Hot Rods My new 57 Chevy 210
Discussion in 'The Hokey Ass Message Board' started by Xman, Nov 24, 2024.
  1. Xman
    Xman
    I just bought a very clean 57 210. Its rust free with a fresh black paint job and stock replacement interior. It has a stock 283, powerglide. The previous owner installed 17 and 18-inch mag wheels and tires.
    I will be going with a 327 and muncie 4 speed but first I need these tires and wheels off the car. I will be going with 15 inch wheels but need help with width and back spacing.
    What have you 57 guys run?
    Tow Truck Tom likes this.
  2. Moriarity
    Moriarity
    SUPER MODERATOR
    Not a 57 but a 55 is pretty close. 15x6 with 3 inch backspace and 6.70-15's
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Congratulations.
    :D
    mad mikey, chevy57dude and Xman like this.
  4. wheeldog57
    wheeldog57
  5. Xman
    Xman
    Wheeldog57, could you get a 15X8 in the rear? If so, what back spacing?
  6. Xman
    Xman
    I'm having trouble loading new pictures, 100_1257.JPG 100_1259.JPG so I'll add one of a 57 I had several years ago. This is the look Im going for but with larger rear tires and wheels. I don't remember what these were.
  7. DDDenny
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If I’m being paged about 15 8’s, yes they’ll fit. 4 1/2” back space is the ticket. These only come close in 4 1/4” & 4 3/4” back space. So a 1/4” solid style wheel spacer and the 4 3/4” back space got them in with a 275/60/15. (Note, stock rear end) IMG_3314.jpeg IMG_3315.jpeg
  9. Super/Stock Poncho
    Super/Stock Poncho
    from Missouri
    Fronts - 15x5 wheels on 205/75 tires
    Rears - 15x7 wheels on 235/70 tires.
    Don’t laugh at my low hanging passenger tailpipe. Hanger has been replaced since photo was taken.
  10. wheeldog57
    wheeldog57
    Neat stuff on here. @Xman I had corvette ralleys when I first put the Chevy together but they didn't really fit. Had to pull out the quarter panels to get wheels on and off. Looked cool though. These tri-5s are just like second generation Novas, not a lot of room in the rear.
    15x7s for me
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Those rears scream stock Chevy 15 7’s with 255/70/15’s.
    That’s what’s on the back of the avatar 56. Clearance is great. On and off easy. IMG_3436.jpeg IMG_3437.jpeg
  12. Squablow
    Squablow
    I think I have 7" wide wheels and 225/75's on the back of my '57, and it's already kinda tight. They don't have room for a ton of width, but you can get quite a bit of tire height in there, which is usually my preference anyway. I'm pretty sure you can get an 8" wide wheel in there but it has to have really exact backspacing, the right size tire, and probably air shocks to push the springs down to get them in there, nothing you'd ever want to change on the side of the road.
    Xman and Packrat like this.
  13. 15x7's and I cant remember the backspacing but its like 3ish inches or in that range.
    60411077_3115942911752775_6589998266211893248_o.jpg 60430170_3115942351752831_8250120726615425024_o.jpg
    You can get a 15x8 under the rear of the car, usually have to unhook the shocks and let the rear drop to mount.
  14. brigrat
    brigrat
    from Wa.St.
    If the 283 is a runner & 4 sale I am in the Wenatchee, Wa. area and interested. I also have the makings of a 301-302 if interested....................................
  15. partsdawg
    partsdawg
    from Minnesota
    I rolled the inner lip to gain a little more room on my last '55 to run wider tires.
    Even with that I had to jack the body up and take a shock loose to get enough clearance to get the tire off.
    Your '57 should be good with the advise given above
  16. 55 gasser pickup
    55 gasser pickup
    from utah
    These are 10 inch wide tires on 8 1/2" wheel on my 56.
    Back space is 4 1/2" i beleive.
  17. I ran 15X8 'vette ralleys. They had the same offset [4"] on both front side and back....zero offset. Ran them on the front and back...........Had no rubbing issues I can remember. 57chevy.jpg
    Johnny Gee likes this.
  18. Xman
    Xman
    There is some really good info here and I'm listening. Not sure witch way to go, weighing the options.
    Bigrat, I only drove the car about 30 miles to get it home and it seemed to run fine. When I get the 283 out, you can have it. You know of course, no side motor mounts.
    Squablow likes this.
  19. Tickety Boo
    Tickety Boo
    from Wisconsin
    8" American torque thrust D come in a 4 1/2 in backspace, got to disconnect the shocks to get 8" x 28" towel city slicks under a early Chevelle, Grey spokes would look nice on a black 57 INMHO
    Xman likes this.
  20. CTaulbert
    CTaulbert
    from Detroit
    I'm running magnesium Americans - 15x6" with 2.5" backspacing all around. I rolled the rear lips for extra clearance, and haven't had any contact all around.
    Xman, Motorwrxs, Big Al and 1 other person like this.
  21. I run a 15x7 wheel with 275/60/15's, the backspace is 4 1/8" but needed 3/8" spacers when it had the stock rear. Pinched quarter panel lip required.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Mmm, apples to oranges.
  23. Tickety Boo
    Tickety Boo
    from Wisconsin
    All I'm saying is "diesel fit her" and look good doing it :D
  24. brady1929
    brady1929
    Congrats.
    Xman likes this.
