Hot Rods My 1935 Ford , sedan to 5 window conversion
Discussion in 'The Hokey Ass Message Board' started by aw1950, Sep 19, 2023.
  1. Wow...you're saving a rough one! When done, it'll be less a '35 Ford and more of a Lincoln ER70S-6!
    As a side request, when posting (and I look forward to your updates) please select full size images (it won't cost you anything and it makes it easier for those of us following along ;)).
    40FORDPU and aw1950 like this.
  2. aw1950 likes this.
  3. Had a couple hours to kill this afternoon. Worked on the damaged left rear fender IMG_1170.jpeg
    Squablow and tb33anda3rd like this.
  4. beater32
    beater32
    Man you are keen!
    aw1950 likes this.
  5. insomniacshotrods
    insomniacshotrods
  6. Was able to get some more work done in the last little bit hard to tell on the pictures as this is all inside the car tying the car all back together. The pillars are tied to the frame built subframe. That’s gonna divide the trunk in the interior compartment, not gonna be built like a 35 looks like inside, but this is a hot rod. It’ll look good but the purist won’t like it. My car my my car my way lol IMG_1216.jpeg IMG_1217.jpeg IMG_1218.jpeg IMG_1220.jpeg IMG_1221.jpeg IMG_1222.jpeg IMG_1216.jpeg IMG_1216.jpeg
    Squablow, tb33anda3rd and BigRRR like this.
  7. insomniacshotrods
    insomniacshotrods
    Looking good, every step is one step closer.
    aw1950 likes this.
  8. Out with the old crappy a pillar metal in with new 16gauge . A pillar is very stout now IMG_1223.jpeg IMG_1226.jpeg IMG_1227.jpeg
  9. IMG_1229.jpeg IMG_1230.jpeg IMG_1231.jpeg IMG_1232.jpeg IMG_1236.jpeg IMG_1233.jpeg Mocked up and built the rear catwalk area . Mocked up the trunk lid for inspiration and motivation. Onto something.
  10. More mock up today , staring to look in the right direction
  11. ronzmtrwrx
    ronzmtrwrx
    Man, I tip my hat to ya. That is a mountain of work you are in the middle of. As the old REO Speedwagon tune goes, Keep pushing on.
    aw1950 likes this.
  12. patsurf
    patsurf
    aw1950 likes this.
    So a new friend had a back half of a slant back that had a decent enough inner floor pan to work with and the quarters / rear panel that I will persuade into a coupe tail pan . He saved me $600.00 landed cost to be here in Canada . Have a look
  14. choptop40
    choptop40
    Holy Sheetmetal Batman.....
    aw1950 likes this.
  15. uncle buck
    uncle buck
    That’s some serious dedication to your goal of a 5 window! I don’t even want to tell you how many I cut up for a couple roadster and coupe patches years ago
    rod1 likes this.
  16. No, no don’t tell me , Geeze I don’t think I could take it LOL
    a few from recent , coming along
  18. More done , had to cut down two halves of a 36 hood . Modified to fit the 35 design rad support . There is a hole in the picture first one of two . They are both filled now plus I had to replace about 10 inches of the hood at the back to cowl area . Nice solid hood otherwise . Other pic is a repair on the window opening passenger side windshield. IMG_1362.jpeg IMG_1363.jpeg IMG_1360.jpeg IMG_1361.jpeg IMG_1362.jpeg IMG_1363.jpeg IMG_1364.jpeg IMG_1365.jpeg IMG_1366.jpeg IMG_1367.jpeg
    Squablow, tb33anda3rd, Chucky and 3 others like this.
  20. Been busy , roof filler as all welded in and ground . The whole top is now all welded up after the chop . Made up some floor pans and currently in process of installing . Have a look !
  21. tubman
    tubman
    I just ran across this. Unbelievable! Keep up the good work.
    aw1950 likes this.
  22. More updates , starting to mock up running board rear fender and rear apron repair before panel placement
    Squablow and Hot Rod Ron like this.
  23. More done or in process I should say . Tying in the quarter panel from door opening to wheel well reveal. Seeing that I don’t have the correct dies to roll the bead reveals along the bottom I am fabricating them instead . I will weld them on as seen in pictures . Stay tuned .
  24. More updates for you people who are watching along starting to tie in the sides of the car over to the trunk lead opening and using older sheet metal and as you can see in one of the pictures, newer sheet metal from an off topic style of car.
    Remember this car was a two door humpback and I do not have the correct rear section or pieces at all of an actual Five window coupe. So I have to improvise and I will have a one off 35 coupe clone stay tuned. This will be interesting. More updates to come.
    tb33anda3rd, Squablow and Copper Top like this.
    More showing the repair of the inner section of the wheelhouse . More to come
    Squablow and vtx1800 like this.
  26. patsurf
    patsurf
    you have sam barris looking over your shoulder!
    aw1950 likes this.
  27. tubman
    tubman
    Absolutely amazing work!
    From time to time, I run across a thread on the H.A.M.B. that blows me away. This is one of them.:cool:
    I visit quite a few online forums, but this is the only place I have found where you can see stuff like this.
    aw1950 likes this.
  28. Keep going you are killing it.
    aw1950 likes this.
  29. Thanks brother , stay tuned
