Hot Rods Small Block Chevy V2
Discussion in 'The Hokey Ass Message Board' started by swade41, Dec 9, 2024.
  1. 1biggun
    1biggun
  2. partsdawg
    partsdawg
    from Minnesota
    The seed has been planted.
    Somebody on this board will attempt to recreate it.
    SS327 and Sharpone like this.
  3. swade41
    swade41
    from Buffalo,NY
    Great idea !
    winduptoy, Sharpone, 1biggun and 2 others like this.
  4. Stogy
    Stogy
    Even better...
    winduptoy and Sharpone like this.
  5. Ned Ludd
    Ned Ludd
    It might shake less than you'd think. The theory is actually quite interesting.
    Balancing a single is a problem. No counterweighting, and it'll shake up and down. Full counterweighting, it'll shake side to side because, though the m*** of the piston and rod is counterbalanced, there is nothing counterbalancing the counterweight halfway up and down the stroke. Any intermediate amount of counterweighting, and it'll shake up and down some and side to side some, and it's a judgment call as to more of which you can live with.
    Add another cylinder at right angles, and the second piston and rod will counterbalance full counterweighting at mid-stroke.
    Of course, on the SBC one bank of cylinders is ahead of the other, and the rods are side by side on the crankpins, unlike the fork-and-blade or master-and-slave big-end arrangements used e.g. on Harley Davidsons, aircraft radials, etc. to get the cylinders in the same plane. So on a SBC-based V-twin there will be a small amount of rotational vibration about the vertical axis. It might be possible to do something about that by making the counterweights slightly asymmetrical.
  6. If you want an idea of what it might sound like ... fire up your SBC then start pulling plug wires until the back two are the only ones left :)
    I'd offer to do it but I already receive regular doses of court imposed, medically applied shock treatment on a regular basis. Any more and my main fuse may trip o_O :oops: :( :confused:
  7. Unkl Ian
    Unkl Ian
    An inline 4 lives better, than a V4, when you start making power.
    The crank loads are spread across more bearings.
  8. noboD
    noboD
    That's how the SESCO Chevys were built.
    Sharpone and sdluck like this.
  9. Sharpone
    Sharpone
    The idea of pulling wires is simply shocking
    Outback, borntoloze and Stan Back like this.
  10. wheeltramp brian
    wheeltramp brian
    I had to take the p*** side wires of of my poly motor to do something and forgot. Fired up kinda hard but ran ok but wasn't right. Then I remembered, whoops!
    Outback and Sharpone like this.
  11. oldiron 440
    oldiron 440
    All it needs is a turbo…:)
    Sharpone likes this.
  12. Jacksmith
    Jacksmith
    from Aridzona
    Whelp... now I've seen it all!
  13. mohr hp
    mohr hp
    from Georgia
    There was a V2 KB hemi that ran at Bonneville in the 80's or 90's powering a MC streamliner. It was made from junk Top Fuel parts. Made power and ran hard, but shook itself silly. Lots of SBC V4's were made for sprint cars in the late 60's, very successfully.
    Sharpone and Outback like this.
  14. GuyW
    GuyW
    In the 80's, a company was selling a fairly large displacement V-twin engine to bolt into H-D ch***is, the engine used Chevy parts because H-D parts are historically over-priced....
  15. 05snopro440
    05snopro440
    My old neighbor told me that HD actually stands for Huge Dollars.
    Sharpone and GuyW like this.
  16. swade41
    swade41
    from Buffalo,NY
    I watched a do***entary on those Super Vee's, they seemed to not be able to get the bugs worked out on them
