Hot Rods Wiring My Roadster
Discussion in 'The Hokey Ass Message Board' started by krylon32, Nov 23, 2024.
  1. krylon32
    krylon32
    from Nebraska
    Any suggestions from you Nebraska/Iowa/Kansas HAMB guys for a good reasonable shop to wire my deuce roadster next fall? Nothing fancy just the basics. I'm finding it difficult to find someone who understands the extra effort necessary to take the job from just ok to a higher level of finish. I've wired dozens. If I wasn't so old I'd do it myself but standing on my head under the dash isn't my idea of fun. May end up doing it myself?
    ekimneirbo, Tow Truck Tom and nochop like this.
  2. Tim
    Tim
    from KCMO
    Hmm not off hand maybe @CTaulbert knows of someone? Seems like the best bet would be finding a guy who builds and wires his own cars that is the correct level of **** and would take on a side gig to wire yours.
    I’ll keep thinking and let ya know if someone comes to mind.
    Just Gary and Tow Truck Tom like this.
  3. 19Eddy30
    19Eddy30
    from VA
    If steel , I find its so much easier to pull dash, even if there a dash tunnel & wire dash on bench & have the car
    16 -24 inches under all four tires & pull running boards if fenders ,
  4. Happydaze
    Happydaze
    32 I imagine. Why wouldn't you wire it with the body not fitted? I'd never have attempted this otherwise, and I hope I never encounter any problems! 20230302_145353.jpg
    Chris
    PONTNAK123, orbitup, clem and 6 others like this.
  5. krylon32
    krylon32
    from Nebraska
    Happydaze: I don't know about wiring but that's one dam interesting exhaust!
  6. 19Eddy30
    19Eddy30
    from VA
    Time , Time , " Exhaust"
    These are used for Tight radius turns ,
    You can use straight tube , & cut angles also , Will had more hours of fabrication
    & many more hours of welding
    Tig or Mig..
    Not including grinding welds down and polishing,,
    Fabrication Exhaust donuts.
    ***anium ,stainless steel ,mild steel & aluminum..
    @krylon32 all The Ch***is that you have done , & if you know how to Tig,
    When coming to wiring on a scale
    1 -10 , I feel the wiring would be a #4,
    skill level,,, simple wiring with Basic
    Power leads , Head , Turn , Brake etc.
    Shops around here , @ a shop , hourly
    Rate is commonly $175 -$250 Now !!
    Not just H -Rs , its all shops , D-D ,
    Big Trucks , Machinery. I do not get how average person can afford.
    & as we get older Not be able to do your self any more for what ever the reason,
    Maybe always been this way , expensive I guess I just never paid attention ,I was able to do most all myself and what I did not know ,traded work with others.
    A few weeks ago , On highway ,
    H O V sign's running along main Interstate , witch about 50 miles to Pentagon, its close to $50.00
    "one way"
    & $50.00 on return for D-D'ers .
    I was thinking ,
    " How much are the ones using Hov making a hour ?""
    Plus 87 octane being $3.00-3,40 gal
    Diesel $3.20- $3.60 gal.
    HOV @ One time was free for motorcycles &
    3 or more in a vehicle .
    I have lived same place for over 50 years
    Tow Truck Tom likes this.
  7. 19Eddy30
    19Eddy30
    from VA
    & over the Years , All cars I build ,
    I buid in a way I can take apart with ease,
    One example one 32 , I turn down
    Knurling on door pins So I can remover doors,
    Firewall, I replaced all spots welds , rivets on legs ,ect , So I can take out with out lifting body ,
    Steering column ,
    Floor boards ,
    Original seat,
    Gauge tunnel ,
    Wiring with Weather pack connectors
    Ect .
    Roadster same way .
    I would pretty much finish , then change
    Something up drastically,
    I guess I will not have a finished ride!!
  8. krylon32
    krylon32
    from Nebraska
    I just did a simple exhaust under a project deuce highboy. I've used donuts for years. For most of the years I built ch***is I employed a part time certified tig welder to do the finish work after I did the fabrication. Never could tig worth a dam. I can do wiring, done dozens of 32's. It's just something at my age I no longer enjoy. But if a simple basic roadster wiring job is gonna cost $4-5K I'll get it done. These new wiring kits make it a lot easier than when I had to fabricate my own. Next is to find the right kit? Toll roads even in neighboring Kansas seem expensive. going and coming south of Wichita to OK City and back was around $30. Just filled up with 87 plus at $2.79
  9. 19Eddy30
    19Eddy30
    from VA
    Tig , hit or mis , I tigged about 3 mouths ago,
    Takes little to get back in rhythm .
    My self , Not able to lay in a Vehicle like I wants did
    Head Under dash , legs over seat , getting a cramp,
    First kit I used was a S-W kit like 12 cir I think ,
    I thought Kit was decent quality, well marked every few inches , good for one's using steering column with functions , ( not me)
    Another car I had was a Rons , half pre wire , other was screw terminals, My thoughts was kind of bulky,
    Then painless , did not use ,
    A few other kits , Make sure read description of ,
    Some are mis leading .
    Since most I have do are 50ish older ,& especially pre-war , I just make all,
    ( No function, Naked column)
    Switch's Hidden under dash walking by,
    Visible in seat.
    There a company in I Believe Michigan that's a supplier for the OEM the companies name
    Wire Barn, I use there wire It has like 3 letters
    It has like a ponder feel to it & very flexible
    28 ga to like #2 ga thats reasonable.
    Some I used is cloth $$.
    I find best to set down , sketch out what power leads needed , location Before starting even with a kit ,
    Kit laying out on a table separating wires to the front, middle and rear.
    Do not make finale until your sue where wire needed to go ,,
    Check each Circuit/ Connection as you go
  10. Tim
    Tim
    from KCMO
    I think rebel wire seems to be the forum favorite
    osage orange, vtx1800, 325w and 2 others like this.
  11. chicken
    chicken
    from Kansas
    Gary, sent you a PM.
  12. nochop
    nochop
    from norcal
    I’m lucky my body is still getting prepared and in the paint shop so wiring is a little easier IMG_7150.jpeg IMG_7153.jpeg IMG_7128.jpeg IMG_7089.jpeg
    rod1, Hot Rods Ta Hell and warbird1 like this.
  13. krylon32
    krylon32
    from Nebraska
    I've contacted a couple shops here in Nebraska about wiring the roadster, neither returned my message. I'll be alright, I'll leave the hood, fenders, boards, doors and deck lid off, no seat or interior to work around. The dash insert is easy to remove. When I used to wire I was so dam **** about running the wires and keeping them in tight bundles. Always ran the front wires thru the frame etc. I'll [probably do all that again. My big issue is selection of a wiring package. So dam many opinions which is best. I want the best quality, best engineered, easiest to work with (kit) available. Cost isn't a big factor. I remember the kits I used in the past had such small writing on the wires I had to use a magnifying gl*** to read them so I could tag them with masking tape. If I find the right wiring kit I'll do this myself, may just take a little longer. Oh yea, I used to make my own wiring kits from bulk rolls of wire.
    1oldtimer, seb fontana and warbird1 like this.
  14. 51504bat
    51504bat
    Lots of choices for wiring kits. I've used Rebel kits for my '39 p/u and '54 Ranch Wagon with no issues. Good tech support as well. AND USA made. JMO
    Edit: Plus I believe Rebel is an Alliance vendor.
    Tim and Just Gary like this.
  15. bodymanmp
    bodymanmp
    E-Z WIRING KIT WORKS GREAT
    curbspeed likes this.
  16. PotvinV8
    PotvinV8
    Put the fuse panel and other ***orted stuff in the trunk behind the seat. I've wired a couple roadsters that way and it works great. I use Coach Controls Roadster 18-circuit Kits for the simple stuff. They offer a "long wire" option on all their kits and I've never had a problem putting the panel in the trunk, even on full-size cars. Mount everything on a 1/4-inch sheet of ABS on your work bench and go from there! Ship the car to CA and I'll do it for ya! :D
    Here's one example that I did on Joe Kugel's AMBR Roadster from 2022...
  17. seadog
    seadog
  18. ct1932ford
    ct1932ford
    I always put it on paper color coded then just follow.
  19. 325w
    325w
    Around here FtWorth acouple of guys who will do wiring charge $100 a circuit
  20. krylon32
    krylon32
    from Nebraska
    Ouch: The one shop that did respond wanted $3000 up front plus the cost of the wiring materials. With the balance when the job is finished. Wouldn't say what he thought the end balance would be. I'm getting more enthused about doing the job myself.
    PONTNAK123 and Happydaze like this.
  21. 05snopro440
    05snopro440
    If he charges $150, that's 20 hours just to start with. ***uming ignition, gauges, and lights, 20 hours to do a quality job of wiring a basic roadster seems generous for a shop that should know what they're doing.
  22. Hotwyr
    Hotwyr
    I also vote for American Autowire although A customer brought in a basic kit from Speedway that I could swear was AA manufacture. I usually figure 40 hours for a basic hot rod job. Give or take depending on add ons.
  23. bill gruendeman
    bill gruendeman
    I wired my dash on the bench and put some plugs ends on the harness. Now when the dash is mounted I have 2 plugs to plug in, I am to old and fat to lay upside down under the dash.
    panhead_pete and Happydaze like this.
  24. dart4forte
    dart4forte
    from Mesa, AZ
    Going to depend on what you plan on running in the car. If it’s a simple build the a 12 circuit setup is the way to go. Speedway sells the EZ Wire kits. Easy to lay out, has a checklist you can go buy for all the major circuits. When you start adding stereos, AC, and other bells an whistles then it becomes more extensive.
  25. RICH B
    RICH B
    Don't overcomplicate it; a basic hot rod doesn't need multiple circuits, fancy panels, and wires of many colors.
  26. dart4forte
    dart4forte
    from Mesa, AZ
    Agree
    firstinsteele likes this.
  27. krylon32
    krylon32
    from Nebraska
    I'm a gambler and sometimes a bit conservative. I'm wondering if the 12 circuit wiring kit that Speedway sells for about $150 is worth a dam or not?
  28. RICH B
    RICH B
    I wired one into a Model A once. While it worked OK, I felt the wires were on the small side; but then again so are most kits. Also re-arranged how the wires that exited the panel for better routing.
    Blues4U and 05snopro440 like this.
  29. 05snopro440
    05snopro440
    This one? Simple 12 Circuit Wiring Harness Kit with 12v Fuse Block
    It has 332 reviews, the majority of which are 4 or 5 stars. A lot of people seem to like it.
    I've used Painless and really like them. I have this one on the shelf for my roadster. Painless Performance 10308 18 Circuit Modular Wiring Harness
    There's a price difference of less than $100 currently. What I like about the Painless harness in this case over the Speedway is that the circuits aren't pre-terminated at the fuse block. That will save you a bunch of time rather than having to re-organize the pre***embled harness as provided by Speedway.
  30. 05snopro440
    05snopro440
    That's nice and tidy.
