Hot Rods What rear end is this?
Discussion in 'The Hokey Ass Message Board' started by 2345.coupe, Nov 28, 2024.
  1. 31 frord coupe hot rod.jpg toyota hot rod rear end.jpg toyota hot rod rear end1.jpg toyota hot rod rear end3.jpg toyota hot rod rear end4.jpg toyota hot rod rear end5.jpg Recently purchased this really sweet 31 ford coupe hot rod. I was told it has a Toyota truck rear end. So far, I purchased brake shoes and wheel cylinders for a '79 2wd truck that looked like they matched what was on the rear end.
    I can't find the correct the brake adjuster spring. I can't find the correct brake drums. The wheel studs are 5x4.475 which doesn't make sense because the early Toyota trucks are all 5x4.5.
    Does anyone know what yr, model this rear end is, or where I can find this brake adjuster spring?Tha 31 frord coupe hot rod.jpg toyota hot rod rear end.jpg toyota hot rod rear end1.jpg toyota hot rod rear end3.jpg toyota hot rod rear end4.jpg nks
  2. RodStRace
    RodStRace
  3. LOU WELLS
    LOU WELLS
    from IDAHO
    1955-57 Chevy?...
  4. squirrel
    The axles have been redrilled to change the bolt pattern, what is the original bolt pattern?
    It's not a Chevy rear, it is most likely a Toyota pickup.
    It looks like you have the adjuster spring, is the spring missing on the other side or something? do you really need to replace them?
    Do you have the old drums? to measure and take a picture of? or do you have dimensions?
    rockauto is pretty good for looking up the dimensions of drums that you suspect might fit it, so you can compare.
  5. NOT A DODGE. 1977 Toyota Land Cruiser.
  6. squirrel
    Land Cruisers were six lug. Pickups were 5 lug, like this rearend.,
    gimpyshotrods likes this.
  7. Yep
    2wd
    Toyota
  8. yes the spring is missing on the other side. And yes its a toyota rear, but what yr and what did it come out of?
    I can't seem to find the correct spring I've checked Rock auto,
    I also figured out its a chev bolt pattern.
    I think a 1957 chev drum might work from Rock auto.
    But I need that brake adjuster spring.
  9. I believe the drum has to be wider than 10" plus the bolt pattern on my axels are 5x4.75 not 5x4.5
    there were no drums that came with the car.
    there was no brake parts that came on the rear end drivers side
  10. Depends on where they were exported to. Middle East were 5 lug along with SE Asian.
  11. gimpyshotrods
    gimpyshotrods
    It is very clear that these axles have been drilled with the Chevy bolt pattern, and the studs installed there.
    Measure the bolt circle on the 5 empty holes
    You will find that to be 5-on-4-1/2".
    It is a 2WD Toyota pickup rear end.
    You will need to re drill new drums to get them to fit.
    squirrel likes this.
  12. Measure it
    easiest drum is drilling a Toyota drum
    You can look up a casting number from a wheel cyl to help ID
    Numbers on shoes
    Things like speed sensors being present or missing
  13. squirrel
    And you can get a different rearend, too....
