Projects 17" tire dilemma
Discussion in 'Traditional Hot Rods' started by PhiltheThrill, Dec 10, 2024.
  1. PhiltheThrill
    PhiltheThrill
    tires.jpg I have 4 of the tires in the middle at 17” 525-550 and want 17” 750 in the rear but they don’t make them in the same tread pattern as the ones I already have. I want to run the 17” wheels and tires are expensive so don’t want to buy 4 new ones.
    Which would look better having matching brands with different tread patterns comparing the 2 on the left or similar tread patterns but different brands as in the 2 on the right?
    for reference I'm building a 30-31 coupster with a flatty with 32 grill and no hood
  2. NoSurf
    NoSurf
    IMO the tread will be more noticeable than the manufacturer logo.
    PhiltheThrill and Unkl Ian like this.
  3. Unkl Ian
    Unkl Ian
    Go with the ones on the right.
    If necessary, sand off the branding.
    PhiltheThrill likes this.
  4. 29Sleeper
    29Sleeper
    from SoCal
    You can have new lettering made up. There are companies that will buff off the lettering and add new. They've done it for several years for high dollar restorations where the original company no longer makes the tires. Now you can get DIY kits. Most of the lettering is in color so you'd want to dye them black before you add them. You could find some odd ball 1930/40s brand and use those. https://tredwear.com/tire-kits/branded-tire-lettering/
    Appearance of read doesn't matter much dirt and even pavement race cars had different tread front to rear.
  5. Hitchhiker
    Hitchhiker
    Here are your Balloon tire rears 7.50x17 and 5.50x17 firestone fronts.
  6. ct1932ford
    ct1932ford
    I’m running 5:50 x17” front with 7:00x 18” rear
  7. SS327
    SS327
    I thought 17” tires and rims weren’t traditional!
  8. Crusty Chevy
    Crusty Chevy
    The two on the right is the way to go. Diamondback Tires can shave off the lettering when you buy from them.
  9. PhiltheThrill
    PhiltheThrill
    thanks for the help guys, I'm going with the tires on the right
    Hitchhiker and Unkl Ian like this.
