Technical LAs Totally Awesome cleaner, anyone boil it?
Discussion in 'The Hokey Ass Message Board' started by JD Miller, Dec 16, 2024.
  1. JD Miller
    JD Miller
    I bought couple gallons of Awesome. Worked great cleaning a Q jet (top) Air horn. Poured a half gallon in a plastic kitchen tub and just scrubbed with a tooth brush. Worked frickin great and fast
    Has anyone boiled Awesume in a pot like a hot tank. I wonder if it will foam up, over flow and make a big fuggin mess.
  2. DDDenny
    Gonna look like cousin Cletus' last Thanksgiving turkey deep fry'n fiasco!
    hotrodA and JD Miller like this.
  3. Jmountainjr
    Jmountainjr
    I can't comment on Awesome, but I do heat and also boil Simple Green with no issues. I use a single burner electric hot plate and a stainless stock pot. Usually use the Simple Green full strength for stuff I want really clean.
    alanp561 likes this.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Totally awesome is the best cleaner ever. And cheap too. I even use it to spray on laundry stains. Works on everything but dried paint.
    Have not heated it but I’d give it a go.
    Let us know if you blow up. :)
  5. RodStRace
    RodStRace
    ClayMart likes this.
  6. JD Miller
    JD Miller
    Yeah,,,,, sheet like that :eek::D:D
    There was a old post by F.O.G. years ago, He said he boiled Awesome in a crock pot with carburetor parts. But looks like he hasnt posted in a few years
  7. tubman
    tubman
    How would this be for soaking carburetor parts for rebuilding? Anyone had any experience with it?
  8. Matt Dudley
    Matt Dudley
    from New York
    I learned a trick with lemon juice in a pot of water, and boil that from motorcycle guys. Works great. Caveat it will pull off a zinc coating if it has one
  9. 1952henry
    1952henry
    Usually cleaners work better warm. I have an old crock pot I use for this. I throw in some Phosphate free TSP in water for degreasing small parts and fasteners before zinc plating them.
  10. Mr48chev
    I've been thinking about putting the Totally Awesome cleaner in my solvent tank as it is cheap enough to do it. I use it to clean parts and use it in the house to do squirt bottle cleaning. I haven't tried cooking a carb in it though or soaking one in it.
  11. 1952henry
    1952henry
    I would try a s**** carb body. Some chemicals don’t play well with zinc die cast.
    SS327 likes this.
