History Madis F Head on a Ford 6
Discussion in 'Traditional Hot Rods' started by Speedster, Dec 11, 2024.
  1. Speedster
    Speedster
    from Tacoma, WA
    Resized_Resized_20240326_130024_1717697471801_1717702996800.jpeg IMG_0742.jpeg Resized_Resized_20240608_152258_1717885746071_1717886794411.jpeg Resized_Resized_20240326_130033_1717697470941_1717702996610.jpeg I’ve posted before about this engine/head combination, but would like to know if there are any other complete engines out there.
    Mine is race prepped with the Madis Engineeting F aluminum head and dry sump pump/distributor drive. It also has billet main caps on crank journals 2, 3, and 4.
    This engine came out of a track roadster that was campaigned in SoCal by David McKindley around 1950. I think it’s a really rare piece of hot rod history, and internally it’s in much better condition than the exterior pictures would indicate. Resized_Resized_20240326_130024_1717697471801_1717702996800.jpeg IMG_0742.jpeg Resized_Resized_20240608_152258_1717885746071_1717886794411.jpeg Resized_Resized_20240326_130033_1717697470941_1717702996610.jpeg
  2. What a cool engine - I hope you get it rebuilt and running in the future!
  3. banjorear
    banjorear
    Dang. Talk about hen's teeth. That's rad.
    Toms Dogs likes this.
  4. Stan Back
    Stan Back
    . . . as I remember hearing (not so good) that when Henry finally let them build the flathead-6, it tested out at 90 HP. He had them change the rating to 80, so as to not be more than the V-8's 85.
    Here's Bill Freeman with a flathead Ford-6 in 1951 . . .
    tractorguy likes this.
  5. Budget36
    Budget36
    Pretty cool piece. I assume valves in the head?
  6. Mr48chev
    F head = intake valves in the head and exhaust valves in the block.
    L head= flathead aka side valve with valves in the block
    F head, Intake valves in the head, exhaust valves in the block. A lot of 50's Jeeps had these and they didn't make a lot of power.
    I head, aka overhead valve with both exhaust and intake valves in the head (s).
    Budget36 likes this.
  7. choptop4
    choptop4
  8. Speedster
    Speedster
    from Tacoma, WA
    According to the Hot Rod article about this engine, it made 31hp more than a flathead G series six. This was with the Madis head installed on a stock engine with no other performance modifications.
    Toms Dogs and Stan Back like this.
  9. Make mine the Edgy F Head in red like that pictured.............is delivery available?.........paypal o/k?.........lol....whatever happened to it?........is Earl or the Montana guys still playing with these?......andyd.
  10. Squablow
    Squablow
    An incredible amount of engineering to make that head, especially for such a limited run on an engine with virtually no other speed parts available. Very cool for what it is.
    tractorguy, Speedster and Budget36 like this.
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    As an aside, a company called Knudsen was big into these engines, and made aluminum flathead heads, intakes, and cast headers for them.
    Toms Dogs and tractorguy like this.
  12. HEATHEN
    HEATHEN
    from SIDNEY, NY
    This is the sort of engine that's worthy of building a car around.
  13. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Ford experimented with all sorts of heads on their sixes (and fours), all the while aware that good performing base engines may disuade buyers from poping for the optional V8s.
    A more recent experimental prototype:
    Stan Back, tractorguy and Budget36 like this.
  14. brading
    brading
    Is the head with the black rocker cover head a modified OHV head.
  15. Quoting @so-cal-speed-sacramento on this one.
    -Madis Engineering Co. was out of Bellflower CA. according to the ID tag, but state records don't show that the business existed; and least not under that name.
    -Madis made mostly parts for 1940s-1950s single-seater hydroplanes. I talked to a gentleman who used to own the Frankie's Boy racer, and he confirmed that there was a Madis oil pump on the front of the Ford G-series inline six. He also said that he has had a few boats with Ford inline engines running these over the years, but he was never able find any information on the company.
    -Supposedly, the pumps were designed with the different 'ears' on them so that they could be mounted to the timing cover in place of the distributor or a keyed-spacer could be used to put the distributor on the front of the pump.
    Here is an article from the March, 1951 issue of Hot Rod Magazine. You can see the pump mentioned in the article, but the engine being used a an H series, which uses a distributor off to the side rather than the G series with the distributor off of the front. These pictures were shot and the engine has been sitting in LA since. To the best of my knowledge, it was never actually run in a car/ boat/ etc.
    [​IMG][​IMG]
    tractorguy, Ducbsa and Budget36 like this.
  16. Speedster
    Speedster
    from Tacoma, WA
    That’s my plan. Well, not to build a car around the engine, but with the engine came Mr. McKindley’s “hot rod”. It has an 8BA in it with a lot of set back, so I tried the straight six in it and it fit with just enough room for a fan behind the radiator mount. He must of planned to install the Madis engine in this car. IMG_0626.jpeg
    tractorguy, RMR&C, Tim and 2 others like this.
  17. nrgwizard
    nrgwizard
    from Minn. uSA
    When you get into the engine, would you please post a few shots of the combustion-side of the head?
    TIA.
    Marcus...
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    factory experimental crossflow prototype - barely O/T to the HAMB era - never put into production
    pity
  19. Speedster
    Speedster
    from Tacoma, WA
    Will do.
  20. Speedster
    Speedster
    from Tacoma, WA
    IMG_0506.jpeg I pulled the valve cover and pan. Notice the billet main caps on journals 2 and 3. IMG_0537.jpeg IMG_0538.jpeg
    RMR&C likes this.
  21. brading
    brading
    Thank you for the that info.
