Technical ***December 2024 Banger Meet Thread - Santa, I was bad, but good at it***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 1, 2024.
  1. Jiminy
    Jiminy
    Link to previous month: November 2024 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    bubba55 likes this.
  2. Had a little four banger meet up yesterday…
  3. Picked up a Whippet grill shell from cactus1 here on the Hamb. Three Springer still moving forward.
  4. Joey Donuts
    Joey Donuts
    First post - purchased a 30 Tudor and it had juice brakes on it from an 80’s restoration. Could someone confirm what year these are off of?
    bubba55, jet996 and G Baese like this.
  5. PINEAPPLE
    PINEAPPLE
    Those are early 40's lincoln brakes.. Bendix made, very sought after brakes.. Not the typical 39-41 or 42-48 lockheed style ford brakes. Total score!
    winduptoy and Outback like this.
  6. Joey Donuts
    Joey Donuts
    Awesome, thanks for the info Pineapple!
    PINEAPPLE likes this.
  7. Stovebolt
    Stovebolt
    I need me a zip code open car ….. real bad
  8. About 10 hours in the truck, all for the chance to learn more about the Tamarco Hal. It was definitely worth it, Terry was a wealth of knowledge! IMG_5949.JPG IMG_5954.JPG IMG_5953.JPG
    winduptoy, Lil'Alb, flyin-t and 10 others like this.
  9. Zax
    Zax
    1. 1952-59 Ford Social Group
    If you guys were rebuilding a 39 transmission to go behind a mildly hopped up A banger (6.5 head, Mallory dist., downdraft with single 2 barrel) would you use the stock 39 gears? Or build it with Lincoln gears? Would the Lincoln gears even be worth it on a banger?
    Running 7.00 x 16 tires in the rear with a stock rear end.
    Crusty Chevy, PINEAPPLE and Deutscher like this.
  10. I would go with the 39 gear set with the 28 tooth cluster. That's if your rear is the 3.78 one. That's what I had in my roadster and I had no complaints.
  11. Deutscher
    Deutscher
    from Germany
    I have a Volvo M40 gearbox behind my 4Banger, 4 gears synchro.
    Just a thought.
    Greetings Harald
  12. PINEAPPLE
    PINEAPPLE
    Zephyrs are nice for the close ratios but you might want a quickchange rear to get the right final drive for city or highway driving. I had this setup until recently, I broke the zephyr gears (repop gears, lesson learned, only buy originals) I now have 28 tooth ford gears in there. Works good just a bigger drop between gears.
    winduptoy likes this.
  13. wuga
    wuga
    Just helped a friend install a blown flathead in a 37 with a 39 box and a Columbia rear end. We have on the bench a 37 Cad-Lasalle that will eventually replace the 39 Ford. No tail shaft will be used although we have the short Olds tail shaft. He also has a Halibrand adaptor but wants to stick with the early flathead. Am in the process of making the front adaptor plate and will adapt the rear mount to keep the closed driveshaft. This is all early hot rodding, but the question is, what will keep the Columbia together? Just a rhetorical question, but the same applies to the Zephyr and the Columbia.
    Warren
    winduptoy and 51 mercules like this.
  14. jet996
    jet996
    from WY
    I can't remember the company, but they make some upgrades for the Columbia. I have a friend with a 331 hemi in front of one and it's held up fine. The car was built by his dad like that back in '55 and he wanted to keep the rearend.
  15. jet996
    jet996
    from WY
    Tremendous winds this past week, but got a killer sunset tonight! IMG_4540.jpeg
  16. PINEAPPLE
    PINEAPPLE
    That truck looks so cool. Are those the brewster caps on 35 wires? Look awesome.
    winduptoy, Bigcheese327 and jet996 like this.
  17. jet996
    jet996
    from WY
    They're covers made by Kevin Lee, I've had them forever. I've run them on everything with '35 type wires. They're awesome with whitewalls!
  18. I'm looking to feature some photos or video of a Hal SOHC to wrap up my video on Harry Hosterman. Does anyone know of someone who owns one? Thank you, guys!! Screenshot 2024-12-05 at 10.28.00 AM.png
  19. Kevin Pharis
    Kevin Pharis
    from Califunny
    Wicked cool pic Retson! Neat to see the secondary intake manifold over the plugs being used. Wonder if they used the intake manifold on the other side too…?
    winduptoy and alanp561 like this.
  20. Crazydaddyo
    Crazydaddyo
    Here are pictures of mine.
    DSC05215.JPG DSC05236.JPG DSC05216.JPG DSC05179.JPG DSC05192.JPG DSC05204.JPG
    winduptoy, flyin-t, mvee33 and 8 others like this.
  21. Fabber McGee
    Fabber McGee
    What supports the cam? Do you have those parts? How do you adjust the valve lash?
  22. 25mercury
    25mercury
  23. Dan from Oakland
    Dan from Oakland
    The water pump on the sprinter engine appears to be from a Model T. I was not aware that these heads had an 'extra' intake port on the driver side. I know the Morton and Brett A heads had intake ports on both sides but......
    jet996 likes this.
  24. I've decided to just drive my car as much as humanly possible this winter, and finish up the OHV conversion once the temps climb back up next spring.
    In that spirit, if anyone finds themselves in Sin City next weekend, I've been trying to get something HAMB-related together. Guaranteed to be at least one car there...
    winduptoy, Outback, alanp561 and 2 others like this.
  25. Crazydaddyo
    Crazydaddyo
    More HAL SOHC info.
    winduptoy, flyin-t, Deutscher and 2 others like this.
  26. Fabber McGee
    Fabber McGee
    Well, yeah, I'd give $135.00 for one of those set-ups. You know, as long as it was new.
  27. Bearing Burner
    Bearing Burner
    from W. MA
    $135 was probably 13 1/2 weeks pay at that time.
    winduptoy, Outback and BeaverMatt like this.
  28. brjnelson
    brjnelson
  29. Fabber McGee
    Fabber McGee
    Probably longer than that.
    "The Model A was available in four standard colors, but not black. Prices ranged from $385 for a roadster to $570 for the top-of-the-line Fordor."
    So, almost half the cost of a new car.
  30. trikejunkie
    trikejunkie
    from Scotland
    427390545_401954116189686_5800225672706901584_n.jpg I`m still here , planning race meetings for the four banger coupe next year.................picked up what could be the oldest AA truck in the UK(pre April 1928 going by the chassis archaeology)wooden cab so it must have been ordered as a driver chassis, continuously registered in the UK since 1928!!!!!!!!!.I dunno what to do with it but it had to be bought lol
    winduptoy, Dedsoto, jet996 and 4 others like this.
