Folks Of Interest Magic Welder?
Discussion in 'The Hokey Ass Message Board' started by krylon32, Dec 16, 2024.
  1. seb fontana
    seb fontana
    from ct
    I can arrange that!
  2. tubman
    tubman
  3. Damon777
    Damon777
    We have a laser welder at work. I ***ure you that it was more than $100.
    We are looking at it to replace MIG in our production processes. Sheet metal fireplaces, thinner gauge cold rolled and some stainless.
    coast40, mad mikey and Moriarity like this.
  4. lostone
    lostone
    from kansas
    Invertor technology is the future, the Chinese have been messing it for years and now to the point where they produce and sell it cheap.
    It's smaller, lighter and definitely more efficient. Lincoln is now starting to produce smaller inverter welders but their starting point is 1800.00
  5. abe lugo
    abe lugo
    All this chatter in the ****ty welder.
    where is the ****ty rust remover laser? Def try for 100.00.
    coast40, Squablow and williebill like this.
  6. Damon777
    Damon777
    I guess ours will remove rust with an optics change. IIRC it was about $40k
    seb fontana, abe lugo and alanp561 like this.
  7. twenty8
    twenty8
    Man, that's a whole heap of wire wheels right there....o_O
    Squablow and Damon777 like this.
  8. blue 49
    blue 49
    from Iowa
    I had 1 of their 110 benchtop welders and used it quite a bit. I made a clutch slave cylinder bracket for my 1st engine swap and it never failed. I think I was still using it when I built my engine stand. You had to use small rod.
    Gary
  9. JD Miller
    JD Miller
    Magic Welder ..... hunert dolla magic tig welder....you betcha ...... I wanna getz me one fo sho ..... :confused:
    LOL !
    seb fontana, mad mikey and alanp561 like this.
  10. oldolds
    oldolds
    Even if that welder works, those little rods will be frustrating. They weld about 3 inches at a time. Most of us weld for miles on a car. :D
  11. tubman
    tubman
    Need I remind you that there is a huge difference between Consumer Electronics and Industrial Products.
    Production quan***y makes a insurmountable difference. When I did my 12 volt to 6 volt tachometer driver, we had a unit cost for a run of ten of $150 resulting in a market failure. My partner (who has been in more than a few joint electronics ventures) tells me that the cost would have been less than 1/10 our cost if done by a commercial operation in reasonable quan***ies.
    clem likes this.
  12. snoc653
    snoc653
    from Iowa
    These inexpensive welders aren't intended for serious jobs. I used to carry baby Oxy/Acetylene tanks when we went out 4 wheeling. People dismissed the little alternator ran welders when they first came out. Now days, there are more generator powered welders than you can count on a rock crawl. This welder running on an inverter would do just about the same level of field repairs. I wonder if they make a chinesium plasma cutter so I can leave the blue wrench home when I take the car out to play.
    2devilles and alanp561 like this.
  13. Back in the 60"s the back inner cover of guy magazines use to advertise a welder for something like 9.95. My cousin bought it. Saved me 9.95. You couldnt get it to start a bead. I see that modern miracle welder to be the modern version of beating a guy out of 100 bucks. See if you can get your cousin to buy one.......
  14. Matt Dudley
    Matt Dudley
    from New York
    If it’s actually a little stick welder, the inverters are quite powerful. The drill style would for sure be awkward but for sure would ‘work’. No it wouldn’t be worth $100 tho.
    https://www.ebay.com/itm/1766315092...LbHiqsvR--&var=&widget_ver=artemi***edia=COPY
    This is what I have and on 220v, it’s actually a really nice machine to use. Other than needing to buy longer leads for it which were another $30. I only paid $62
    coast40 likes this.
  15. K13
    K13
    There are lots of "reviews" of them on YouTube. I watched 5 or 6 of them. Of those two commented on the unit continually tripping breakers and one the machine smoked itself. None produced welds that didn't look like **** and they all looked like the struggled handing the unit which may explain the weld quality to some extent. A couple tested it's output compared to stated rating and they were quite a bit lower than what the manufacturer claims. The units tested topped out at about 95amps compared to rated 120. I would imaging the same would be true for its duty cycle which they claim is 20%.
    Like I said in the beginning it looks like you get what you pay for. It would probably work in a pinch for an emergency repair like on a trail with a generator but not something to relace a day to day welder.
  16. Hemi Joel
    Hemi Joel
    from Minnesota
    I looked that welder up. It's battery powered arc welder with a little battery like what runs your cordless drill. Arc welding uses a lot of power. You could probably get an inch, maybe an inch and a half of weld before you had to change the battery. In an a video on YouTube, you never see them weld more than an inch without cutting to a different scene. I suppose that is when they are changing the battery.
  17. ALLDONE
    ALLDONE
    bout 30 plus years ago I made a couple welders..... wasn't that hard,... in fact I thoroughly enjoyed it and did it again... 75642841100__5AD51F8D-9AC4-43F2-B124-82CBB25C4DD1[9453].jpg 75642841899__48141E64-ADC5-4CB5-BF37-3AA5CB5483DA[9454].jpg
  18. K13
    K13
    They are not battery powered. They run off 120v.
    2OLD2FAST likes this.
  19. duecesteve
    duecesteve
    Alumilloy I think they were called
  20. Beanscoot
    Beanscoot
    Here's the last weld the guy made in the video using the Chinese POS:
    Looks awful, eh?
  21. Did it break?
    Ben
  22. Beanscoot
    Beanscoot
    It looks solid, but I don't think he tested it in the video.
    The video sure had stupid music though.
  23. Rodsports
    Rodsports
    This made me laugh - cl***ic, I could visualise the solder melting in the feed tube and the drop in shoulders that would have followed . We’ve all been here in some way shape or form….
  24. BJR
    BJR
    I don't!!!! :eek::eek::eek:
    2OLD2FAST and seb fontana like this.
  25. 73RR
    73RR
    Update on the $50 hand held welder. Yeah, I bought one, figured that if it worked at all it might be handy for small quicky jobs. Hey, it actually works! Tops out at 122amps but does not like 1/8" 6011. Runs 3/32 just fine so I'll keep it for the odd jobs offsite when a 20A circuit is available.
  26. 2devilles
    2devilles
    Would I buy it to replace my mig and stick welders in my shop (ok, garage)? No. But would it be handy to throw in the trunk for a multi hundred or thousand mile trip "just in case" to fix something at a hotel or anywhere else with an extension cord just so I could keep going? Hell yeah. Probably get one just for that, because I drive my ****. A lot.
    coast40, lostone and 73RR like this.
  27. I have bought Saker products and or had been gifted this brand in the past. Everything that I have had first hand is ****. I will not purchase anymore of their products even if it came with a Genie
    Vic
    coast40, ekimneirbo and Moriarity like this.
  28. theHIGHLANDER
    theHIGHLANDER
    3 Millers in my shop. Funny thing is, they've been there for over 35 years. All work exceptionally well for my needs. I don't care what video, sale, endor*****t, net topic comes up I'm not changing. This whole gig reminds me of that "miracle" rod they sell you at swap meets where they weld pop cans together, and when you get to the shop it doesn't stick to a ****in thing. Yes, I bought some once, still have it laying around to remind me, NEVER AGAIN. There may be more than 1 way to skin a cat but there will always be only 1 way to do it right.
    TrailerTrashToo and Moriarity like this.
  29. Intriguing as a trail repair welder for the 4x4 crowd. If I'm home, I'm using a real welder. And when I say real welder, I mean my Harbor Freight Vulcans lol. 445609470_504157141945822_7004603713483006274_n.jpg
    coast40, lostone and 2OLD2FAST like this.
  30. 73RR
    73RR
    Like some others, I have 2-MillerMatics, 3-stick machines (one is an Airco I bought in the early 70's) and a gas powered Lincoln, but this hand held job is not intended to replace only to support the others. Will it get much use? Dunno, haven't had it long enough to figure out its place in the scheme of things.
    The interesting thing, at least for me, is the vast number of really small inverter type machines available. I hadn't had any occasion to look at such units until this thread popped up so that has been informative. No, no more machines needed here but what an estate sale my Niece will have someday.:confused:
    coast40 and X-cpe like this.
