Technical Lowering rear end in a '40 Ford
Discussion in 'The Hokey Ass Message Board' started by Nads, Dec 7, 2024.
  1. Nads
    Nads
    from Hypocrisy
    As the title may suggest, I need to lower the rear end in a 1940 Ford. It's stock, stock radius rods, transverse leaf, and Columbia 2-speed. How does one go about doing this? I know it was done many times back in the day, but I can't find any easy to find sources on this.
  2. My recollection is longer shackles were used, but I have no personal knowledge of their impact on the resulting ride. Conversion to parallel springs is possible, but on an open rear end. Reverse ends on the spring is a more common approach nowadays.
    olscrounger and Algoma56 like this.
  3. ***Area-51***
    ***Area-51***
    from Ohio
    Posies offers a rear spring that they say will lower it 2.5 inches...
  4. F-head
    F-head
    Reverse the main leaf, Pudding creek hot Rod shop just put out a you tube video on it. You can use longer shackles but anything more than about an inch longer you’ll need to add a panhard rod
    You can flatten the cross member but that’s a lot of work, reverse the main leaf and remove a couple leaves will get you down a couple inches
  5. Squablow
    Squablow
    That's what I was going to say, reversed spring eye first. Then see how much clearance you have left.
  6. Long shackles can cause some lateral sway, but has been done for decades.
    My preferred way is to reverse the main leaf, then remove some leaves and put them on the bottom of the pack under the main leaf. Might take some trial and error for ride height.
    Weedburner 40, guthriesmith and Tim like this.
  7. Tim
    Tim
    from KCMO
    ^ that.
    a lot of guys add a pan hard when going to longer shackles if they get too long and start swaying
  8. wheeltramp brian
    wheeltramp brian
    My 41 is basically the same and I took about half the leafs out . Someone had previously installed one inch lower shackles. 20241014_084230.jpg
    Squablow, Nads, catdad49 and 4 others like this.
  9. Zax
    Zax
    1. 1952-59 Ford Social Group
    Millworks sells a reversed eye main spring. I have one sitting in my garage I plan to use to lower my '40. I plan to use it and remove a couple additional leaves. If you go the same route be sure to make up a spacer to fill the void of however many leaves you remove.
    alanp561 and 100% Matt like this.
  10. Check out Iron Trap Garage on Youtube:
    The 1939 Mercury Gets Much Need Drops Shackles - Front & Rear!!!
    OzMerc39 likes this.
  11. mgtstumpy
    mgtstumpy
    An old thread by Marty Strode, flatten it.
    guthriesmith likes this.
  12. 42merc
    42merc
    Reverse the main leaf, then remove the 2 top short leaves & add them to the bottom of the pack.
    Doing this maintains the clamping force & lowers & softens the spring.
    Eaton Detroit Spring will sell you a reversed eye main leaf.
    catdad49 likes this.
  13. Put the removed leaves on the bottom of the pack below the main leaf, that’s your spacer.
    Tim likes this.
  14. 100% Matt
    100% Matt
    We sell a reverse eye main and 2" lowering shackles available on the Millworks website
    Nads likes this.
  15. Nads
    Nads
    from Hypocrisy
    IMG_3350.jpeg IMG_3353.jpeg IMG_3350.jpeg IMG_3353.jpeg IMG_3350.jpeg The vehicle in question. A sedan delivery, original V8, runs and drives great, zero rust.
    I also need a pair of 16” wheels to replace the 15”s someone put on the back.
    dwollam, Squablow and Tim like this.
