1932 Ford spreader bars
Discussion in 'The Hokey Ass Message Board' started by Ghost of ElMirage, Jan 30, 2013.
  1. Deuce Daddy Don
    Deuce Daddy Don
    Joe Nitti's '32
  2. The37Kid
    The37Kid
    Is wing strut material traditidional? [​IMG]
  3. Beachcomber
    Beachcomber
    from Phoenix,AZ
    I was going to say... nitti!
  4. tommy
    tommy
    I'm with you guys. I remember the year that I we went to the Shades of the Past show. The whole front row of repopped Deuces in the Deuce show area had the same Ved spreader bar with the built in turn signals. I pointed it out to my buddy and we just chuckled.
    Mine is a genuine Henry model along with the tag bracket. Chromed some time in the 50s.
  5. Mpls 40
    Mpls 40
    Bob McGee's is he first "V'd" one I'm aware of.
    The37Kid likes this.
  6. Never2old
    Never2old
    from so cal
    I just figured they all got bent when they towed em home.
  7. Bruce Lancaster
    Bruce Lancaster
    If you are running a fairly original frame, you need the strength of originals with forged ends and heavy tubing. I think all the new ones have the structural value of a K-Mart shower curtain rod, fine with boxed frame and complex crossmember. Until someone backs into your car...well, no problem, deuce grills are common and cheap...
    HemiDeuce and Moriarity like this.
  8. DDDenny
    The new veed ones are too pronounced, whilst the above photos show they were quite subtle to start with.[/QUOTE]
    I feel so deflated but it will make a good wall hanging!
    Yep, you all are right, I too have lost the attraction to my v'd spreader bar, kind of wish it wasn't so obtrusive looking.
    I was fine with it, then I joined the HAMB.
  9. 56don
    56don
    Question: Are original spreader bars the exact same width as the repros? I heard or read somewhere that there was a difference. Don't recall where I got that rumor though.
  10. swifty
    swifty
    After-market ones are slightly longer to suit the after-market frames which don't have the stiffening plates on the inside of the frame rails like an original frame. I had to remove one of the plates from my frame to fit the repro bar on my OG ch***is.
    clem and 56don like this.
  11. koolbeans
    koolbeans
    40 roger on that.......
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  12. el Scotto
    el Scotto
    from Tracy, CA
    I was 33 years old the first time I replied to this thread. Makes me think maybe I should leave some bits of wisdom for future Scott. ;)
    I have three different front bars, one is original, all are slightly different lengths.
    I have three different rear bars, two originals, all are slightly different lengths o_O
    56don likes this.
  13. dann57
    dann57
    from Missouri
    Use stainless and polish
  14. clem
    clem
    Old thread, dragged up, but, for what it’s worth,
    I built my own out of heavy wall tube or steam pipe with 3/8” end brackets, chromed them.
    They double as bumpers, hence the heavy tube.
    Rear one is awfully close to the fuel tank !
  15. mlinton1941
    mlinton1941
    A childs swing set has heavier metal than Speedways bars... I made my own !!
    mad mikey likes this.
  16. mlinton1941
    mlinton1941
    JUNK !
  17. krylon32
    krylon32
    from Nebraska
    The last few years I've used spreader bars on all my customer 32 ch***is from Roadster Supply.
  18. DDDenny
    My Stainless spreader bars are from Deuce Factory (no longer in business), they are hefty.
  19. Grandadeo
    Grandadeo
    I made mine out of ribbed very heavy wall stainless steel tubing, an internal component in a commercial nuclear reactor where I worked. No, it was never irradiated, otherwise I wouldn't need headlights!
    Happydaze and clem like this.
