Projects 53 COOP (Studebaker) gets a major makeover
Discussion in 'Traditional Customs' started by Irishjr, Oct 10, 2020.
  1. Tim
    Tim
    from KCMO
    Been a while since an update, how’s it
    Going?
  2. pprather
    pprather
    @Irishjr , Jim, please provide an on topic update.
    Thanks.
    chryslerfan55 and jim snow like this.
  3. pprather
    pprather
    So we got our hands slapped a while back. Let's all get past that and move on.
    Jim, @Irishjr , can we get a little update on this neat project?
  4. Irishjr
    Irishjr
    As I was apologizing a while back, I still am working on the **95 C****O ZX8. I twisted something wrong and had sciatica hit me on Labor Day weekend. OUCH!!! That limited my garage activity for a while.
    I have the steering column apart to replace the turn signal switch and cam plus the cruise, turn, and wiper staff. Boy I hate modern cars compared to traditional hot rods and customs. The oldies are so much easier to work on. I can't even find metal close enough to situate a magnetic base led lamp. Everything's plastic!
    Probably get back on 53 COOP in a couple of weeks. Grandson needs to have his 6-speed 90s factory hot rod!
    Okie Pete, Stogy, Tim and 10 others like this.
  5. pprather
    pprather
    Thanks for the update. Take care of yourself and the grandson.
    We will wait patiently for a 53COOP update.
    Stogy, jim snow and Scooterville like this.
  6. pprather
    pprather
    Are you back on the Stude yet?
    Stogy and Jacksmith like this.
  7. Irishjr
    Irishjr
    Yes, close to getting back on it, but still having cooling system issues on the **95 C****O ZX8. Soon, and thanks for asking!
  8. Tim
    Tim
    from KCMO
  9. pprather
    pprather
    Jim, can we get an update?
    I hope all is well.
  10. Irishjr
    Irishjr
    Phil et al.....
    Sorry I haven't updated.
    1. Health is OK:)
    2. 1**5 C****o Z*8 was shipped to grandson, Sam, right after the first of the year. He's now the COOL at the Engineering SCHOOL.:cool:
    3. No progress on 53 COOP :( because:
    I got a call from Kevin Anderson of the Custom Car Revival. He and Steve ****an got together and put out an invitation to all custom cars that have been featured in The Rodder's Journal to gather at CCR in Indianapolis June. So guess where my efforts have focused. First, I called Don Richardson about bringing the Doug Rice Coupe for another meetup of the Bonneville Boomers (TRJ #57). He liked the idea, so I am hoping he will be there. Jay Fitzhugh is planning on riding out with me (just like in 2012). So, I am busy fixing the stuff I never did right in the thrashing before leavin on High Sodium Diet III:
    • I moved the A/C compressor up to the top of the engine, where it is more accessible
    • Made a shroud and fit a mechanical fan
    • Will be revising the cowl vent mechanism so it will seal better
    • Cleaning up the wiring under the dash, including a Coach Controls panel
    • Replacing my gauges in the '50 Ford dash with a Cl***ics Instruments panel and clock
    • Installed weatherproof door switches under the car (lost one key fob out on the Salt in a rainstorm!)
    So that's where I am at.........
    Thanks for asking. I promise to get back on 53 COOP after I get back from Indianapolis. Oh, and I also need to celebrate my 60th anniversary in May (if I want to see the 61st) :eek::D:D
    Stogy, brEad, Hnstray and 13 others like this.
  11. Tim
    Tim
    from KCMO
    Keep us posted an that thrash/ trip/ adventure we’d love to see it!
    Just Gary likes this.
  12. pprather
    pprather
    Jim, thanks for the update. Glad you are well and busy.
    I may have to put CCR on my June calendar, as a spectator.
  13. Irishjr
    Irishjr
    Okie Pete, pprather, Tim and 2 others like this.
  14. lothiandon1940
    lothiandon1940
  15. pprather
    pprather
    Any progress on Stude since CCR?
    I saw your CCR story of the '40 Coop adventure.
    milwscruffy and Scooterville like this.
  16. Irishjr
    Irishjr
    Alright, alright, alright.......I'm back and making progress!!!!
    Yes, 40 COOP made it to CCR 2025 and I had a great time:
    https://www.jalopyjournal.com/forum...custom-car-revival-another-adventure.1336906/
    But that was in June and I had to do some repairs....but I'm back on 53 COOP and have already registered to take it to CCR 2026. So I've gotta get crackin'!
    As I have related repeatedly, I'm going to paint it in segments. I'm 81 and definitely not up to doing it all in one session, so here goes. First segment is to paint the hood and trunk lid and set them out in the back garage to have them out of the way for an extended time.
    So first order is to prime them with high build urethane primer and get ready for color. In order to simplify, I elected to try Eastwood's OptiFlow roll-on primer, which I had purchased a couple of years back (Oh Oh!). I started to mix the can with a stick....not! So I went over to my buddy Ray Travis's shop and used his HFT air-operated shaker. Gotta get me one! Then I cleaned the epoxy-followed-by-Slick-Sand surface with Pre and rolled the primer on per instructions. So far, so good.
    Notice how glossy it ended up....not good! Instructions said it would be dry-sandable in four hours...not in my case. After 4 days, I was still not able to dry sand without clogging the 320 or 400 grit paper. So I wet sanded.
    By the way, I searched for adhesive-backed wet sanding abrasive, just hoping here was sucha a thing and there is and it worked GREAT!:
    Meanwhile, I contacted Eastwood and, as I suspected, the activator for the OptiFlow primer had a shelf life far shorter than 2 years! So I will be trying out a new can of the activator in the future paint prep.
    But back to the issue at hand. It turned out that the primer did wet sand OK and so I guide coaed it and used 310 and 400 wet snding, followed by 400 dry and now it did not clog the paper, so the cure was complete:
    Now on to the color....
    I wanted to kinda duplicate the original two tone light blue bottom/dark blue top of the stock Stude, but with heavy metllic added. So I selected some online stock shades at TCP Global's Restoration Shop and bought the system. However, it turned out that the bottom color was too dark to my liking, so I bought a gallon of a lighter blue metallic. Unfortunately, it turned out to be grayish blue, so I made a custom color by adding a pint per gallon of the too-dark-blue and I suited me perfectly (and ahould be repeatable if more is needed). Base coated the hood and trunk lid:
    Then came the clear (also from Restoration shop - Premium Clear 4:1 mix). It's been awhile since I have done this, so I selected my 3M AccuSpray gun with a 1.4 tip and......not so good! :(:( A lot of orange peel on the first coat, which caused me to switch to a SATA RP gun with a 1.3 tip which a buddy gave me several years ago. With a 10% addition of urethane reducer , it atomized beautifully for a second and third coat. I will have to sand and buff the orange peel, but I can live with that:
    So today I sand and buff. It's great to be back on the 'Baker!
    Later.......
    BigRRR, Paul B, Just Gary and 21 others like this.
  17. lothiandon1940
    lothiandon1940
    WOW! Looking great @Irishjr . Nice work as always.
  18. Tim
    Tim
    from KCMO
    Very nice color! Glad to see updates :)
  19. patsurf
    patsurf
    perfection-AND ...patience!!-congrats!
  20. Irishjr
    Irishjr
    Today was very fruitful. I called Richard Glymph, famous local custom car painter friend, to get some advice on the hood/trunk paint issue and another issue (I'll talk about that later). He suggested sanding the surface and re-clearing it rather than buffing it. That way, I won't have to sand and buff the rest of the car. He said I will really like the results. Sounded good to me. :):)
    So today I finished the sanding with 400/600/800 grit and called another retired car painter friend, Calvin Martin (wasted both his shoulders doing it) to help me set the gun correctly and give me some spraying lessons. It turns out that Calvin knew Richard and was even mentored by him when he started in the painting business.
    Much improvement:
    So now for the other issue I discussed with Richard Glymph. A few years ago I bought a set of four repro '54 Studebaker stainless steel full wheel discs ('53 discs had three convex radial grooves). I think these are some of the nicest discs ever put on a car. Here's a pic of a used one i snipped off eBay:
    However, on a customized '53, the stock discs need added bling. Older guys like me may remember a fad back in the early 60's where guys decorated them with candy scallops with pinstripes. I'm going to try that (eventually), so I asked Richard how to do them without damaging the surface. He suggested spraying the masked surfaces with clear Bulldog Adhesion Promoter (rattle can) and then spraying the candy urethane. If I don't like it I can always use paint remover to go back to the polished stainless of the stockers.
    So that's what I am going to try on an old one, just to find out if it will work.
    Well, that's enough for now. Tomorrow, I will build some standoffs that bolt to the hinge mounting holes on the hood and trunk that will allow me to rest them against the wall in my back garage and be raised off the floor a bit so they don't get damaged.
    Then on to the rest of the car!
    Later......
    Just Gary, Paul B, Okie Pete and 15 others like this.
  21. Irishjr
    Irishjr
    Back at it!
    So I built some short brackets that bolt to where the hood and trunk hinges bolt. These are short posts that raise them off the concrete on my back garage so I can store them for awhile and not mess up the corners:
    So now, in between working on the body, I am also working on the customized full wheel discs. I've been talking to custom painter friends and merchants of paints about my plans and here goes:
    First I took some measurements off the disc and went on 2D CAD to come up with my scallop design. I constructed a parabola pattern for masking to provide six radial spears. First try was too large so then I fixed it:
    Then I printed six of them out at full size, cut them out and and taped them into position on the wheel disc (after laying out some centerlines with a sharpie):
    Next I'm having them cut out on a special masking vinyl sheet at a friend's print shop. In the mean time I am going to try some sample paint with a blue candy color on some s**** polished stainless. I'll let you know how that works out, later.
  22. Irishjr
    Irishjr
    I haven't been neglectiing 53 COOP......just juggling parts of the project!
    On all my COOPs I have usted the same radio antenna system, i.e., a flush mounted tip painted the body color, which was originally a kit that Gennie Shifter Company sold. (OOPS! Not on 26 COOP, 'cause it ain't got a radio! o_O)
    However, Gennie Shifter hasn't sold them for a long time. So I made my own:
    Here's the anntenna I use:
    Here's the ***embly I built, ready to go into the car. Notice the tip, which is a machined piece of aluminum which is mounted with a setscrew. It is the same O.D. as the tip that comes with the antenna, and is chamfered on the bottom to help it re-enter the hole in the fender. I machined an aluminum cylinder that allows the chromed nut to clamp onto the staff outer shell at the sheet metal bracket with an oversize hole and washers to allow horizontal adjustment. At the bottom of the ***embly are two mounting holes for 5mm screws, again with oversized holes for adjustment.
    I am mounting the antenna just behind the "C" pilllar at the same angle as the leading edge of the wrap-around back window, so it required cutting a slot in the inner rear quarter panel, which I clecoed in place as shown below:
    Here's the tip sticking through a hole in the top of the fender:
    After a lot of fitup and a few nutserts, here's the ***embly in place with the tip shaped to be flush with the top of the fender:
    At the same time, I have been working on the hubcaps:
    I had a friend at Island Print Shop cut me the masking vinyl parabolas:
    Then I cut a hole in a piece of plywood to help me mark all 4 caps into 6 equal segments:
    Then using a rigid/flexible straight edge, I eyeballed the alignment near the center of the caps:
    Using a water spritz with a little Dawn soap, I mounted the parabolas and squeegied them to make them push the water out and adhere to the stainless:
    Finally, I masked them the rest of the way and used a lid from Planter's Mixed Nuts, held in place with rope caulking, to mask off the center circle, which may get painted gold later Doesn't that loook like something from Cinco De mayo?:
    By the way, I must give my wife credit for finding the center masking lid fitment!
    I'm gonna have another friend paint the HOC candy cobalt blue next Monday, in preparation for pinstriper Matt Stankis laying down some outlines at Jalopyrama Tribute in Easton, MD October 4. Gonna take 40 COOP!
    See ya there?.......
    Tim, Just Gary, AndersF and 10 others like this.
  23. Irishjr
    Irishjr
    Rather than paint the candy myself, I elected to have a painter friend do it in his booth in Annapolis. In fact, he was my source of a 20 year old can of HOC cobalt blue candy, which he mixed into the 4:1 clear and layed on 4 coats, adding a few more drops of candy with each coat. Here's how they look now with the masking removed (the Sharpie marks will be removed after a couple of days of curing):
    I'm having masks cut at the print shop to mask the center circles for gold tinting.
    Now is the time to select a color for the striping. I was originally thinking of a blue of some sort, but now I'm thinking of gold. What do you think?
    By the way, At the same time I've been cleaning up my garage and putting a lot of stuff into storage so I can mess it up with body work and painting. wish me well......
  24. Irishjr
    Irishjr
    Went to Jalopyrama Tribute last weekend in Easton, Maryland. Had a great time, in spite of being addressed as "Jim Ireland, LEGEND", which meant that I was really OLD!
    https://www.jalopyjournal.com/forum/threads/2025-jalopyrama-tribute-show-my-pics.1341949/
    I had arranged for the stripes to be layed down by Matt Stankis, from Wilmington, DE. It really finished them off!
    Another HAMBer, Just Gary, who I met at the show, messaged me a pic of Dean Jeffries that I had been unsuccessfully searching for:
    Now I really feel that I am following in the traditional customs lineage....
    Meanwhile, I'm working on readying the back half of the body for paint and ***embly.
    But more about that later.......
  25. pprather
    pprather
    I saw the hubcap display in Scott's video of the Tribute event. I also noted the 40 Coop with prime parking in the outdoor area.
    Looking forward to Stude updates as they progress.
    Scooterville and Just Gary like this.
  26. Irishjr
    Irishjr
    Oops! I forgot to show ya how I did the gold centers. Studebaker hubcaps and full wheel discs had a concave center that is essentially identical on all of them and were painted a translucent gold through many years. How to mask them off presented a challenge. So I came up with a machined disc that projected down into the concaved portion so it would be self-centering and grooved on the outside of that projection where I could place rope caulking to seal it from overspray:
    I used plastic film and masking tape on the bottom side to wrap around the wheel disc to mask the outer portion. Note the rope caulking in the groove:
    Here's a shot of the center afteer spraying the candy gold:
    Of course, I had to do one disc spraying at a time, but the transfering of the masking ***embly was easy.
    After the center was completed, I remasked off the portion outside of the whole design and clear coated it all to "knit" the painted surface into a single unit to aid in adhesion to the polished stainless surface. The pinstriping is the the device that seals the outside edge. Hopefully, it will be pretty permanent, given careful handling by the owner :):rolleyes:
    I'm a member of the Studebaker Drivers Club and think I should share this on their forum, perhaps lending the machined masking disc to anyone who wants to try it......
  27. Irishjr
    Irishjr
    Alright, I admit I've really ignored this thread, of late. Sorry, OK?
    So here's what's goin' on:
    First, Here's a pic I took today. Just about ready for paint on the back half, but you'll have to see the "schedule" below to see where I've been and where I'm goin'.
    The plan is....make that WAS to get the back half painted by the end of October. That didn't happen because other issues got in the way, but the general progress is ongoing. Now I am trying my darndest to make it happen by the end of November.
    Here's the revised sequence:
    1. Cut the Lexan rear window to fit the new opening and make it ready to install. I moved that up so that I would not be endangering the new paint by doing the fit-up later. Its all done and ready to apply the cord-in-the-inside-flap method, including installing the stainless trim.
    2. Do the same for the Lexan windshield. I decided I will have the gl*** one installed by Brian, the Gl*** Guy Chicago, do it in the Chicago or Indianapolis area in June. It also is all ready to go in.
    3. Fix the door gaps. Boy, the stock '53 doors were terrible. Gaps as wide as 3/8". I bit the bullet and I'm glad they are fixed. As it turn out, I am priming them at the same time as the back half, although I probably will wait to paint them separately.
    4. Position and relocate mounting holes for the rechromed pot metal trim around the door and rear quarter windows.
    5. Finish some of the structural gaps around the door openings and rear quarter windows.
    6. Prime and block sand the back half......and
    7. PAINT!
    8. ***emble rear half, including trunk seals and lid, bumper, taillights, windows, etc.
    So here's a look at the rear window development:
    I started by determining the gap between the edge of the gl*** and the contour of the window frame that allowed a piece of the seal to be installed at the top and bottom of the window. Note the piece of seal about 30" long at the bottom of the window. Small tiedowns worked well for positioning the gl*** and partially clamping the flexible Lexan around the side curves. This allowed me to gradually trim the edges to maintain the aforementioned gap around the whole perimeter.
    Pro Gl*** advised me to use a medium pitch wood cutting blade in a saber saw and to put a layer of tape on the foot of the saw to keep from scratching the Lexan. I found that a Bosch wood blade of about 14TPI with very slight set to the teeth cut a very clean kerf:
    Pulling the rope:
    Establishing the proper gap:
    Boy! Gorilla tape comes in really handy!
    Long story short, I covered the finished rear window with mylar drafting film (except around the perimeter) to protect it while I completed measuring and cutting the Lexan. Once that was finished, I stretched the rubber seal around the perimeter, cut out about 2" and glued the new joint with CCA (Super Glue). It turned out that that was not a one-man chore. Lexan is flexible, where gl*** is not. Ultimately I needed to round up a bunch of plastic spring clamps (bought all that HFT had in stock in Easton, MD) and wound up with a seal that had to be strecthed to get it on the window (which was the plan). Note how my buddy Carl and I discovered was the right way to hold the rubber in place, by clamping on the window and pushing the crotch of the clamp against the rubber.
    Then came the messy and hard part... the messy part is putting a bead of butyl rubber caulk (remains soft) and stretching it around the window. then the stainless trim goes in a slot of the seal and gets completely installed before the window is installed on the car.
    My plan is to have the ***embly ready to pull the rope after the back half is painted.
    So here's the completed ***embly, ready for installation.....EXCEPT the trim had to be modified to fit a chopped top!!!
    The back/bottom piece was unchanged, likewise the two front/bottom curved pieces. However, the top/front piece was cut about 2" at the bottom/front and, since I had widened the top about 1-1/4", I cut the top/front piece in the center and made a cover over the gap. I had some #24GA polished stainess and it turened out to be relatively easy to fit the profile of the face of the trim and bend the edges to stay in place:
    So now the rear window is ready to go in and, by the way, I also did the Lexan windshield the same way, although I had already modified the trim and had a template from my getting the gl*** windshield cut by Gl*** Guy Chicago:
    Well guys,, that's all I'm including on this post, but I'm ready to work on the next one right away and promise I will be better about keeping up to date.
    See ya for now......
    drdave, SS327, Just Gary and 12 others like this.
  28. pprather
    pprather
    Thanks for the updates, Jim.
  29. Tim
    Tim
    from KCMO
  30. Tim
    Tim
    from KCMO
    Geez I missed all the hubcap stuff! Damn those rule! Great job they’ll look perfect!
