Technical 1961 Oldsmobile
Discussion in 'The Hokey Ass Message Board' started by deadbeat, Jan 21, 2024.
  1. deadbeat
    deadbeat
    Hey fellas, need some advice down here. My son in law and daughter have acquired a 1961 Oldsmobile 98 with a 394 engine. The harmonic balancer has fallen apart. We had a guy down here that could repair them, but unfortunately, he has retired. Any ideas where I can get them another one for. Im a FE guy and im just trying to keep young folk into old cars. Any info would be very much appreciated. Cheers
  2. GordonC
    GordonC
    These folks are a fountain of knowledge when it comes to Olds engines.
    Ross Racing Engines
    1763 North Main St
    Niles,Ohio 44446
    330-544-4466 w
    330-720-1282 c
    www.RossRacingEngines.com
    deadbeat likes this.
  3. Black Panther
    Black Panther
    from SoCal
    Damper dudes used to rebuild all types of harmonic balancers...theyre in California. I looked at their website and while they list Olds balancers..I don't see one for a '61..and no mention of rebuilding...so who knows if they still do that. Worth a shot..
  4. X38
    X38
    You could ask these guys at Power Bond, recently bought bought out by Dayco. They used to reman balancers, as well as manufacture new.
    A bit closer to home. I've used their products a few times.
    https://dayco.com.au/page.aspx?A=11326
  5. deadbeat
    deadbeat
    Awesome thanks fellas,will check them out,cheers
  6. KenC
    KenC
    I've always wanted to try this repair. Seems fairly simple but I'm probably not seeing the whole picture. Clean out all the old rubber, devise a fixture to hold and center the two other parts withing concentric tolerance (.001?) and fill the cavity with a urethane casting resin. They come in hard to soft formulas. One source
    https://www.mcmaster.com/products/two-part-casting-compounds/
  7. mongo4u2
    mongo4u2
    from sparta
    I have a few , with 2 V belt grooves , just marked them for storage
  8. rockable
    rockable
    I don't think that would work. The compound between the 2 halves of a balancer is under some serious compression. I don't think urethane that was simply poured in would last very long...if that long.
  9. deadbeat
    deadbeat
    Thank you for the responses. We ended up sending it to Damper Dudes in California. They were very easy to deal with and they turned it around in no time. I would seriously recommend them. Cheers
