Projects 4BANGER mild HotRod
Discussion in 'Traditional Hot Rods' started by Deutscher, Nov 12, 2024.
  1. Deutscher
    Deutscher
    from Germany
    Done, the spring is out.
    I had to tweak my spring tensioner a little so that I could turn the nuts,
    the shackles are badly worn,
    that will also be replaced.
  2. Deutscher
    Deutscher
    from Germany
    The 32 axle still needs to be dis***embled and I've started to pull the rim off,
    I think the rim is lost, LOL
    Someone tried to open the wheel nut with a torch, I milled it off and got it off,
    the brake drum is absolutely solid,
    I hope that I can save the spindles and perches, the drums may be lost,
    so I'll probably build the 31 brake,
    I probably won't find a 32 brake in Germany.
    Greetings Harald
  3. cruiserbuddy
    cruiserbuddy
    from Germany
    Welcome from Hameln, the town of the pied piper.
  4. Deutscher
    Deutscher
    from Germany
    Thank you for the welcome, you are not far away.
    Greetings back to beautiful Hameln.
    Harald
    winduptoy and 51 mercules like this.
  5. cruiserbuddy
    cruiserbuddy
    from Germany
    Thanks. Yeah, my ex came from Brunswick…
    51 mercules and Deutscher like this.
  6. cruiserbuddy
    cruiserbuddy
    from Germany
    Cool build!
    Deutscher likes this.
  7. alchemy
    alchemy
    So press some fresh studs in the drum. The 12” brakes from the 32 will be much better than the A’s.
    LCGarage, Baumi, winduptoy and 2 others like this.
  8. Deutscher
    Deutscher
    from Germany
    What a struggle, but the brake drums are now free of their rusted-in shackles.
    The good thing is that I was able to save the spindles.
    Unfortunately, the drums cannot be saved; they are too rusted to be machining the Surface.
    The spring perches are not looking good either.
    The thread on one of them has already gone and I need a replacement.
    The two front brake actuating units are in good condition.
    I have all the important parts to install a 32 axle in the Model A and keep the rod brake.
    Greetings Harald
  9. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Welcome and great looking car! If you stay with the A brakes get the cast iron drums, will stop you much better than the old steel ones.
    Mike
  10. Deutscher
    Deutscher
    from Germany
    The 32' axle has been dis***embled, the spindles are good for further use,
    I pressed the perches out, with heat and a 20t press, it made a good bang, unfortunately the threads have rusted away,
    but otherwise it is amazing that every screw could be turned and left its place, I think the axle has been lying outside for a very long time and there is still so much usable, great.
    Greetings Harald
    OleADTruck, treb11, LCGarage and 7 others like this.
  11. alchemy
    alchemy
    You could sandblast the perches, TIG weld the threads, then cut fresh ones in a lathe.
    Jeff34, catdad49, Okie Pete and 2 others like this.
  12. Deutscher
    Deutscher
    from Germany
    That's a good idea and worth a try.
    I'll have to find someone who has the skills to do it,
    thanks for the tip.
    Regards Harald
    catdad49, winduptoy and Okie Pete like this.
  13. Deutscher
    Deutscher
    from Germany
    Now the frame is stripped and the 31 front axle and brake removed, while the backplate and everything around it is in a clean condition, the drums look like a vinyl record, let's see if they can still be turned out.
    Putting new cast drums on the old hub means a lot of work, milling off the crushed old bolts and pressing them out and and and....
    Just read that the steel drums must not be turned out, if that is true, they will probably be new drums.
    Greetings Harald
  14. Liberty Garage
    Liberty Garage
    Bob Drake has new spring perch bolts. $150.00 US for a set
  15. Deutscher
    Deutscher
    from Germany
    Thanks, I have the perches in my shopping cart at Summit,
    I'm still waiting for inquiries to used parts dealers to see if they'll get back to me and tell me that the parts are available.
    Regards Harald
    Dannerr likes this.
  16. Deutscher
    Deutscher
    from Germany
    The wishbone is off the Model A axle, the spring perches were really resisting,
    I had to drill it out to get it off.
    32' perches have been ordered from Summit,
    I will probably order the brake drums with hub, they are ready to screw on.
    I can't find a workshop that will caulk the wheel bolts for me, or they charge too much.
    Or they don't have a 50t press.
    I was already running around for the Mustang drums back then until an old truck workshop was able to turn them out for me.
    Greetings Harald
    LCGarage, catdad49, Dannerr and 3 others like this.
  17. CSPIDY
    CSPIDY
    Great build
    you have many obstacles
    but
    you seam to be quite the hurdler
    winduptoy and Deutscher like this.
  18. Martinbuilt
    Martinbuilt
    It's true. There have been a few European builds, i'm always impressed with the effort.
    A few years ago, i did some work on a post-war bike. It was a BSA C11, very few made it to the US.
    Just miserable finding parts. It's how i imagine finding model A parts in Germany to be.
  19. burl
    burl
    from Minnesota
    Ive done this it's pretty sketchy as you have to chuck the perch in the 4 jaw chuck and you the center on the tailstock.
    It worked well for fixing bad threads from beating them out of the axle.
    Dannerr, winduptoy and Deutscher like this.
  20. Deutscher
    Deutscher
    from Germany
    Thank you for your support.
    Parts for Model A are almost twice as expensive here and second hand ones are worth their weight in gold. I'm having it sent to my home in a container via a shipper,
    shipping is very expensive,
    so this is about half the price, it just takes a long time, the next container won't be with me until the beginning of February, I have to be patient and can't forget anything.
    And..... did I mention problems with pressing the wheel bolts, ha..., I asked at the truck workshop in question and they actually still have the brake drum lathe and even better, they have a 50t press and they will help me.
    I'm happy.
    Regards Harald
  21. Deutscher
    Deutscher
    from Germany
    I have now cleaned everything and painted the frame and axle parts black.
    All the parts have been ordered, now I have to wait until February for them. Maybe I can get the motor back from the repair shop before Christmas, that would be great.
    We had my friend's 4 banger converted to bearing inserts there and have now completed and installed it.
    Greetings Harald
    LCGarage, catdad49, Dannerr and 11 others like this.
  22. Deutscher
    Deutscher
    from Germany
    Now I opened the steering gear to reseal it. There was no grease left in it and the bushing with the bearing ring was torn.
    The sector shaft was quite loose and new bushings were pressed in.
    The bearings and steering are in good condition, no holes or breakages.
    The Adjustment was also carried out successfully. The steering is ready to be installed.
    I wish everyone a happy and healthy new year.
    Greetings Harald
    OleADTruck, Dannerr, Joe Blow and 8 others like this.
  23. richard noble
    richard noble
    Hi Harald, and welcome to the H.A.M.B. If I’m reading this right, you’re planning on running the Modal A wish bone with the 32 axle. The 32 axle is 2 inches at the perch whereas the A is 2 1/4, that means you have to install a 1/4 inch spacer. Also the 32 perch bolts will be to short, you’ll have to run the A perches. Try a fit and let us know if this is a problem for you. Great car by the way.
    OleADTruck, Baumi and porkshop like this.
  24. 29Sleeper
    29Sleeper
    from SoCal
    I like reading the European build threads. They are doing it the way we did in the 60s. We spent hours saving/fixing old parts - usually because we got it free and a usable one was $5. Today most here just toss it and buy a new or rebuilt part. Since there is a lack of parts in Europe they need to use the old methods and take extraordinary measures to save them.
  25. Deutscher
    Deutscher
    from Germany
    Happy new year to you all.
    @Richard, as I understand it, the 32 spring perches are essential to get the actuator arms to the right height with a 32 axle, all the conversions that I know of used the 32 spring perches for this type of conversion.
    What causes problems are the 32 actuator arms, from there the rods run to the middle of the car on the 32 and the levers hang down,
    on the Model A they run along the frame and the levers point upwards.
    I will probably have to adjust the 31, that should work. Yes, a spacer has to be used. The thread is just about enough to attach the spring perches to the 31 wishbone. Greetings Harald
    catdad49, Joe Blow, porkshop and 4 others like this.
  26. Stovebolt
    Stovebolt
    Model A actuators and king pins.
    Everything else is 33-34
    OleADTruck, Dannerr, catdad49 and 6 others like this.
  27. Deutscher
    Deutscher
    from Germany
    Thanks for the pictures, you put the spacer at the bottom so that your shackle still has enough space.
    I've seen some people who put the spacer at the top to give the shackle more room, good pictures, very helpful.
    Greetings Harald
  28. Greetings Harald and welcome to the Hamb. I really like what you have done with your "A" so far. Here's a photo of the "old school banger" that I did a few years ago... 113.JPG
    OleADTruck, catdad49, Dannerr and 7 others like this.
  29. Deutscher
    Deutscher
    from Germany
    Thank you for your kind words,
    it stands well on its wheels,
    very nice, a fine 4 banger,
    I like it a lot.
    Greetings Harald
    OleADTruck, catdad49, Dannerr and 3 others like this.
  30. RodStRace
    RodStRace
    Really like your build. It seems like you have the smarts and the connections to handle everything. However, this might help. He also owns a Model A in Germany. He might be able to suggest a local place or maybe share in parts purchase and transport.
    www.youtube.com/@AstraWerke/videos
    OleADTruck, winduptoy and porkshop like this.
