes you can add BelAir trim to any ‘57 but most only add the billboard and not all the trim. This red car is full dress BelAir
    lurker mick and porkshop like this.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The belt line trim is not Bel Air. As well no upper side gl*** trim. IMG_3614.jpeg
  29. SS327
    SS327
    Does the cowl hole and firewall tell the tale? Does it look right?
  30. Dan Glover
    Dan Glover
    The cowl does not look correct. 210’s never had belt line trim that I’m aware of.
