Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. TERPU
    TERPU
    Unacceptable
    Forge ahead you're too close now.
    -That Pain in the *** from Morro Bay :)
  2. Anderson
    Anderson
    Roadsters are always a priority.
  3. Hitchhiker
    Hitchhiker
    After a big set back like a blown engine. Sometimes it's best to change gears. Do a mock up on another car. Change something you've been meaning to change in your "finished car" Or whatever it is to change your focus....
    instead of lighting the current car on fire. :eek:
  4. -Brent-
    -Brent-
    Or... put a 265/283 in it and spend the savings on chrome!
    (I am full of good advice.)
    31chevymike, NealinCA, brEad and 13 others like this.
  5. alchemy
    alchemy
    You’re full of something…..
  6. nrgwizard
    nrgwizard
    from Minn. uSA
    Or maybe put in a Studebaker v8. If it was good enough for Dean Moon & his '34, & Eric Rickmann(sp?) early corvette, + it came out in '51, well... :D .
    Marcus...
    31chevymike, porkshop and Outback like this.
  7. Outback
    Outback
    from NE Vic, Oz
    At very least please start a build thread for the rowdster!
    31chevymike and porkshop like this.
  8. NealinCA
    NealinCA
    I had my annual Neal's Hot Rod Party and reliability run on Saturday. This was the 23rd annual. I keep it small, as it had grown out of control for a couple of years, so now it's just the 19 of us.
    20241130_085503.jpg 20241130_100054.jpg 20241130_120355.jpg 20241130_143906.jpg 20241130_144047.jpg 20241130_144214.jpg 20241130_144557.jpg 20241130_162216.jpg 20241130_144622.jpg
  9. Fogger
    Fogger
    Neal, The louvers look great on the hood sides. Time to blow it apart and make it purple. Enjoyed following the built. Ron
  10. krylon32
    krylon32
    from Nebraska
    Looks like a good time. All the kool kids were there.
  11. NealinCA
    NealinCA
    I did manage to squeeze in a couple of things on the 5W project.
    I finally got the courage to redrill the holes in the cowl that had been leaded shut.
    20241201_152858.jpg 20241201_154045.jpg 20241201_155125.jpg 20241201_155118.jpg
    I also cut up some bent original 32 bumper irons to make spreader bar caps similar to the ones on the rear. These will get sent off to be plated.
    31chevymike, brEad, HEMI32 and 20 others like this.
  12. dirt car
    dirt car
    from nebraska
    I've seen the cowl mount antenna's before & have a 32-cowl section with one still attached somewhere within the confines of my barn, I must admit with a bit of ingenuity it could be incorporated through the upper & lower hinge pins & save the sheet metal.
    porkshop likes this.
  13. pprather
    pprather
    Mounting the antenna to the cowl side is authentic traditional.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The run looked like a great time. I'm glad you mounted the antenna—it was meant to be there (again).
  15. NealinCA
    NealinCA
    Right? Sometimes these old cars tell you what they need.
    And you'll have to make the trip down in your roadster next year!
  16. NealinCA
    NealinCA
    Did some repairs on the firewall feet yesterday. Welding up the all too common cracks in the bases
    Prepping these to send out for chrome
    Also organized my 40 years of mismatched ratchets and extensions using some magnetic organizers I impulse bought off of IG. Not perfect, but it's better than all thrown in the drawer...
  17. Outback
    Outback
    from NE Vic, Oz
    Everything has a place & everything in it's place!
    Glad to see forward movement again. Chrome Cowl feet wow! :eek: This is & will be an exceptional build when finished:cool:
    31chevymike likes this.
  18. NealinCA
    NealinCA
    Found one more crack that required a patch repair. The hole was too close to the edge, so I made the patch curve out slightly
    20241208_114028.jpg 20241208_130629.jpg 20241208_131832.jpg 20241208_141737.jpg
  19. nrgwizard
    nrgwizard
    from Minn. uSA
    Wow, nice...
    Marcus...
  20. atch
    atch
    Neal,
    There are several thousand of us who don't comment on builds very often but say WOW to ourselves every time you post an update.
  21. -Brent-
    -Brent-
    I respect and admire taking on the minute details.
    31chevymike and Algoma56 like this.
  22. NealinCA
    NealinCA
    Feet have been test fit back on the firewall. I found some hex head 12-24 stainless screws. The head is just 5/16" hex, so I plan to polish them and use for final ***embly.
    The feet are now ready to send off for chrome and then firewall can be blasted and prepped for paint.
    Onward with the minutia...
  23. Excellent progress!
    31chevymike, porkshop and Uncle Ronn like this.
  24. hotrodA
    hotrodA
    Nice save in the firewall feet.
    Here’s a fastener alternative I used on my old beater, FWIW.
    Polished Stainless rivet head bolts with lock nuts.
    From ThirdGen Automotive if I remember right.
    31chevymike, HEMI32, 63fdsnr and 12 others like this.
  25. NealinCA
    NealinCA
    I didn't like how low the car sat in the back, so I added one more leaf
    I think this has a more authentic 50's look with it showing more blackwall and the whitewall more concentric with the fender radius.
    Screenshot_20221121_100439_Instagram.jpg 298699712_10228242825999694_3670719682508035451_n.jpg
  26. NealinCA
    NealinCA
    Thanks for the heads up. I just ordered some.
    31chevymike, hotrodA, Tim and 3 others like this.
  27. Outback
    Outback
    from NE Vic, Oz
    Super low looks rad, but the new height looks less cartoony,
    Your coupe @NealinCA sits so nice!
  28. -Brent-
    -Brent-
    I dig both stances but a little rake is a great choice.
  29. NealinCA
    NealinCA
    I know the super low stance has some at***ude, but agree that it is also kind of cartoony. It was never what I was going for with this build. I always pictured a more "****y" 50's stance. I really want this car to look like it came out of the "little pages". I will keep playing with it until it's right...
  30. alchemy
    alchemy
    How does the added leaf ride? When I was ***embling my sedan I removed one leaf from the original spring to soften the ride (I had never driven it before). After a few years I was tired of bottoming out in the back and pulled the spring. I dearched the main leaf and a few more above it, and added the removed leaf back in as well. It rides perfectly now, and sits the same as it did when I first ***embled it. Henry’s guys must have known what they were doing.
