Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Tonight’s update takes the form of new parts arrival. Bronze bushings will replace the plastic ones on the rear spring and hangers, and bump stops will be installed once the frame is all painted. Tag is from Norm Rapp’s garage sale, included because I re-discovered it in a stack of books. IMG_6227.jpeg
    Also, mild custom shoebox sighting in Detroit!
  2. Tim
    Tim
    from KCMO
    Good stuff! Where are the jump stops sourced from?
    Stogy, J.Ukrop and Six Ball like this.
  3. pprather
    pprather
    Is that Joey, on the wall above the shoebox?
    Stogy, Woogeroo, drdave and 3 others like this.
  4. Six Ball
    Six Ball
    from Nevada
    When did he have time to pose for that?
    Stogy, drdave and J.Ukrop like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thanks! They came from Roadster Supply, but they're stamped SO-CAL on the bottom. They're pretty low profile and should be good for my application.
    Hahahhahahah
    Stogy, Ragged Edge, Tim and 1 other person like this.
  6. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    This weekend, I'm teaming up with Yama to dive into the finish welding for the frame. I'm hoping to do a Lowe's run to get some extra flap discs for the metal and appliance paint for the spring and axle on Friday.
    Stuff is super busy with work for the end of the year, so I'm not sure how much more progress I'll be able to make before we roll into 2025. Oh, and I did just hit send on a new piece of magazine writing that will be showing up in mailboxes early next year.
    This picture has nothing to do with anything, but I'm sharing just because I like it. The car, of course, was the subject of my Jalopy Journal column before Thanksgiving.
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I've been working on this car for quite some time now, but yesterday was one of the best days of the build. It started with me waking up early as the sunlight made its way into my sunroom-turned-bedroom. I peeked out the curtains: blue skies, green trees, and a big day on the horizon.
    Although I was there to visit and drop off David's heavy-duty engine stand, Ted was hard at work on his A-V8. This was my first time seeing it with the body on, and man was I blown away. David and Ted have been cookin' on this one, and I was excited to see how similar our stances are. Ted has a deluxe rearend setup: highlights include chrome axle bells and a magnesium quickchange by @B***.
    Parking lot scene, featuring David's roadster (note the carb tops), Jerry's Deuce pickup, Ted's three-window, and the 120lb. engine stand that I lifted into my truck earlier in the day (my physical the****** would not approve). To get it out, me, Ted, and David used an engine hoist. Superintendent Jerry supervised.
    Stogy, mgermca, tr_rodder and 8 others like this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    After a fun morning, I said my goodbyes and headed home. Back on the terrace, my roommates Michael and Aneesh helped me load my frame into the truck. IMG_6386.jpg
    A scene from outside Arguello Market, featuring a hot rod frame and lots of bay windows. IMG_6452.jpg
    Rolling up to the shop, Yama greeted me with a smile. We laid out our game plan over world-famous turkey sandwiches, rotated one of his fabrication tables, and hoisted the frame into position. And that's when the fun began. IMG_6400.jpg
    Bzzzzzzzzzzzpttttp. Bzzzzzzzptttt. Metal melted and sparks flew. Dream-pop echoed through the 947 Works shop as Panheads, Shovelheads, a dog named Mazi and a kitten named Harley looked on. IMG_6393.jpg
    Right from the start, we wasted little time. Yama hooked up a power strip, allowing one of us to cut while the other was grinding. One could weld as another fabricated. With the frame on the table, we had a 360 degree workspace. IMG_6395.jpg
    As Yama welded the K-member, I ground out the old rivets and popped off the ultra-crispy bump stop brackets. IMG_6397.jpg
    And as welds cooled, Yama and I grabbed drills with wire wheels and cleaned the crossmember. The era-correct dirt is for sale if anyone is interested.
    enloe, Stogy, mgermca and 11 others like this.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    For the welding, Yama and I tag-teamed. I haven't welded in awhile, but it didn't take long for me to jump right back in. Sitting in an old office chair with frame on all four-sides, I felt at ease. "This is the most comfortable I've been while welding in a long time," I told Yama.
    IMG_6410.jpg And when the dust settled, the frame was sturdier than ever. We notched, reinforced, and finalized the K-member, front body mounts, master-cylinder mount, and rear crossmember. It will all be painted black soon. IMG_6415.jpg
    We also used the O/A to fine-tune the front F-1 shock mounts. Here's Mazi and Harley both looking somewhat uninterested in hot rod fabrication.
    enloe, Stogy, JalopyJimbo and 17 others like this.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's getting late here, so I'll share my closing thoughts on the day tomorrow after work. There are plenty more updates on their way, including driveway fun, sidewalk finds, and project projections. Thanks for sticking with me!
  11. Outback
    Outback
    from NE Vic, Oz
    Great progress @J.Ukrop this project & your enthusiasm makes me smile :D
    Oh by the way would you ship the dirt to Australia?? :eek::p
  12. BigJoeArt
    BigJoeArt
    This is getting good!
    before you know it, final paint will be going on!
    Stogy, J.Ukrop and 41 GMC K-18 like this.
  13. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Is it just coincidence or is the name of the shop ( 947 WORKS ), connected to the cool poster on the wall that indicates the year "1947" ?
    Its always cool to zoom in and check out the various interesting details of any of the photographs that you post.
    Thanks from Dennis.
  14. Tim
    Tim
    from KCMO
    Good stuff man
  15. RodStRace
    RodStRace
    @41 GMC K-18 I thought it might be the area code, but that's 907 and 947 is Detroit. So that ain't it...
  16. Scooterfish
    Scooterfish
    The 1947 looks like a poster of a cover for a Harley service manual covering year of 1947.
    "947 works" is a You tube channel for motorcycles. Good group of guys like Joey.
  17. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Full replies to come. Just winding down here for the night and want to get things up to speed.
    Sidebar 947: A little help from my friends
    Days like Saturday remind me why I'm building this car. At David's and Yama's, I didn't have a care in the world. We were joking, goofing around, and laughing the whole time—all while simultaneously getting down to business. I couldn't be more excited about David, Ted, and Yama's projects, and they feel the same way about mine. I'm lucky to have such great friends. With their help, we're going to get this thing back on the road in 2025.
    Stogy, Driver50x, tr_rodder and 9 others like this.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Since Yama and I knocked out two days of work in less than one, I was able to use Sunday to get moving on the frame prep. In the morning, I made my way to ACE to pick up me and @BigJoeArt's favorite white appliance paint. Back at the house, I dragged the frame into the driveway and perched it on a quartet of jackstands. Then, the sanding began.
    The consensus on the cul-de-sac? Confusion. Two friends came by and asked: "Wasn't this just a complete car? Why does it look like this?"
    What a difference a few weeks can make (Hi, mom!) I ***ured them that it would be back together again one day soon, but I warned them that they may have to help.
    GirchyGirchy, enloe, Stogy and 15 others like this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Once I had done enough sanding for the day, I moseyed on over to the paint booth to spray the rear leaves. IMG_6426.jpg
    This is just the first coat. I sprayed the rest of the spring tonight in the dark.
    While I was driving yesterday, I also spotted a pair of era-correct saw horses near the trash heap at a neighbor's house. Since I was in my truck, I scooped them right up. The leaves are currently resting on them, looking much like a Halloween skeleton, as they dry in the warmth of the garage.
    That concludes tonight's update. Maybe more tomorrow?
    Stogy, mgermca, tr_rodder and 9 others like this.
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Oh, and remember when I had a top on the car? I'm going to learn to sew one day and get it all set up. Maybe around the time that I re-upholster my seat. Pardon the low-resolution.
  21. BigJoeArt
    BigJoeArt
    Tech tip: appliance enamel doesn't always cover colors well, but rustoleum primer white does, my secret sauce for bright white is 2 heavy coats of primer white, followed by a light coat of appliance enamel, and then a thick coat of enamel.
    also: dude that top is gonna look killer. what needs sewn?
    Stogy, Ragged Edge, G_Don and 7 others like this.
  22. Tim
    Tim
    from KCMO
    That’s a great tip Joey. That paint tends to be pretty dang thin
    Stogy, Outback and J.Ukrop like this.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I'm still inspired by my trip to Missouri. We're making this happen!
    Thanks, Tim! It's hot rod season.
    @Scooterfish nailed it. Yama's shop is known as 947 Works (formerly Mazi Moto). @RodStRace brought up a good point about Detroit, which is my hometown. The true meaning of 947? We'll cover that at a later date. Longtime readers will remember the big orange splot paint job from T.R.O.G. in 2022. 34A0DA7B-17FA-497B-8FDF-2E6CEE3A036A.jpg
    Yama is one of my best friends. He's one of the most positive people I know, and he's an incredible builder. If you're on YouTube, you should check out his channel.
    Some videos of his that tie back to this project to various degrees:
    He and I will be working together to finish my car, so there's a lot more where this came from.
    enloe, Stogy, tr_rodder and 6 others like this.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Love that strategy. And thanks! We'll have to see how it goes with the windshield angle, but I'm thinking the rear portion needs a little tuck behind the doors so it snaps to the tack strip rather than the body? But maybe not?
    Stogy, Ragged Edge, Six Ball and 3 others like this.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Tonight's update: more spring painting, plus the arrival of some raw materials and hardware. I also ordered my master cylinder parts from Van Pelt, so those should be getting here next week.
    Stogy, mgermca, RMcCulley and 10 others like this.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I won't be able to work on the car this weekend, but I've been busy hunting down odds and ends. My rear shackles, complete with castle nuts, arrived yesterday, and my Slip Plate No. 1 is en route.
    Stogy, mgermca, RMcCulley and 5 others like this.
  27. B_Griswold
    B_Griswold
    from Greer SC
    This stuff is awesome! Keep it up! Love the tips, tricks and love shared throughout the project.
    Stogy likes this.
  28. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! It's certainly a team effort on this thing.
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    No news from over here at the moment. I've finished painting the rear spring, and I plan to paint the frame and rear axle after the holidays. Figured I'd drop this snapshot of the car in the driveway to keep things interesting.
    Also, a question: does anyone have a good source for 1939 Ford pedal bushings? I'm going to try calling Van Pelt in the morning, but I know they're hard to come by. Any input would be greatly appreciated.
    trevorsworth, enloe, Stogy and 11 others like this.
  30. Six Ball
    Six Ball
    from Nevada
    Sacramento Ford? Get some br***/bronze and David help you make them.
    Stogy, J.Ukrop and Outback like this.
