History A Roadster at Bonneville
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Nov 22, 2024.
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    J.Ukrop submitted a new blog post:
    Sharpone, tractorguy, GordonC and 3 others like this.
  2. Tim
    Tim
    from KCMO
    No clue, but it is a rad hotrod!
  3. alchemy
    alchemy
    Something funky going on with the cowl top. Looks kinda like there was a V windshield that was removed for the race day. The front shock mounts should be easy to recognize in other photos too.
  4. Tim
    Tim
    from KCMO
    Yeah the cowl has been shaved down good catch. With those shock mounts I’m curious if this wasn’t also regularly a fendered car.
    edit: it actually looks like a chromed fender brace on the p***enger side is visible.
  5. BigJoeArt
    BigJoeArt
    I don't think those are fender mounts, they look like headlight mounts to me.
    It is remarkably similar to the norm car, but I agree its not the same.
  6. Tim
    Tim
    from KCMO
    Yeah could be. They do stop a little shorter than a stock fender brace would but I have seen them cut short when they car is low and the tire starts hitting them.
    what a good mystery car/ photo to dig into :)
  7. brett4christ
    brett4christ
    Could the builder have used the original fender braces as upper shock mounts? And cut off the top portion that would be useless on a fenderless car?
    I only say this as I had once wondered if they were strong enough to do so on my full-fendered sedan....
    Also, could it have started life as a sport coupe? Cowl looks odd for a roadster.
  8. BigJoeArt
    BigJoeArt
    It looked like to us that they were using the cl***ic F1 mounts for uppers in the front, but the headlight mounts could be modified fender braces I guess.
    I think the doors and how they roll into the cowl would rule out the sport coupe theory.
    It was a common mod back then to weld the dash rail and cowl/under windshield piece together into one smooth part.
    chryslerfan55 and Tim like this.
  9. Tim
    Tim
    from KCMO
    And the posts being gone and the rail missing is how you’d do a Duvall Type windshield. There’s a spot on the cowl top that could be a little bolt for the windscreen. There’s gotta be more pictures out there.
  10. Tim
    Tim
    from KCMO
    @brett4christ ive seen even fendered cars with the upper shock mounts located in the fender brace. Even with the headlight bar off like @Rand Man ’a coupe
  11. brett4christ
    brett4christ
    Does that approach work well? If so, I may go that route instead of fabbing top mounts.
  12. Tim
    Tim
    from KCMO
    He’s been driving it for a decade and haven't heard him complain about it. I plan on using the 28-9 forged front fender braces for my shock mounts on my A but I also plan to keep my headlight bar in tack in effect bracing them against each other.
  13. noboD
    noboD
    9 hours for ID, you guys are getting slow. The power of the HAMB.
    J.Ukrop and Outback like this.
  14. :D:D I would have ID'ed sooner but I was asleep, original post was 1:11am I was reading threads with my morning coffee when I posted ;):rolleyes:
  15. This was Semas/Brocchini's effort in 1954
  16. Outback
    Outback
    from NE Vic, Oz
  17. Tim
    Tim
    from KCMO
    Man what a great link/thread! IMG_7188.jpeg the car did have a v shapped windshield, they are head light mounts and it did run fenders at one point! Hot dang!
    RMcCulley, Outback and Jimmy B like this.
  18. 1950, Don Waite roadster photo in background you can see the Brocchini A and Semas '37. along with Justin George tracknose T, and Downey Bros. T
  19. HEMI32
    HEMI32
    Of course my mate @Jimmy B beat me to it! :D
    I read @J.Ukrop 's TJJ Blog this morning and immediately remembered the roadster . . . but was at work and couldn't reply . . . I just got home after a 3 hour commute (Californians don't know how to drive in the rain :mad:) . . . Anyway, here's some pics of (@stillrunners uncle) Lawrence Brocchini's Model A Roadster I found in my archives:
    Under Construction
    At the Dry Lakes
    Heading to the 1950 Bonneville National Speed Trials
    On the Salt at the 1950 B'ville Nats
    Home from the 1950 B'ville Nats
    Lawrence Brocchini's Model A Roadster at Thunderbolts Auto Show - November 1950 (1).jpg
    Lawrence Brocchini's Model A Roadster at Thunderbolts Auto Show - November 1950 (2).jpg
    Thunderbolts Auto Show (aka Sacramento Autorama) - November 1950
  20. It’s on a deuce frame though, right?
  21. sr
    sr
    from Monterey
    Wow thanks for sharing that. Incredible!
