Hot Rods whats this junk called and where do I buy it?
Discussion in 'The Hokey Ass Message Board' started by sawzall, Nov 22, 2024.
  1. sawzall
    sawzall
    this "material" goes in a grove in the body of my 51 ford. metal tabs hold it into the body and then staples attach the windlace to this "JUNK"
    its not wood, its not a plastic
    Its kinda like a fiberous "junk" perhaps one step above hardboard ?
    where do i get this? or where can I get something that I can use in its place?
  2. Most offered these days is rubber. Local upholstery guy makes his out of thin cardboard. He cuts correct width strips and glues them together. Stacks them to thickness desired. Works great for him
  3. Squablow
    Squablow
    It's usually referred to as "tack strip" and I really, really prefer to put rubber tack strip into cars instead of this stuff, the rubber holds a tack or staple so much better, and if some of your foldover tabs are missing, you can drill through the rubber and mount it with aluminum pop rivets instead. Some tack strips I've run into were originally stapled through the sheetmetal to hold it on, that's when the rivets really work nicely.
    EDIT the stuff is considered plastic and not rubber, although it's a soft, black, bendy type of plastic.
  4. Squablow
    Squablow
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Old school hack, fan belt.
    Algoma56, lothiandon1940 and squirrel like this.
  6. If it's the board that goes between the windlace check local upholstery shops. It's the next thinner chipboard than the door panel one. They will sell you a sheet like 2'x3' and you cut the strips and do the rest. The guys sew it into the windlace. I would say it's about two thicknesses of cereal box.
    The alternative is to use wire and weave it into your wind lace and the when you are setting it make sure the rack strip teeth catch the wire.
  7. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  8. RAK
    RAK
    Bob Drake has it in a bunch of different sizes
  9. tubman
    tubman
    For oddball stuff like this, I go to Restoration Specialties and Supply Inc. They have an incredible selection of, well, "junk". They are a source that should be known by anyone contemplating any kind of restoration or refurbishment.
    rockable, chryslerfan55 and 5window like this.
  10. If you can't find the plastic tack strip in the size you need; you can use "vinyl wood" trim boards from a home store and rip them to the desired size on a table saw. Since they are white; I give them a coat of flat black paint just in case an edge or something shows.
    Picture of a strip I cut for my coupe. A couple screws replaced missing bend-over tabs. The material is pretty flexible for curves and a heat gun can help it conform to tighter curves like the strip on my old roadster in the second picture.
    vtx1800 and chryslerfan55 like this.
  11. kb cookout
    kb cookout
    Convertible tack strip ,works well , you can also use plastic body side molding strips , you can cut them to size and put them in a bucket of hot water, to help with bend and curves ,
    And check out rubber base board moldings in the hardware stores, it can be glue together, and laminated to get the thickness you need
    later kb
    Custom - Premium Universal Body Molding for All Vehicles - Easy Install, Black F | eBay
    , Inc. ES210018-PK Universal Fit European Style Matte Black Body Side Molding | eBay
    alanp561 and chryslerfan55 like this.
  12. '29 Gizmo
    '29 Gizmo
    from UK
    Ford used asbestos strips in their folding roofs to tack the fabric to. Could be the same stuff.
    Try burning it, if it won't burn its asbestos!
  13. woodiewagon46
    woodiewagon46
    from New York
    Hello Jeff, Restoration Specialties and Supply, www.restorationspecialties.com 814-467-9842, has it in several different sizes. It's called ''Laminated Waterproof Cardboard Tacking Strip''.
    vtx1800 and '29 Gizmo like this.
  14. 19Fordy
    19Fordy
    It's called "tack strip". You can buy it from Restorationspecialties.com
    Page 117 in their on line catalog.
  15. sawzall
    sawzall
