Technical ford 1940 drums question
Discussion in 'Traditional Hot Rods' started by italianhotrodder, Nov 24, 2024.
  1. italianhotrodder
    italianhotrodder
    from sweden
    scoob_daddy likes this.
  2. chlsnk
    chlsnk
    The looks very much like 48' and up slip on F1 drums.
    italianhotrodder likes this.
  3. alchemy
    alchemy
    Looks like a 40 Ford drum. Won’t fit up to 48 like the seller mistakenly said. I’ve got no idea about the quality though.
  4. How come so much patina on a new reproduction drum? If correct it should fit post war with the correct hub, Ford sold them as an ***embly for 40-48.
    Charlie Stephens
    V8-m and italianhotrodder like this.
  5. V8-m
    V8-m
    from Alaska
    What's the difference? I'm not spe******t.
    Here is my 48 drum. Looks the same?
  6. V8-m
    V8-m
    from Alaska
    It's probably old reproduction part, that's why patina is present. Never seen those drums as reproduction part.
  7. joel
    joel
    The same page on Epay shows Speedway drums for about $90 shipped.
  8. V8-m
    V8-m
    from Alaska
    But doesn't look the same as original if someone wish to keep it looking original.
  9. junkman8888
    junkman8888
    At the bottom of ad it says "old-stock reproduction", perhaps he means old-stock dealer replacement.
  10. rusty valley
    rusty valley
    The guy that wrote that ad is a bit goofy. He calls his drum "one piece", not so, they are cast iron lined steel, and he says the new reproductions are two piece when they are all cast iron one piece that I've seen. It looks like a stock 40 drum to me.
  11. V8-m
    V8-m
    from Alaska
    I think they are full steel drums but maybe I'm wrong. In my opinion there is not enough overall thickness to do it that way.
  12. rusty valley
    rusty valley
    I think pretty much all brake drums except maybe a kids go kart are cast Iron. Not sure if its a heat thing or iron grabs better. I know it cuts like cast iron in my lathe, chips...not curls
  13. I thought I missed that and went back to check. That is not on my ad???
    Charlie Stephens
  14. alchemy
    alchemy
    Yours is also a 40. The drum mounts on the outside of the hub. If it was gonna mount to the inside of the hub it couldn’t have the lip at the center hole.
    ydopen and V8-m like this.
  15. italianhotrodder
    italianhotrodder
    from sweden
    i did a different google search and found out they are old KH reproduction now would like to understand if someone have the old Kelsey Hayes part book to understand for which model are made
    seabeecmc likes this.
  16. 42merc
    42merc
    Two piece drum. 21A part number says '42, fits '40-'42. Looks correct.
  17. RICH B
    RICH B
    That drum would be a replacement for use where the hub is mounted inside the hub.
    Probably a good part if it is a KH replacement drum; likely made in the days before off-shore production.
    Originally '40-'42 like mentioned; but after all these years these parts can be mixed up and you have to see what you have.
    I've found outside flange hubs on earlier cars as well as inside mount hubs on '46-'48 cars.
    Ford only sold hub/drum ***emblies so if you go with replacement drums you will have to deal with properly removing the swedged studs and either getting new studs and having them swedged on ***embly or converting to pressed in serrated studs and letting the drums slip on.
  18. scoob_daddy
    scoob_daddy
    from Georgia
    All I know is that for that price you may as well pick up the boiling bros slip on Lincoln drums, and convert your hubs to slip on configuration with press in studs
