Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. NealinCA
    NealinCA
    Still no engine in the car, so time will tell. It was way too soft and low before, so it bottomed out really easily. It also had original 32 rear shocks that were supposed to be rebuilt, but leaked out with in the first 100 miles. When adding the extra leaf, I also added bump stops and have a pair of new Rotoshim shocks on order for the rear. I am happy with the way the Rotoshim front shocks performed, so looking forward to driving it with the extra leaf and new shocks in the rear.
    The goal is to get it back together with the lavender engine for GNRS, so probably won't put any miles on it until after then.
    31chevymike, brEad, RMcCulley and 7 others like this.
  2. banjorear
    banjorear
    Looking good as always. Extra leaf does look more little page-y.
  3. pprather
    pprather
    Looking forward to seeing it in person at GNRS.
  4. alchemy
    alchemy
    For bumpstops I like 48 Ford rears. They have a hollow middle so they’re more cushiony than 32 or 34 style. But you do need to drill a center hole for mounting instead of the two ears like a stock 32 has.
    31chevymike, porkshop and Tim like this.
  5. Dubonet Garage
    Dubonet Garage
    from France
    31chevymike and porkshop like this.
  6. NealinCA
    NealinCA
    Hmmm...maybe that is why the front wheels are at the tire shop today, swapping 5.00/5.25's for 5.50's...but you never know. Haha
  7. Dubonet Garage
    Dubonet Garage
    from France
    Brillant !
  8. NealinCA
    NealinCA
    Worked on the firewall again today. I wanted horns on the firewall, kinda like these... 184505776_1467015170357519_4002978370334362531_n.jpg Screenshot_20241221_180340_Instagram.jpg
    I rounded up some 49-51 Ford horns and 39 Ford brackets. To mount them, I used original style 12-24 clinch nuts. I hadn't used these before, but were fairly easy to install once I figured out the process. You need to make a D shaped hole. I drilled a pilot hole, then used a carbide burr and a flat file to make the shape.
    Then used a ballpein hammer to start the swedge and finished it off with a flat face body hammer
    Here is the firewall with accessories in place
    I also added the threaded inserts for the voltage regulator
    As well as the Kugel stainless hood prop brackets
    Horn details
    Now the firewall is ready for paint
  9. Outback
    Outback
    from NE Vic, Oz
    Love the details Neal, did you make, buy or recover the clinch nuts? They are a very nice detail
  10. NealinCA
    NealinCA
    They are readily available from most Model A/Early Ford suppliers in various sizes. Here are some 12-24 like I used:
    https://www.mikes-afordable.com/product/12-24.html
  11. Outback
    Outback
    from NE Vic, Oz
    Thanks, I've seen them but hadn't thought they might be available
  12. NealinCA
    NealinCA
  13. Outback
    Outback
    from NE Vic, Oz
  14. NealinCA
    NealinCA
    Got a Christmas present from Sherm's plating.
    I stepped up on these and am very glad I did. They look amazing.
    Here's a quick mockup on the car
    But they are going back in my office until right before GNRS. Too nice to have on the car while we are still installing engine, trans, exhaust, etc.
  15. Grumpy ole A
    Grumpy ole A
  16. tim troutman
    tim troutman
    still watching nice photos from hop up congrats. love the new chrome
    31chevymike, Stogy and porkshop like this.
  17. HotRodJoe454
    HotRodJoe454
    Nice job
    31chevymike, rod1 and Stogy like this.
  18. NealinCA
    NealinCA
    Lavendeer engine update.
    I got the leaky front seal replaced and the bottom end sealed again.
    I am pretty confident the valve noise we heard was caused by two lifters backing off. With the Potvin 3/8 cam, the lifters have to extend pretty far where the threads can start getting loose. I pulled the two valves and replaced those lifters with two tight ones, so hopefully that issue is solved.
    While the head was off, I clayed piston and valve clearance again. I had originally cut the valve pockets on both heads at 7 degrees. In my mind the bigger angle would be good for both sides, but that puts the lower edge of the valve closer to the head on the p***enger side. I decided to come back and take a light cut at 4.5 degrees to match the valve angle. It probably doesn't make much difference but it makes me feel better about it.
    With that all done, we got the engine back in the test stand. I just need to buy a new ignition switch, wire that up and fill all the fluids.
    Hopefully second time around with this engine proves successful
  19. dwollam
    dwollam
    I had 1 adjustable lifter in my 286 flatty stroker that kept backing off. After pulling the intake twice to adjust it, the 3rd time I pulled the intake and let it set open few a few days, covered everything up, adjusted it, then zapped it a couple times on the threads with the MIG welder! Crude? Yes, but effective. Been years now and no clatter. I had previously tried red loc***e with no success. Your way of course is better but I didn't want to pull the head.
    Dave
  20. Great job on the build thread Neal. Thanks for taking the time to share. Very enjoyable!
  21. Stogy
    Stogy
    Congrats on the Milestones Nealin and yeah...you have a way with these vintage beauties...its a stunning Hotrod...
  22. Tim
    Tim
    from KCMO
  23. NealinCA
    NealinCA
    Happy New Year to all!
    I did some shop maintenance projects today. One was my continued effort to replace the flourensent lights with LED fixtures. I installed some more 2' x 4' panels in my machine shop area. These panels are designed to drop into T-bar ceiling, so I made up some sheet metal brackets to hang them between the joists.
    With a shear, brake and punch they were pretty quick to make. 20250101_151504.jpg 20250101_151520.jpg
    It is lit up pretty well now, which really helps with my 57 year old eyes.
    I wasn't happy with the stance the car had when I took it to Oklahoma.
    I added a leaf front and rear and went from 5.00/5.25-16's to 5.50-16's up front. I like the rear showing some blackwall. The front stance is still up in the air until I get the engine back in.
  24. Tim
    Tim
    from KCMO
    Lights look fantastic, I like the rear being raised up a bit as well.
  25. atch
    atch
    Yep; rear looks 100% better. Kudos.
  26. Equipped28
    Equipped28
    Tons better! Such a great car
  27. Grumpy ole A
    Grumpy ole A
    Lights are excellent. They will definitely make working in there much easier. The car is looking good, keep up the good work and keep us posted.
  28. richard noble
    richard noble
    Took me all evening to read this thread, don’t know how I missed it before. Your car is absolutely perfect Neal and congratulations on the Hop Up spotlight, well deserved. I would love to see this car in person, someday……
  29. Tumblin' Dice
    Tumblin' Dice
    from Las Vegas
  30. dirt car
    dirt car
    from nebraska
    Nice rear tire to fender gap now, I wondered if the tires were contacting the fenders before.
