Projects Hopeless T
Discussion in 'Traditional Hot Rods' started by Hopeless_hotrodder, Oct 17, 2023.
  1. A Boner
    A Boner
    Inspirational pic from the Hunert Car Pileup.
    jet996, chryslerfan55, Tim and 15 others like this.
  2. Jacksmith
    Jacksmith
    from Aridzona
    *****in'! That deep channel really does it!
  3. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    JD Squared air over hydraulic tubing bender with a 1” square die
  4. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    The windshield on this car is really throwing me off.
  5. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
  6. duecesteve
    duecesteve
    It's straight at the bottom.
  7. duecesteve
    duecesteve
    Saw this a couple weeks ago in New Hampshire Screenshot_20241117-111442.png Right now don't have a garage to put it in. :(
  8. The37Kid
    The37Kid
    NICE! You have a good eye, that back window enlargement is a huge improvement. Looking forward to more build progress. Bob
  9. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    I had to spend a week on another project but the last couple days I was able to hit it hard on “SweeTy”. I got the steering box mount finished, I was going to gusset it but I stood all my 200 lbs on it and jumped and it didn’t budge at all so I’m feeling very comfortable with it. I also finished the floor bracing and my trans crossmember so hopefully the next post I’m making is showing some floors. IMG_9525.jpeg
  10. Outback
    Outback
    from NE Vic, Oz
  11. The37Kid
    The37Kid
    Is that a Model T running board bracket above the bellhousing? [​IMG]
  12. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    No that’s a bar I bent up to give myself something to build off for the steering mount
  13. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    With all the major components mounted under the dash, trans crossmember made, and the rest of the floor bracing welded in, I was able to whip up a new firewall.
  14. Outback
    Outback
    from NE Vic, Oz
  15. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    I changed pace this week and decided to give my engine some love. So the plan is this being my initial engine while the engine being used as mock up right now is built. So the initial engine is just a stock 57 y block 272 ECZ-G heads. Nothing real special about it besides the stuff that I will be able to reuse like the edelbrock 3x2 intake, Mallory YC distributor and some cool valve covers I’m not even sure of what they are. Here some before during and after photos of cleaning stuff up
  16. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    It’s been a hot minute but here’s an update. I started working on floor structure, floor pans and building the trans tunnel/ floor pans to the firewall. Next up the pans will be getting bead rolled and I will finish building everything to connect and flow together.
  17. RodStRace
    RodStRace
    I'll mention something. I see a lot of beautiful bead rolls on floors. But what I rarely see is a wire channel like the OEs do to allow the wiring to have a little space to run. Either down the driver's side or down the middle for console electrics. Just a thought before you commit.
  18. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    I plan on this car having extremely minimal wiring inside. There won’t be anything beyond the dash and the taillights will be run inside the frame rails. I appreciate where your heads at tho!
  19. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Well I finally got some time on Sweety for the first time this summer. The floor is coming along nice after I s****ped the first trans cover I made. I got the sideburns finished out the way ol Henry should have done it from the factory. To help with motivation i went ahead and ordered my carb scoops from Nystrom Performance and damn those baby’s are purdy. I took 3/4 of an inch out of the windshield header and holy **** did that make a big change in her face. I have about 6 more weeks set aside to keep chipping away at her before she has to get put in storage for the winter to make room for a customer car. IMG_1229.jpeg IMG_1298.jpeg IMG_1229.jpeg
  20. Outback
    Outback
    from NE Vic, Oz
    Looking good! You are nailing the proportions!
  21. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Another 2 weeks, a bit more progress. Floors are finished from the seat forward. The steering box and pillow block are finished. To stick with moving the steering in the right direction I got my pitman arm made and ordered my tie rod to finally connect the cowl to the knuckle.
  22. AndersF
    AndersF
    Really nice work on the firewall and floor.
    Hopeless_hotrodder likes this.
  23. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Another week, more progress made. I have 1 month left before SweeTy has to be moved into storage and I have a few more goals to meet, so I can't slow down yet. This week the seat is in, steering column is roughed in to get a feel, the dash holes are all filled, and the dash is tacked into its proposed location.
    IMG_1427.JPG IMG_1438.JPG IMG_1444.JPG IMG_1447.jpg IMG_1455.JPG IMG_1456.JPG IMG_1463.JPG IMG_1467.JPG IMG_1468.JPG
  24. Tim
    Tim
    from KCMO
  25. Outback
    Outback
    from NE Vic, Oz
    Nice work fella!
  26. AHotRod
    AHotRod
  27. Jay Robison
    Jay Robison
    You're doing great! Gonn'a be a nice one!
  28. willymakeit
    willymakeit
    This is a very nice build.
    I just bought a t coupe and this is very close to what I am started on.
    Keep posting.
  29. Nailhead A-V8
    Nailhead A-V8
    chopped phone booth T's are cool but does anyone remember the "Tall T" fad of the '60's? [​IMG][​IMG]
  30. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    It’s been a bit since my last update because I was wrapping up a much of boring loos ends finalizing things but now I have some goodies to post. The steering brackets are done and man is it solid. The dash is welded in completely. Next up will be finalizing the steering column. Also while work has been a bit on the slow side, I took my door in to get it ready for primer. IMG_1602.png IMG_1601.png IMG_1600.png IMG_1603.png
