Hot Rods Fuel regulator location
Discussion in 'The Hokey Ass Message Board' started by Ray Muscat, Dec 8, 2024.
  1. Ray Muscat
    Ray Muscat
    I have a roadster with a 392 hemi and a WC 3-D intake manifold with three new big 97 Stromberg’s. Would like to know who makes a low pressure regulator and the best place to mount it. I don’t want to mount on the firewall looking at the front of the motor off the bolts for the water pump, I need to make a bracket to hold it. I was gonna mount the filter right off the regulator and feeds into the fuel rail with a gas pressure gauge at the end of the rail. Your thoughts IMG_0769.jpeg
  2. nochop
    nochop
    from norcal
    IMG_5524.jpeg IMG_7288.jpeg I mounted mine low on the firewall to keep that sanitary look. The take off with the ball valve services the pressure gauge on the dash. I valved it in case of a gauge failure or leak. The bracket also has threaded provisions for the throttle pedal
    jimmy six and rattlecanrods like this.
  3. chicken
    chicken
    from Kansas
    A Holley 12-804 regulator is 1-4 psi adjustable and looks like the one nochop has on his firewall. I've mounted them on the front of cylinder heads and they do fine there. Your water pump mount should work.
  4. Ray Muscat
    Ray Muscat
  5. Ray Muscat
    Ray Muscat
    looks real sanitary, nice job.
    nochop likes this.
  6. Ray Muscat
    Ray Muscat
    thanks i was worried about the heat boiling the fuel
  7. Mike VV
    Mike VV
    from SoCal
  8. krylon32
    krylon32
    from Nebraska
    Just don't settle for one of those cheap dial type regulators, fire hazard!
  9. rattlecanrods
    rattlecanrods
    I wanted to firewall mount mine but didn't want to deal with the vibration isolation issues of the lines coming to and from the engine driven pump. Wil end up mounting mine off the carb studs so that the reg sits between on top of the intake ahead of the carb. Looks meh but works. Thankfully I can close the hood.
    I think a front mount would be just fine and give a clean look.
  10. cs39ford
    cs39ford
  11. Bandit Billy
    Bandit Billy
    And you may be moving it next summer when you start boiling fuel in the lines. Fuel, like revenge, is a dish best served cold.
    I mounted the roadsters on the frame rail under the car where no one has to look at it but it is still serviceable...with a jack.
  12. 51 mercules
    51 mercules
    Nice setup. I'm wanting to do the same thing. I have 2 of the WC 3-D intakes.one is drilled for Rochesters and the other for Strombergs. You'll have to let me know how your 392 runs with the big 97's when you get it going.Can't decide which carbs to run. wc3d.jpg
  13. Blake 27
    Blake 27
    Just before my fuel pressure gauge.
  14. Joe H
    Joe H
    You can always put the regulator after the carburetors in a return line to the tank. The carburetors will receive full volume of the fuel pump at the set regulator pressure. The return fuel line bleeds off the pressure and sends unused fuel back to the tank, as a bonus, no vapor lock.
    Never run a fuel line into or through a drivers area! If you must have a pressure gauge inside the cabin, use a pressure ISOLATOR. Also, NEVER use solid fuel line if there is any chance of movement from mounting location to mounting location, frame to body, frame to engine, or engine to body.
    For best safety practices, follow NHRA rules.
    rattlecanrods and RodStRace like this.
  15. 1971BB427
    1971BB427
    from Oregon
    I never mount fuel regulators, blocks, or anything to do with fuel on the firewall. Occasionally I run the drags and the car wont p*** tech if fuel lines or devices are firewall mounted.
    I have a couple on the frame ahead of the engine, and one mounted off a bracket towards the front of the engine. I use Holley regulators with one input and two outputs. One output gets a pressure gauge so I can adjust pressure and watch the gauge as I adjust it.
    Chief 64 and rattlecanrods like this.
  16. swade41
    swade41
    from Buffalo,NY
    I've never had a heat related issue with my regulator mounted on the front of the engine. I use a piece of aluminum bar stock with holes to dissipate heat and space it off the head so it's hanging out in the breeze.
    20200329_173034.jpg 20200329_173431.jpg 20200329_173323.jpg 20220924_164121.jpg
