Technical Ford 32 frame and x member
Discussion in 'Traditional Hot Rods' started by italianhotrodder, Nov 21, 2024.
  1. italianhotrodder
    italianhotrodder
    from sweden
    Hi guys
    I have a ford 32 handmade frame with a 1934 built x-member, where i can find reference where to mount the brake/clutch pedal?
    I have 1939 pedal set but no. Mounting holes on the cross member , planning to mount a 29 body on it
    Happydaze and Johnny Gee like this.
  2. alchemy
    alchemy
    That depends on where your firewall is, and the seat, the steering wheel, and transmission. Have you even mounted the body yet?
  3. italianhotrodder
    italianhotrodder
    from sweden
    I don't have the body, this is why i was looking for kind of blue print for the pedal position
  4. The37Kid
    The37Kid
    Will you be using a Flathead and '39 transmission?
  5. italianhotrodder
    italianhotrodder
    from sweden
    Yes correct, i hope a 8BA
  6. alchemy
    alchemy
    All the things I mentioned are variable and moveable depending on engine and the size of the driver. Would be futile to mount the pedals without the rest of the information.
    lothiandon1940 and Johnny Gee like this.
  7. continentaljohn
    continentaljohn
    As said it all depends on body position. I recommend at least get a cowl so you can position the pedals in the floorboard
    Just Gary likes this.
  8. italianhotrodder
    italianhotrodder
    from sweden
    Thanks
  9. italianhotrodder
    italianhotrodder
    from sweden
    Thanks a lot
    continentaljohn likes this.
  10. Hitchhiker
    Hitchhiker
    Never mock up major parts without all the major parts. That is building a hot rod 101
  11. DDDenny
    My mantra is "don't get ahead of yourself", it doesn't mean I'm always successful though!
    YRMV
    Hitchhiker, GordonC and alchemy like this.
  12. You might want to post your question on Fordbarn (https://www.fordbarn.com/forum/forumdisplay.php?f=4) and the Early Ford V8 (https://www.earlyfordv8.org/forum/viewtopics.cfm?Forum=18) sites. Ask "Does anybody make (or have a design for) a bracket to mount a hydraulic brake master cylinder in a 1934 Ford? Since these are sites oriented towards restorers LEAVE OUT THE REST OF THE DETAILS. They do periodically cover hydraulic brake conversions as they are a safety issue. You might want to contact Richard Lacy at earlyv8@aol.com (mail), earlyv8garage.net (web site) to see if he has anything. I have hydraulic brakes in my AVATAR but it is entirely different animal (K member). If you get lucky the stock brake location may be close to what you need since whoever installed it would want the engine in the same location.
    Charlie Stephens
