Projects I'm all in...My '38 Chevy PU Build Thread
Discussion in 'The Hokey Ass Message Board' started by pila38, Aug 2, 2013.
  1. pila38
    pila38
    Mounted the regulator and fuel pressure isolator (had to make a quick bracket for it). Ran most of the fuel lines up top, but need a fitting for the isolator hose.
  2. pila38
    pila38
    Now I’m working on modernizing my old Sun tach parts. Using TechnoVersions TachMatch inside the EB9A box. It will allow the Flamethrower, which needs a 4 cylinder tach reading, to send the proper signal to the Sun 10K tach. Just need to solder the connections and ****on it back up. IMG_5423.jpeg IMG_5425.jpeg IMG_5422.jpeg IMG_5424.jpeg IMG_5440.jpeg IMG_5442.jpeg IMG_5441.jpeg IMG_5443.jpeg
    Okie Pete, neilswheels, TFoch and 3 others like this.
  3. pila38
    pila38
    Working on gauge placement. IMG_5463.jpeg IMG_5464.jpeg IMG_5465.jpeg IMG_5466.jpeg IMG_5467.jpeg
    Chucky, Okie Pete, swade41 and 3 others like this.
  4. TFoch
    TFoch
    Looks great!
    pila38 likes this.
  5. neilswheels
    neilswheels
    from England
    Thats a cool idea
    pila38 likes this.
  6. pila38
    pila38
    Thanks man! Can’t take credit for it though, got the idea right from TechnoVersions website.
  7. pila38
    pila38
    Today was my birthday, and it was awesome. I took the day off just to work in the garage. Got some stuff done, and the engine guy called and told me everything is ready to go! To top it all off, my daughter also came out and worked with me. She actually welded up the dash panel. Some pics from today (put the cab back on the frame last weekend):
    IMG_5474.jpeg IMG_5490.jpeg IMG_5489.jpeg IMG_5517.jpeg IMG_5518.jpeg IMG_5519.jpeg IMG_5520.jpeg IMG_5522.jpeg IMG_5523.jpeg IMG_5521.jpeg IMG_5524.jpeg
    Chucky, tb33anda3rd, swade41 and 3 others like this.
  8. pila38
    pila38
    For a full range of stupidity, check out my thread “oil galley plug conundrum”. I’m forgetting it ever happened and moving on. Cleaned the block last night…the cylinders came out squeaky clean, but I think the block needs more, so after finally getting the last plug out, I’ll do it again tonight.
    And while working on removing that pesky galley plug today…I took a few breaks to part putting some paint on the short block parts. The pics don’t really show the color, but it is Caterpillar yellow. Backstory…I’m a big fan of semi trucks having grown up in them and really wanted to pay some homage to that interest. I originally wanted to paint the engine Detroit Diesel Alpine Green, but couldn’t bring myself to do it. Sometime back in the 90’s, my father started painting all the engines he built yellow. It’s kind of a family tradition, so the engine had to be yellow. So putting those two together, I arrived a Cat yellow. I really like it. Can’t wait to paint the interior the color of B model Mack interior!
  9. pila38
    pila38
    Block is cleaned and painted. Ready to ***emble.
    IMG_0021.jpeg IMG_0022.jpeg IMG_0023.jpeg IMG_0024.jpeg IMG_0025.jpeg IMG_0026.jpeg
    bchctybob, swade41, Chucky and 3 others like this.
  10. pila38
    pila38
    Been doing pre***embly and have the bottom end in for good. Ran into a few problems. My original cam ****on was too short for the timing cover I have. Ordered the BBC nylon ****on, waited for it to arrive, fit it, and got the cam all installed and good to go. Put the finned moon timing cover on and got that all ****oned up. Went to install the dampener and it hits the timing cover WAAAYYY before it’s seated. Turns out the moon cover with the removable cam plate is just way too thick. ****s. Bought the Cloyes cover with built in cam ****on which means everything has to come back apart. Cover showed up today, hope to have short block complete by tomorrow night.
    Pics are after I removed the cam plate. It still was not able to fully seat, but was very close.
    bchctybob, loudbang and nunattax like this.
  11. pila38
    pila38
    Some more ***embly pics
    bchctybob, swade41, loudbang and 3 others like this.
  12. nunattax
    nunattax
    WISECO PISTONS !whats the compression ratio with these slugs eric
    pila38 likes this.
  13. pila38
    pila38
    Compression ratio is a healthy 10.9:1. Should be fun.
    swade41, SS327 and nunattax like this.
  14. pila38
    pila38
    Got the timing cover issue fixed. Moon cover was just way too thick in so many ways. Got the short block wrapped up and will have the heads on tonight.
    IMG_0116.jpeg IMG_0117.jpeg IMG_0118.jpeg IMG_0119.jpeg IMG_0123.jpeg IMG_0124.jpeg IMG_0125.jpeg
    bchctybob, nunattax, swade41 and 4 others like this.
  15. fastcar1953
    fastcar1953
    What size cheaters on the back?
  16. pila38
    pila38
    29” x 9” Towel City Cheaters
  17. fastcar1953
    fastcar1953
    Thanks , looks good.
    pila38 likes this.
  18. pila38
    pila38
    Intake not installed yet, but couldn’t resist dressing it up tonight.
  19. patsurf
    patsurf
    pila38 likes this.
  20. pila38
    pila38
    I dig that. My striping skills are awful though.
  21. patsurf
    patsurf
    have a lathe/ drillpress around?
  22. pila38
    pila38
    I do. I’ll have to monkey around with it. Need this thing to run first though!
    nunattax likes this.
  23. nunattax
    nunattax
    exactly running and driving first, cosmetics later.
    pila38 likes this.
  24. pila38
    pila38
    Was about to stab the engine in and found a slight hiccup. In all my measuring for the engine (years ago), I never accounted for the bottom pulley. Duh. Welp, I had to slice up the front crossmember and because, why not, we’ll have to redo the front brake lines too. Now, I just need to weld the boxing gussets in and it will be all set for the engine to go in. Although, I am now thinking I should set up the bellhousing, clutch and trans and then put it in.
    IMG_0174.jpeg IMG_0175.jpeg IMG_0176.jpeg IMG_0177.jpeg IMG_0178.jpeg IMG_0179.jpeg IMG_0180.jpeg IMG_0181.jpeg IMG_0182.jpeg
  25. pila38
    pila38
  26. pila38
    pila38
    Got her welded up and used the grinder to make look like I’m a good welder. Painted it up, now she’s good to go. Waiting on some bits to show up to get the clutch and bell on before the engine goes in for good.
    IMG_0202.jpeg IMG_0203.jpeg IMG_0204.jpeg IMG_0205.jpeg IMG_0206.jpeg IMG_0207.jpeg
  27. pila38
    pila38
    More progress last night. Replaced the bellhousing dowels with extra long ones. I know I may need offset ones later, but I can’t get everything together with standard dowels, so I just went ahead and put these in, it’s not that hard.
    Then I got the roller skates bolted up and dropped the engine onto the floor so I can work on the backend. Flywheel went on and was torqued down, which is great, until I realized…
    So, back off the flywheel came. I then proceeded to put everything on in the correct order and got the bell snugged up. At that point I was wiped out, so I’ll index it next time I’m in the garage.
    bchctybob, cactus1, loudbang and 2 others like this.
  28. pila38
    pila38
    Dialed in and no need for offsets. Biggest runout was .0035. Good job Lakewood. IMG_0224.jpeg
    bchctybob, swade41, 4 pedals and 2 others like this.
  29. pila38
    pila38
    Forgot to post this in here last weekend. Finished up the clutch install. Went pretty smoothly:
    Got the bell finalized as well. Had to drill holes in the mid plate to get the blow proof plate bolted on:
    Then it got saucy, and I stabbed the engine in:
    Also, made some adjustments to the limiters and got those bolted on as well. Didn’t take pics of them. Plan coming up is to get the intake finalized, distributor installed, fuel lines run, alternator bolted up, and radiator in. Then cobble some wiring together and hopefully light this thing off.
    bchctybob, lumpy 63, 4 pedals and 7 others like this.
  30. pila38
    pila38
    And as it turns out, probably didn’t need to cut the crossmember. Front pulley would have sat about 1/2”-3/4” above it. Probably would have been too close for comfort, so I’m taking the mindset that I’m better off having done it.o_O
