Hot Rods 29 RPU- "Street/Strip" B/SR Build - Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Dec 19, 2019.
  1. Marty Strode
    Marty Strode
    IMG_0796.jpg I did find a pedal pad for the throttle, when driving my Ranger PU, I looked at the parking brake pad, so one is on the way. Also, after I get the pad installed, I will form up a bolt on toe strap, to meet the rules.
    catdad49, brEad, bymanr and 6 others like this.
  2. DDDenny
    Took some looking but I found a couple left over from my Kart racing days, thought you could use one but I wasn't fast enough Marty, I don't recall where I got them, it does have a different pattern with one rounded edge, yours is the better choice anyway for a foot feed.
  3. Tim
    Tim
    from KCMO
    Clever pad solution!
    catdad49 and Sharpone like this.
  4. Marty Strode
    Marty Strode
    The last guy on TV I remember calling it a foot feed, was Darrell Waltrip !
    LCGarage, alanp561, catdad49 and 4 others like this.
  5. Dean Lowe
    Dean Lowe
    That's only way my Dad called a throttle pedal.
    alanp561, catdad49, bchctybob and 2 others like this.
  6. Marty Strode
    Marty Strode
    The hood is prepped and the P-side door panel is done, off to be lettered tomorrow ! IMG_0797.jpg IMG_0798.jpg
  7. AmishMike
    AmishMike
    My number 1 complaint about many roadsters: if u do not plan on a top, why have that stupid tab that sticks up just behind door opening? Oh god, I mentioned something I do not like on a Strode build. So sorry, off to hide in closet. I did say “many roadsters”.
    catdad49, bchctybob and Just Gary like this.
  8. AmishMike
    AmishMike
    Tried to help friend design some other way to attach a top. He had that stupid tab also.
    catdad49 likes this.
  9. Marty Strode
    Marty Strode
    Mike, my hero Dean Lowe ran a top on his RPU, I will have to see if he retained that tab. Meanwhile, I will hold off having a HAMB dunce cap made specially for you.
    catdad49, bchctybob, brEad and 6 others like this.
  10. Marty Strode
    Marty Strode
    well, Dean removed the tab, so you are in good company.
  11. Tim
    Tim
    from KCMO
    I can see the tab on the passenger side plane as day?
  12. Marty Strode
    Marty Strode
    Thanks Tim, I do see it. Jimmy Stevens retained his as well, so the Dunce cap is still an option. deanlowe1.jpg Jim Stevens Roadster.png
    catdad49, rod1, bchctybob and 8 others like this.
  13. Stan Back
    Stan Back
    . . . the only time I could get my front wheels off the ground was during an oil change.
    (What kinda plane was it? Jet, bi-wing . . . ?
  14. Dean Lowe
    Dean Lowe
    The tab is on my current RPU too. I think the tab is part of the brace for the door jamb. I have seen a car where the builder managed to get the tab off in one piece and have it chromed. Personally the tab dosen't bother me and painted is just fine.
    catdad49, bchctybob, bymanr and 5 others like this.
  15. AmishMike
    AmishMike
    I am so sorry, sitting corner with dunce cap on.
  16. AmishMike
    AmishMike
    But if u not plan on top - still don’t like the dam things. Growling in corner
  17. 427 sleeper
    427 sleeper
    You can sit in that corner and think about what you just said Young Man! No snack's or recess for you!!! :p
  18. AmishMike
    AmishMike
    Had gout attack yesterday so cannot eat lot of good stuff or work on car
    catdad49, bchctybob and brEad like this.
  19. Marty Strode
    Marty Strode
    Stay away from shellfish !
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'd keep the tabs... only if I were planning on a harness with arm restraints, iff'n you know what I mean.
  21. DDDenny
    Tart cherry juice (100%) is helpful, just went through a bout on my left big toe.
    catdad49 and bchctybob like this.
  22. Dean Lowe
    Dean Lowe
    If that was all I had to worry about I'd be happier than a pig in shit. :D
  23. Marty Strode
    Marty Strode
    The pedal pad showed up today, so I curved a piece of 1/4" aluminum, and got it finished. IMG_0817.jpg IMG_0816.jpg IMG_0813.jpg IMG_0814.jpg IMG_0808.jpg IMG_0811.jpg IMG_0805.jpg IMG_0802.jpg IMG_0800.jpg
  24. Tim_with_a_T
    Tim_with_a_T
  25. Marty Strode
    Marty Strode
    I finally got the seat belt mounts in today, used a piece of 1-3/8 4130 tube to span the width. Now I can put the seats back in so the cats will have a place to sleep at night. IMG_0901.jpg IMG_0900.jpg IMG_0902.jpg IMG_0904.jpg IMG_0906.jpg IMG_0908.jpg IMG_0907.jpg IMG_0903.jpg
  26. Larry Anderson
    Larry Anderson
    And the lettering? We’re waiting Mr Strode and you know what a struggle of a commute it is from my place to yours.
  27. bskustoms
    bskustoms
    from Aloha, Or.
    Bet the cats were irritated with no comfy place to sleep.
    catdad49 and tractorguy like this.
  28. Marty Strode
    Marty Strode
    They do like the seats you did Sam.
    catdad49 and brEad like this.
  29. bskustoms
    bskustoms
    from Aloha, Or.
    I'm glad
  30. Marty Strode
    Marty Strode
    I am back on this one for while. Since I decided to use the 2-1/16" injector on the Top Banana. I needed to set up the bell crank on the 1-13/16" unit, and get it connected to the throttle pedal. Now I can take it to Spud Miller (FIE) to get it checked out. This simple bracket turned into more of a job, because it needed to be built out of 3 pieces, to install it. Meanwhile the 331 Chevy is ready for assembly, and break in. My schedule is pretty clear of customer work, so I can focus on my own projects. IMG_1158.jpg IMG_1159.jpg IMG_1160.jpg IMG_1161.jpg IMG_1162.jpg
