Hot Rods Top Banana Style Slingshot Dragster- Marty Strode-Chris Kopp.
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Apr 7, 2024.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Is that all English Wheel or power hammer?
    porkshop likes this.
  2. Marty Strode
    Marty Strode
    Mostly Wheel, mainly because that’s the way he thinks Jack Hageman did the original.
  3. Johnny99
    Johnny99
    Excited to see it in person Marty. Almost would be a shame to cover that beautiful work with paint.
  4. Marty Strode
    Marty Strode
    We are going to leave it raw for at least one season !
  5. Marty Strode
    Marty Strode
    I get quite the variety of work, like today's example. Sometime back, I mentioned the ch***is repairs on a 1946 Italian Gran Prix Racer, Cisitalia D-46, with some history, as Zora Arkus Duntov raced the car a couple times in 1948. When bending the thin tube, it required packing them full of sand, and weld caps on the ends. The bends copied the sweep of the original lower frame rails, and fit quite well. One side down, and one to go, along with some crossmembers, and the X near the rear. The customer Ed Godshalk, finds the time to work with me on the projects, and we have fun. IMG_1511.jpg IMG_1128.jpg IMG_1131.jpg IMG_1163.jpg IMG_1164.jpg IMG_1165.jpg IMG_1172.jpg IMG_1175.jpg
    rod1, mad mikey, brEad and 16 others like this.
  6. Dave G in Gansevoort
    from Upstate NY
    Marty, when doing a restoration do you make the welds in the splices "disappear" by grinding? Or leave them to show that a repair has been made?
    tractorguy, RodStRace and porkshop like this.
  7. 1971BB427
    1971BB427
    from Oregon
    Wow!! That's quite a mess to straighten out Marty! I'm sure it will look like new once you're finished.
  8. alchemy
    alchemy
    It will definitely be interesting to see how much gets replaced. Does a big dent warrant replacement? Or just rust out?
    This is worthy of its own thread, you know?
    tractorguy, porkshop and Dick Stevens like this.
  9. I would struggle with a restoration. Knowing that you can do better would cause me grief to no end. :)
    Roothawg and porkshop like this.
  10. Marty Strode
    Marty Strode
    Jeff, some dents we can live with, as this will be a patina restoration, but we must fix the rust !
    SS327, mad mikey, dwollam and 5 others like this.
  11. Marty Strode
    Marty Strode
    Dave, I am going the replace the section job in the rear with one piece, because the other side needs to be placed as well. There will be very few but joints, and they will be ground smooth.
    mad mikey, dwollam, porkshop and 4 others like this.
  12. Marty Strode
    Marty Strode
    Val, it won't look like new, but he should be able to make some laps.
  13. Marty Strode
    Marty Strode
    It doesn't bother me, I did a belly tank for the same guy, and I love the character, of early construction, like this. IMG_7842.JPG
    brEad, rod1, mad mikey and 11 others like this.
  14. tractorguy
    tractorguy
    Marty......this will be a kinda dumb question. When I look at all that is going on with the ch***is, I'm sure that there are easy decisions when tubes are actually rusted out or severely bent. But how do you determine the strength ?......inner corrosion?......true thickness ?..... of all the myriad of tubes and structures that you are leaving intact and adding your new pieces onto ? I love this project and please please keep us watching.......it is going to be a long cold winter here in Wisconsin and Iowa......we need all the entertainment we can get !
    Tickety Boo and porkshop like this.
  15. Marty Strode
    Marty Strode
    Alan, there are no "dumb questions" here, the problem was, it sat on dirt floor, in a barn in Virginia for a number of years. I learned from the muffler shop, to use channel lock pliers and gently squeeze different areas of the ch***is. A lot of the tube used in this ch***is is .035 wall, so it was mighty thin to begin with. The car will only be paraded around and never run hard into a corner. With the space frame design, and well braced, I think it will be okay. He has a reproduction frame, but prefers to stay with the one with the serial # stamped on it. The aluminum body pieces are in very good shape, and resemble and American midget from the same era. IMG_1122.jpg IMG_1123.jpg
    SS327, mad mikey, brEad and 15 others like this.
  16. Marty Strode
    Marty Strode
    Making progress on the GP Racer. With both lower frame rails and some crossmembers replaced the gas welding will start. We should be working on sheet metal next week. IMG_1190.jpg IMG_1192.jpg IMG_1191.jpg IMG_1189.jpg
  17. alchemy
    alchemy
    Could you TIG and make a glob here and there to simulate a gas torch? All my TIG welds have globs.
  18. Marty Strode
    Marty Strode
    I hope I don’t have to, but it is an option.
  19. 1971BB427
    1971BB427
    from Oregon
    Coming along great Marty! A shame it was left sitting in the dirt, but it's at the right shop now and should be very cool once you're done!
    mad mikey, Marty Strode and porkshop like this.
  20. Marty Strode
    Marty Strode
    I finally tackled the X in the rear of the ch***is. Multiple angles and the need to be the proper length and height, but we got it fully tacked in place and ready to weld. IMG_1200.jpg IMG_1203.jpg IMG_1201.jpg IMG_1197.jpg
    brEad, ratrodrodder, rod1 and 15 others like this.
  21. mohr hp
    mohr hp
    from Georgia
  22. 1971BB427
    1971BB427
    from Oregon
    Wonder how many hundreds of feet of tubing went into that ch***is? Nice work too Marty!
    porkshop and tractorguy like this.
  23. Marty Strode
    Marty Strode
    When we bent up the rear X, we had a piece of tube left, sand filled and capped it, and bent it from each end. We wound up with 3" to spare in the middle, to make the 2 pieces. It was a close one !
    Tim_with_a_T, USMercUte and porkshop like this.
  24. Marty Strode
    Marty Strode
    They certainly were, as this was one of the first double tube space frames, with some complicated angles.
    USMercUte, porkshop and tractorguy like this.
  25. verde742
    verde742
    Marty, your projects are fantastic, Be glad I don't live in yer neighborhood, I am sure you would ask me to leave, I would wear out my visit with you, just watching and learning.
    BTW, are those Byman boys about the kindest guys, you will ever meet.... And the talent, and sooo many !!! All from the same Mom and Pop.... I have known Rich since he was sperm !!
    Have him share the story of "THE RIDE " tells it so good.....
    Bob.
  26. Marty Strode
    Marty Strode
    Bob, the entire Byman family are talented, kind, and special !
    verde742 and USMercUte like this.
  27. Marty Strode
    Marty Strode
    Getting to the end on this one, perhaps this coming week. IMG_1227.jpg IMG_1228.jpg IMG_1229.jpg IMG_1230.jpg IMG_1226.jpg
  28. Marty Strode
    Marty Strode
    Got it upright and a few more brackets tacked on. Better view of what it looks like with steering in place. IMG_1231.jpg IMG_1232.jpg IMG_1233(1).jpg IMG_1234.jpg
  29. alchemy
    alchemy
    Do you remove the remainders of the cutoff tubes from previous versions? Try to make it look exactly like the original? Or leave those stubs as a reminder of the life it lead?
  30. Marty Strode
    Marty Strode
    The 2 stubs at the front, are the base of a front hoop to support the nose. Once the car is together, and the nose mounted, I will install a new hoop. There are other places on the ch***is, where brackets to hold the side fuel tanks,
    will stay as part of the car's history. Ed is really sharp at what needs to stay and go.
