1965 Ford Cortina
Discussion in 'Off Topic Hot Rods & Customs' started by Mikko_, May 8, 2024.
  1. Hellfish
    Hellfish
  2. Phillips
    Phillips
    Almost looks like a SBF head at a quick glance, wonder if there was any design/engineering overlap on the two engine types.
    porkshop likes this.
  3. Kerrynzl
    Kerrynzl
    The Ford "Kent" engine went into production 2 years ahead of the Smallblock 221 V8
    All V8 heads were crossflow but the Kent had intake / exhaust ports on the same side.
    The Kent had shaft rockers, and solid "mushroom" lifters [which made cam swaps a P.I.T.A]
    It is only the rocker covers that looked similar shape.
    The Kent engine was recognized early as an engine that flowed a lot of air and became a favorite for tuners.
    The 1000cc 3 main bearing engines would turn to 11000rpm in the F3 "screamer" era [they were limited to a
    1 barrel carb]
    Here's a bit of music for you
    Phillips and Mikko_ like this.
  4. Mikko_
    Mikko_
    from Sweden
    Phillips and porkshop like this.
  5. Phillips
    Phillips
    OH YEAH
  6. Kerrynzl
    Kerrynzl
    You need to understand ....
    The Holy Grail of N/A race engines is 100 Ft/lbs per liter [this is a 4v F1 engine that has pneumatic valves, air boxes, tuned intakes, exotic lightweight parts etc etc etc.
    Back in 1964 these guys were getting 62-63 ft/lbs from a 997cc engine with 2 valves and a single throat carburettor
    And 11000 rpm from a 3 main bearing block and crankshaft.
    They only matched that torque/liter in the 70's with F5000 [formula A] engines with Lucas timed injection
    510hp at 8500 rpm from Swiss built Morand engines
    Here's some more music
    porkshop and Phillips like this.
  7. Mikko_
    Mikko_
    from Sweden
    Boxing day was spent tearing the 1500-engine apart.
    Ready for cleaning, inspection and then off to the machine shop.
    I also got the inner intake ports cleaned up a bit so now the head is ready to be converted to unleaded fuel and some milling to raise the compression just a little bit.
  8. snoc653
    snoc653
    from Iowa
    I love the sound of those little engines and he did it proud on the dyno, inched it right on up until the red light came on for the RPM limit. Then let it wind itself back down. To hear a whole track full of those at full song would be something to record with modern equipment to do it justice.
  9. Kerrynzl
    Kerrynzl
    Is that a stock 1500 block? or the taller deck 1600 block?
    You can take a 1500 pre-crossflow out to 1680cc reasonably cheap. By picking your components correctly
    You need a 1600 crossflow crank AND pre-crossflow 125E Rods
    Then you hunt down a set of VW 1500 [air cooled] Flat Top Pistons that are 83mm bore standard or 83.5 oversize
    These pistons have a 39.6mm compression height
    1500 block is 200.5mm deck height [200.4mm to 200.6mm]
    125E Rods are 121.92 length
    1600 crank has 38.8 throw [77.6 stroke]
    VW pistons have 39.6mm compression height
    That leaves 0.18mm deck clearance [0.007"]
    83mm bore = 1680cc
    83.5mm bore = 1700cc
    And the engine can look stock on the outside
    Edit: if you're going to turn a 1500 crank to high rpm you will need to cross drill the crank oiling because #2 and #3 rod journals will starve the centre main journal.
    Ford performed this mod at the factory on the 1600 crank
  10. Mikko_
    Mikko_
    from Sweden
    Great information, thank you.
    This is a stock 1500 block, 120E-6015 casting number.
    If going the route of 1600 crank I guess I would also need to use a MK2 Cortina oil pan and rear oil seal housing, for lip seals instead of rope seals?
  11. Kerrynzl
    Kerrynzl
    Yes you'll need the Mk2 Cortina oil pan [or a front R & P conversion]
    They sound better in the studio!!
    The studio being a totally gutted interior with the whole engine reverberating through the firewall and an unmuffled exhaust under the floor exiting out the side [it's like opium for the ears]:D
    Here's a bit of music for you [A Ford BDA engine with that lovely induction noise]
    The Scandinavian's are pretty good drivers as well ..... [It is not like they're driving a flathead jalopy in a shopping mall carpark :D:D]
    RodStRace likes this.
  12. snoc653
    snoc653
    from Iowa
    Rally driving is a whole other beast. Formula cars have a song of their own and I doubt he hit 7K in the video. I do own a 90 Altrac. If I could figure out how to make it turn 9K and live I’d drive the wheels off it just to hear it sing.
  13. Kerrynzl
    Kerrynzl
    The sound can be deceiving with a cacophony of induction noise vs exhaust noise, but it is pure music
    He was pegging it to 10,000 when driving past the barns but mostly in the 6-8000 range
    Here is the tacho at 10,000 [12 o'clock position is zero]
    I am more impressed with his hand movement on the steering wheel [in road racing we were told to drive smooth]
    RodStRace and porkshop like this.
  14. Mikko_
    Mikko_
    from Sweden
    Dropped the head off at the machine shop the other day to have it converted to unleaded fuel and some minor milling.
    Also found a gearbox from a MK1 Escort Mexico, better gear ratios than the standard box in my Cortina.
    Plan is to build a "hybrid" gearbox by replacing the tail housing on the Mexico gearbox with one from a standard Cortina gearbox.
    This will give me the better gear ratios from the Mexico while I can retain the original long Cortina gear lever = No cutting of the floor.
  15. 59bones
    59bones
    from Illinois
    It's great to see your Cortina and good luck with everything.
    Here is my 66 GT that I stupidly sold about 10 years ago. What an idiot! Cortina 045.jpg Cortina 028.jpg It went to Australia
    34 GAZ, RodStRace, porkshop and 3 others like this.
  16. Mikko_
    Mikko_
    from Sweden
    59bones and porkshop like this.
  17. Mikko_
    Mikko_
    from Sweden
    Got the head back after milling and conversion to unleaded gasoline.
    Just some paint needed now.
    porkshop, Phillips and Speccie like this.
  18. Kerrynzl
    Kerrynzl
    Down our way the 2 boxes were incorrectly called a "bullet" [early] and "rocket" [late]
    Those were the names off the early and late competition boxes.
    The late box [behind 2.0 SOHC] is a "Type E"
    I had a genuine "Rocket" in my Lotus [the ratios are very similar to a M20 Muncie]
    Ford converted these boxes to close ratio using a special Input , Countershaft [Cluster] , 1st gear, 3rd gear.
    The most abused gear for rallying was 2nd gear, so Ford kept this as an "off the shelf" for easy sourced replacements.
    If you want a Type E transmission with the forward shifter position check out the Australian MK2 Escorts.
    They were all 1.6 and 2.0 SOHC engines .
    The Aussie Type E trans had a special tailhousing with a forward mounted single rail shifter.
    Here is an Aussie Type E box
    For a street car [if you have a Type E bellhousing] a better choice would be a Type 9 5-speed from a Sierra.
    It allows you to retain original [or lower 4.44:1 van] ratios and is more highway friendly
    You will need to move the shifter hole and crossmember rearward
  19. Mikko_
    Mikko_
    from Sweden
    I don't want a Type E or Type 9 since I don't wanna cut a new shifter hole.
    So I'm staying with my plan to use the 2000E ratios from the Mk1 Escort Mexico box.
    More fun to drive with 2.97 on 1st gear compared to 3.54 which I have now.
