Why The Jersey Suede Can’t Get No Lovin’ This Year
Discussion in 'The Hokey Ass Message Board' started by 43gman, Jul 6, 2009.
  1. Muddi1
    Muddi1
    from Washington
    I would gladly pay 7% sales tax on parts or anything for that matter, we are at 9.7% for sales of anything that is not "Entertainment" and in that case "Entertainment" applies to the cold one after work, a Big Mac, Candy bars, Bottled water, as well as many other "non-essentials" as determined by state and county reps............10.3% :mad:
  2. KENDEUCE
    KENDEUCE
    Lance: I can relate to being too low. Paint is burned on top of gl*** fenders, and on 2nd set of tires, but I LOVE IT !!!
    I would like permission to use your quote (you know youre a real rodder when ...) as my signature line. What do you think?
    Outback likes this.
  3. Jersey Suede
    Jersey Suede
    from Joisey
    Muffler is a stainless "turbo" style but a shorty. I swear it's getting louder every time I drive it ... that's why I'm now building an interior for it ;)
    Thanks for the compliments!!
    Outback, 29EHV8 and kidcampbell71 like this.
  4. Jersey Suede
    Jersey Suede
    from Joisey
    KENDEUCE,
    No issue with using the quote. If anyone asks, just let them know where you got it from.
    I have to laugh every time I read about burned paint on fenders. Mine are steel so I hope they last a little longer than gl*** ones. I used Rhino bed liner material on the bottom side of my fenders and I never "planned" for that extra 2 mls. of material so clearance is a bit tighter now ;)
    Outback likes this.
  5. Jersey Suede
    Jersey Suede
    from Joisey
    ouch!!!!
  6. Jersey Suede
    Jersey Suede
    from Joisey
    I found a shot of the ch***is, and if you look real close, you'll see the muffler. And yes, I have an S-10 5-speed behind it.
    kidcampbell71 likes this.
  7. bobo
    bobo
    from New Jersey
    Nice work Lance. Love the super low stance. I feel your pain on taxes living in NJ.
  8. jersey greaser
    jersey greaser
    ouch on your near 10% sales tax rate, guess like ny state they even tax the much needed wiper paper?
    our problem is well known in the news papers .we have what they write as the worst realistate tax rate in the nation, it's a killer when living on a retirement check. takes me 4 of them to pay the bill each year. my lot is 100x125 one bed room ,one bath house,converated summer cabin with a 2 car garage, the bill is $7.000.00,only nice part is besides helping lance withhis builds. i love to fish,5 lakes with in a 5 min walk,stocked with walleye,b***, ****pie, muskie,channel cat, if i could still ski, i can walk to one of the 2 ski area's in about 10 mins
    traffic wise, i used to drive a big rig for the now long gone CARRETTA trucking , ny to ca and back 3 trips a month, driving here can be like or worse then driving around LA,Calif. driving at night is worse, people with night vision problems running illegal bulbs in the head lamps, illegal bulbs in the fog lamps and all on at one time. your blinded and still have to watch out for bambie, black bears and other big 4 leged animals.
  9. jersey greaser
    jersey greaser
    as lance posted it is a 5 speed BW t5 from his old s10 chevy pickup. we had some problems with it being to long in the nose area. the TO bearing collar hit the disc.and input shaft locked in the crank shaft. , the input shaft splines didn't allow the disc to release,
    a few old timer tricks. i learned from working with the late pappy hough from the former gasoline alley in patterson nj. a grinder, dremel and some files and we got it to work with out a spacer plate.
    it wasn't hard but what we did and how to get the clutch to release took about a hours work, the tricks we did is up to lance to release
  10. Cool, thanks for the hints and info!
    What bumpstick you running? it sounds killer idling!
    -Shiny
  11. Jersey Suede
    Jersey Suede
    from Joisey
    The stock marine cam is still in my engine. It has specs of 204 duration @ .050 lift and a valve lift of .498 with the 1.75:1 ratio rocker arms. The listing in the Isky cam shaft web site, for the Nova 153 inch motor, shows this cam has specs right between Isky's first 2 street cams which have durations of 202 and 208.
    Right off the top of my head I don't know exactly where the RPM range of this cam is, but it's something like 1400-5500 optimally. It's got a nice subtle overlap and revs up quickly.
    I figured I couldn't hide the fact (noise wise) that it's a 4- banger and I sure didn't want it to sound like a TUNER, so the combination of cam and muffler worked out in my opinion.
  12. jersey greaser
    jersey greaser
    the stock marine cam is ground to provide horse power in a 1200 to 4800 rpm band and torque in the 1200 to roughly 3800 rpm band. they will rev out to 5500 with ease.
    with the gearing lance choose. trans and rear, on the street it seems to be dead on perfect. he doesn't need to give it a lot of gas to get rolling, meaning one can roll into the pedal like any normal every day car, but if banged on ,it breaks the tires loose at will.
    again here are the link from gm on the marine engines specs
    http://www.gm.com/vehicles/innovati...s/specialized/marine/REV_2011_3000_Marine.pdf,
    industrial model specs
    http://www.gm.com/vehicles/innovati...lized/industrial/REV_2011_3000_Industrial.pdf
    take note here, if one uses a fork lift,generater,field water pump ver. of this motor, the cam shaft is ground to provide it's power at a max of 2200 rpm. while it has a higher compression right from the factory, "9.2 and 10.5 "as it runs on propane or natural gas. it's high torque low rpm cam is worthless in useage in a street rod. one most change the cam to a marine grind and use rocker arms that don't push the valves into the pistons.
    i do know for a fact the true flat top pistons with 9.2 to 1 compression clear the valves. i used these in building lances engine and they are used in the volvo and 2 other brand marine engines .I DO NOT know if the 10.5 to 1 slugs allow the valves to clear the pistons when useing a higher lift marine camshaft just yet, as i have still not seen one of these pistons.
    the main advantage to a fork lift motor, either right out of a lift truck or as a crate motor is the use of factory stock cast iron manifolds that allow a one barrel carb to bolt right down and a simple old style single down pipe for the exhuast. if one finds one with a 6 port head the 2 and 4 barrel intakes from clifford fit the head.
    if one wants to make a header stahl headers makes the flange and header kit, beware it is costly.
    http://www.stahlheaders.com/Frame%20New%20OT.htm
  13. lrapso
    lrapso
    from Costa Rica
    Great job, Nice truck
  14. boxstr
    boxstr
    Lance, happy new year, and congrats on getting the truck running and driving. Love the garage pics.
    I meant to get back to you on Xmas cards, but it just got crazy and I was to busy to think about it. I will order early for the Xmas.
    I am loving my truck. Pulled the seat and had it covered, added seat heaters, since that is all of the heat I have.
    Pulled the exhaust manifolds and jet coated them. Rerouted and wrapped the complete wiring loom front to rear.
    I have noticed s****ing on the top of the front fenders under neath. Fortuantely these are all metal.
    Craig, new owner of Dave Gales beater frog truck..
    Weedburner 40 and 05snopro440 like this.
  15. jersey greaser
    jersey greaser
    here is a up date on the pick up. lance has been busy rushing to get it done for cruise-in season and ready it is,
    check out lance web site and click on art in motion, sounds like a banger runs like a small block
    http://www.lancesorchik.com/
  16. Stu
    Stu
    Thanks for the engine info, I think one of those 4cyc whould work great for my wife's metro project
    Lance,love the truck(all your stuff)
  17. paintman27
    paintman27
    from new jersey
    WHOA!!!!!!!!!!!!!!!
  18. bonesy
    bonesy
    That is such a sweet truck!
  19. D ROD
    D ROD
    from New Jersey
    Looks even sweeter in person!
    Kudos Lance, enjoy it!
  20. rusty76
    rusty76
    from Midway NC
  21. 345winder
    345winder
    WOW,,,just came across the videos while surfing the net ! amazing lil truck! i am in love!
  22. IowaMercMan
    IowaMercMan
    Congrats to Lance on the photo spread about this little truck in Hot Rod Deluxe!
  23. brady1929
    brady1929
    sweet hot rod
    lothiandon1940 likes this.
  24. Lance,
    Any chance your friend over in Delaware might repop some more of those SS intake exhaust manifolds?
  25. earlyford
    earlyford
  26. Tim
    Tim
    from KCMO
    Just a bump to the top for a cool truck.
    And out if curiosity what front spring is on the truck? I may have missed it, I’m normally looking at the engine info in this thread
    Outback and kidcampbell71 like this.
  27. Jersey Suede
    Jersey Suede
    from Joisey
    Front spring is a Posies spring, nothing exotic!!
    chryslerfan55, Ron Funkhouser and Tim like this.
  28. Tim
    Tim
    from KCMO
    Thanks for the reply! Truck sits great!
    Outback and chryslerfan55 like this.
  29. Outback
    Outback
    from NE Vic, Oz
    Given this thread was tagged in another thread I thought it was worth a bump @Jersey Suede your 3 window coupe is what really kicked my interest in trad hot rods into gear, it was the article in American Street Rodder mag, it blew my mind as a teen! It is as cool as a cool thing!
    Just Gary, jet996 and lothiandon1940 like this.
  30. jersey greaser
    jersey greaser
    thanks for the bump.
    yes it's been around 15 years since i first met lance and helped him build that pickup. with it still being our most loved build. that motor still turns heads. how we got that 5 spd S10 trans to work without a spacer shocks many a mechanic, yes with a file and a cutoff wheel,
    yet in these past roughly 15 years he and i have along with this PUP ,built his wild 33 roadster, rebuilt his 32 vicky with the nail head, that no longer leaks oil or to put it like any old harley rider would say, about a panhead marked it spot. (yes with gaskets sold by speedway under the name best gaskets you can tightly seal a nailhead, so zero oil p***es between the head and block ) built the 29 real henry steel A bone sedan delivery he just sold, helped one of his teacher buddies finish the restoration of a 64 GTO convert, and now are doing another buddies 32 Todor sedan
    LANCE is always thinking more about the next build, I keep saying it's past time to start trashing on SUEDE, it needs to be shown again . lets refresh that old 56 OLDS engine, swap in a 5 speed in place of that saginaw , rewire it, just do enough to make it safer and enjoy it, before this 77 year old mechanic leaves the earth for hotrodder heaven
    NoSurf, Outback, lurker mick and 4 others like this.
