Projects Rear/Mid Engine 1927 T Roadster
Discussion in 'The Hokey Ass Message Board' started by Noah*, Oct 4, 2024.
  1. 1971BB427
    1971BB427
    from Oregon
    Yes you have the freedom to comment. But it adds zip to the topic, and if anything detracts from it. How about not nitpicking and just watch the thread if you don't have something positive to add to it?
  2. Noah*
    Noah*
    I changed the ***le to Rear/Mid so everyone is right
  3. alchemy
    alchemy
    How about a Duvall type windshield to give your nose a little more room?
  4. Noah*
    Noah*
    It's center steer, so the divider bar would be in my line of vision. May make a brooklands style windscreen
  5. dan c
    dan c
    *****in! i'll bet a lot of us old guys read your ***le and remembered "v-rods"!
  6. amodel25
    amodel25
    Why not refer to it as a "misplaced engine" and drop the subject. This is a post about a cool project....not about automotive dialogue. Keep us up to date on your progress!!!
  7. justabeater37
    justabeater37
    Or something a little racier if we are building his car in our mind...Radius the front edge of the ****pit to follow the rounded windshield. But I am thinking he has a plan of his own and we will all impatiently wait for the results[​IMG]
    Stogy, Outback, Okie Pete and 2 others like this.
  8. krylon32
    krylon32
    from Nebraska
    I may have missed it but did anyone mention Cotton Werksman from Ill? He built one back in the 70's that the build was followed in I believe Rod & Custom? I think he had a Hemi or maybe an Ardun flathead in his. Been a long time, memory not so good.
  9. 34Phil
    34Phil
  10. 1biggun
    1biggun
    I had a chance to get a reverse rotation SBC out of a boat awhile back and was envisioning running a transmission or short drive line under or over the rear end flipped around with a off set diff for clearance into a gear box made to hold a set of quick change gears with one gear connected to the back ward diff . kind of like a V drive boat .. Likely a stupid idea but I was thinking hmmmmmmmo_O
    Looking forward to seeing how this project goes . I always liked the back engine drag cars like this .
  11. gimpyshotrods
    gimpyshotrods
    Ok, but only of you do the same.
  12. gimpyshotrods
    gimpyshotrods
    No need for reverse rotation powertrain, save for the novelty.
    Winters makes a quick change with the ring gear on the other side, and gears cut the other way. It's intended to be in the front of an AWD car.
    I have on in the rear of my mid-engine A, with the engine in backwards.
    GN axle tubes can be had at up to 48" in uncut length, and axle shafts can be had off-t******lf to go farther than this if you want.
  13. 1biggun
    1biggun
    My thoughts were to get the transmission out put over or under the rear end to move the engine back .
    So I'd need a set of gears or chain to connect to the pinion shaft
    That said i have not really thought it through much.
    I don't want to muddy up this thread with my half *** idea.
  14. swade41
    swade41
    from Buffalo,NY
  15. snoc653
    snoc653
    from Iowa
    V-drives might work, they also make a Z drive that goes in the front top or bottom and comes out the rear opposite shaft bottom or top depending on need. If he needs measurements on a v-drive, I have a top loader Casale box (12 degree vintage box from the early 60s) and a modern Casale (10 and 12 degree drives).
  16. 1971BB427
    1971BB427
    from Oregon
    I haven't been arguing the engine location? I simply asked the debate to be stopped.
    seabeecmc likes this.
  17. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    This build makes me think of one of the Oilers cars. Don't know the owner but I remember seeing this car in a few photos over the years.
    Okie Pete and Robdski like this.
  18. Jermey Baye owner of 1945 Speed and Custom Troy NY
    rod1, alanp561 and stubbsrodandcustom like this.
  19. Tim_with_a_T
    Tim_with_a_T
    Just found this thread - if it turns out anything like your coupe, this is gonna be a treat to watch!
    Outback likes this.
  20. Elmo Rodge
    Elmo Rodge
    Regarding the no suspension deal at Bonneville, that's how I've been running lately. No engineering is better than bad engineering. :) Flathead powered tank, unblown on gas. 190 in October. Back to your previously scheduled programming. 2024 Finals Run.jpg
    RodStRace, rod1, alanp561 and 15 others like this.
  21. Elmo Rodge
    Elmo Rodge
    Noah, whether it wins the AMBR or not, it's a winner at my house. ;)
    Wayno
    Stogy, SilverJimmy and Noah* like this.
  22. AccurateMike
    AccurateMike
    '63 Tempest style ?
    Kind of like hanging the trans off of the back of the quick change. Mike
    Okie Pete likes this.
  23. jivin jer
    jivin jer
    We are convinced that you can do it. How about just a pic of those hands//
  24. Blue One
    Blue One
    from Alberta
    You’re too old for the high boots and they’re already full from your own spouting.
  25. Gofannon
    Gofannon
    NZ's Stanton Corvette.
    Ned Ludd, Scott079, chrisp and 2 others like this.
  26. Bandit Billy
    Bandit Billy
    I like the entire concept, regardless of semantics, but where do you plan on putting golf clubs? Maybe offset the engine to the right (always lean toward the right) and the sticks can fit behind the driver? Beers will have to go up front.
    1low52 likes this.
  27. Noah*
    Noah*
    Made all the parts for my tail panel, here it is mocked up. 20241219_195234.jpg 20241219_195253.jpg
  28. patsurf
    patsurf
  29. Ebbsspeed
    Ebbsspeed
    If it's mid-engine, is the engine really in backwards?
    gimpyshotrods likes this.
  30. gimpyshotrods
    gimpyshotrods
    Yes. The proper designation does not take into account the direction of the powertrain.
    It's not front wheel drive (it's AWD), and I don't drive it backwards.
    Okie Pete and TrailerTrashToo like this.
