Checker cab
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Nov 22, 2024.
  1. DDDenny
    Did lubing the speedo cable make it go faster?:D
    brEad, scotty t, porkshop and 2 others like this.
  2. squirrel
    It actually made it go slower! it was reading kind of high, before I fixed it.
    dwollam, rockable, Okie Pete and 6 others like this.
  3. squirrel
    I played with the heater last night, it might almost be working, sort of. Needs more work, though. I connected heater hoses, byp***ing the rusted away water valve. It took some effort to get the hoses on, because a previous owner had disconnected the hoses, and plugged it at the engine, instead of just byp***ing it with a single hose. I ended up having to remove the water outlet to get out a stuck br*** 3/8-1/2" adapter, so I could screw in a hose fitting. I still need to put the blower motor back in, and wire it, as the wiring was messed up also.
    But the reason for being concerned about heat is that there's a LeMons Rally in Pennsylvania in February. Which is a really stupid thing to consider going to, especially when we'll be in the middle of building the robot at the high school.....and besides, it gets cold up there. The rally starts in Scranton, and my experience with Scranton in January and February is that it's cold! I got to go TDY to Tobyhanna Army Depot when I first worked for the Army, in 1984. Stayed in a cabin in the Poconos, and drove the rental Fairmont to the Depot every day for six weeks of training on some fancy electronic equipment. I remember it being really cold every morning, and taking about half an hour to get ready to hit the road...getting the car warmed up, getting the snow off it, maybe finding the driveway again, stuff like that.
    So....if I decide to take that trip, this car needs to be pretty darn reliable. I know they were built to deal with year round use in NYC, Chicago, etc, so it should be doable.
    brEad, dwollam, Thor1 and 12 others like this.
  4. noboD
    noboD
    Scranton ****s in the winter time, but if you come I may have to venture north to visit.
    Sharpone, porkshop and squirrel like this.
  5. Artworx
    Artworx
    Did I understand you correctly, you're putting a new blower motor in it? How cool!
    Tickety Boo, Sharpone, Deuces and 2 others like this.
  6. squirrel
    heh...not quite! but I did put the heater blower motor back in, and got it wired up, and it works. Probably won't add any HP.
    I do still have a blower intake for a big block, but no blower or drive.
    Tickety Boo, Sharpone, Deuces and 4 others like this.
  7. squirrel
    and the underside...
    brEad, dwollam, porkshop and 9 others like this.
  8. Deuces
    Deuces
    A new muffler won't make it seem so sluggish....;)
    Or, you could patch that one up....
  9. snoc653
    snoc653
    from Iowa
    That underside looks all kinds of stout. Stout enough to handle that blown big block. And your blower intake even has a thermostat provision. I spent today figuring out how to mount and route the remote thermostat. I think a blown taxi would be a hit and drag and drives. Go for it.
    porkshop, Sharpone, squirrel and 2 others like this.
  10. squirrel
    I did a quicky repair on the exhaust where the pipe was missing about half an inch a couple feet before the muffler. I just wrapped some 22 gauge steel around it and clamped it in place...it's still noisy, but not nearly as bad. It doesn't rattle now.
    I went for a longer test drive, all the way to Bisbee. Made it there just fine, then going up the long grade to the Mule Tunnel, I almost made it to the top of the hill (which is just past the end of the tunnel), and the car died.
    I pulled the fuel filter, it had a lot of brown **** in it, so I put in a new filter. Tried it, and it didn't get far and died again. I figured maybe the pickup line in the tank was plugged? so I pulled the line off the tank, put a piece of rubber hose on the fitting and blew into it, and a little fuel dribbled out when I removed the hose. So I connected it up, and it started and kept going. For about ten miles. Then I pulled the filter out, and blew the **** out of it, and put it back in, and made it the rest of the way home. I did get another spare filter, and the two dirty ones can usually be blown out and used again for a while. Normal stuff with old cars.
    And you get a little video today. From the beginning of the trip.
    Baumi, brEad, dwollam and 12 others like this.
  11. RodStRace
    RodStRace
    Sounded pretty smooth. Is it cool down there? I'd guess beside the fuel system, cooling is the next possible strander?
    Sharpone, squirrel and 41 GMC K-18 like this.
  12. Deuces
    Deuces
    Love ABBA!.....;)
    Sharpone and squirrel like this.
  13. squirrel
    cool out today, perhaps 60 degrees. The cooling system is doing fine for now, but it's not very hot out, and the radiator hasn't exploded yet. It's missing the side straps that hold it together, and it appears to be original. So I probably should replace it on general principles.
    dwollam, 61Cruiser, porkshop and 7 others like this.
  14. squirrel
    I've been puttering away at the generic old car. I had a local guy make a new exhaust system for it, so now it's quiet. I overhauled the carb, it's running pretty well. The gas tank had a bunch of **** that I guess got loosened up by driving it around 150 miles, so I pulled the tank out again today, and rinsed it with a couple gallons of gas a few times, there's not much junk left in it now, I hope. This is what came out with the gas the first time I drained it today (out the filler neck hole)
    The turn signal switch was tired, it didn't "latch" when turning right, and the brake lights were flaky. I got a new switch, it's a commonly available GM part, and installed it. That's all better now. And I bought a cracked old used original 69-70 Chevy steering wheel off ebay, and put that on, so now it has the right steering wheel, even though it's not in great condition. Still need to deal with the horn ****ons support, but that can wait. Also got new door and trunk locks, so I can lock the car.
    I went for a little drive into town tonight, the car ran great.
    Also fixed the hood, I had this bowling lady left over from my brother's 58 Chevy wagon. She looks right at home.
    I even found a decent radio station to listen to for a few minutes on the AM radio. Playing era appropriate music.
  15. 41 GMC K-18
    41 GMC K-18
    As a former owner of two Checker Marathons, I am proud to say that I am very impressed at the progress that @squirrel is making on this great car/survivor!
    Thanks from Dennis!
    I do hope that this car will remain in the cool squirrel fleet!
  16. squirrel
    thanks! This car seems to be in really good shape, compared to most of the old junk I get.
    Got the wipers to work, it had a bad ground. Went for another drive to Bisbee, and it made it the whole way without trouble. I guess that gas tank flush really helped.
    I have to take a picture of all my old cars in Lowell...it's a tradition...
    Baumi, SuperKONR, brEad and 19 others like this.
  17. DDDenny
    In case it doesn't attract attention I'd suggest putting some polished Halibrands on it (like that will happen)!:D
    Tickety Boo, porkshop and squirrel like this.
  18. 26 T Ford RPU
    26 T Ford RPU
    Looks like Erie Street.:cool: JW
    porkshop and 41 GMC K-18 like this.
  19. squirrel
    Yeah, looks like Jay Allen's house in the background, too.
  20. RodStRace
    RodStRace
    Seems the mining company is closing up the town. Get those shots while you can.
    41 GMC K-18 and porkshop like this.
  21. squirrel
    If you're talking about the restaurant having to move, I don't think it could be considered "closing up the town" :)
    I've been tinkering with adding accessories, now that the car is mostly working. I added a stereo under the dash, but kept the AM radio in place and working.
    The "fuse box" on these cars is interesting. It's just a series of circuit breakers. The kind that it's easy to attach stuff to. Which makes wiring things really easy. It's tucked up under the dash at the top of the left kick panel, but since it's a roomy car, it's not hard to get to.
    Also I have the schematic from the internet, which I've printed out in big size.
    brEad, porkshop, Sharpone and 10 others like this.
  22. bobss396
    bobss396
    That looks like a Deutch Block and holder, only with threaded attachment points.
    porkshop, 41 GMC K-18 and squirrel like this.
  23. squirrel
    Okie Pete, SuperKONR, brEad and 9 others like this.
  24. squirrel
  25. 41 GMC K-18
    41 GMC K-18
    Hey @squirrel
    This really makes me smile big time!
    I have a pretty good feeling that this magical old survivor, cool checker, is working its magic on you!
    That car is in remarkable shape for its age and its mileage. Plus it has a ton of room inside for p***engers and a ton of room under the hood for such a cool new engine!
    As stated before, I do hope that you will keep this cool checker, it deserves to be cared for and tinkered with, by you!
    Happy motoring and potential mild racing in its future !
    Thanks from Dennis.
    Okie Pete, brEad, dwollam and 2 others like this.
  26. snoc653
    snoc653
    from Iowa
    This looks promising. Can't wait to see this grow an go.
  27. squirrel
    We'll see what happens. Since I already have a big block powered old truck, and a small block powered sports car, I thought it might be interesting to see what the kids are doing with modern engines. This is a 2002 364 ci truck motor, iron block, aluminum heads. I hear they take well to turbocharging, and also make decent power without doing much at all to them. Of course the fuel system might need some work...either a 3/8" fuel line and low pressure pump if I go with a carb, or a funky pump to handle FI if I go that route.
    Okie Pete, brEad, dwollam and 6 others like this.
  28. RodStRace
    RodStRace
    Wondering if there is a 3+ behind it. Hard to tell from that angle. Another gear or more really makes a difference on long trips.
  29. squirrel
    No transmission with it, it came with a manual. I was thinking about taking the GV out of my truck, since I never seem to take it on trips any more, so I'd put that behind another 400 to go in the Checker. The 3.31 gears are ok, but for going fast with OD it might like 3.73 or 3.92. Lots available for the Dana 44, and the 30 spline axles in it are hefty enough.
    Pulled the engine most of the way apart, it looks pretty good inside, like the 147k miles it is supposed to have. A little bit of condensation rust in a couple bores, but it turns easily after cleaning that out, it's not damaged. No ridge. Pulled one piston out, the rod bearing looks real nice. I expect to just put it back together with a few new parts.
    brEad, porkshop, 41 GMC K-18 and 4 others like this.
  30. oldolds
    oldolds
    I have never done it, but the kid down the street says if you have the wiring, gas pedal and computer all you need to do is supply them fuel and hook up two wires and they run. The electronics is the secret to make the power. He takes the fuel saver mode out of the computer and it gets about 40 more horsepower. Cam and injector change, are next. That with a Chinese turbo and knowledge of the computer you are on the way to as much as 1000 hp. Without any crazy internal changes.
    As I said that is what he tells me.
    porkshop, 41 GMC K-18, Thor1 and 2 others like this.
