Hot Rods 1932 Tudor doors on a 5w ?
Discussion in 'The Hokey Ass Message Board' started by wildwest, Dec 19, 2024.
  1. wildwest
    wildwest
    So, years ago I remember a chopped highboy Model A 30-31 coupe with the longer sedan doors on it.
    Has anyone ever done the same thing with a 32? I know it would take a longer wheelbase ch***is, but surely somebody has used Tudor sedan doors with a 5 window coupe rear half, to make a long-door 32 Coupe ?
    Just curious if photographs exist of such a monster ?
    porkshop likes this.
  2. The37Kid
    The37Kid
    Years ago there was an unfinished project on a trailer at Hershey that Posie had built or started. Looked like a combination of a Coupe or Vicky, somebody may have photos.
    Bob
  3. 19Eddy30
    19Eddy30
    from VA
    Off top of my head with out measuring between the two , 2dr sedan is 10-12 inch longer maybe more then 5 w, if no one post a measurement later on I can take a measurement
    porkshop, mad mikey and Just Gary like this.
  4. Corn Fed
    Corn Fed
    Good lord I hope you don't find any pics of a real car that had it done.
  5. krylon32
    krylon32
    from Nebraska
    I built a really nice chopped 5 window a few years ago but sold it after a year cause these old bones just could;t get in and out easily. Much easier now in in my chopped sedan.
    5window likes this.
  6. 19Eddy30
    19Eddy30
    from VA
    @wildwest
    32 5 w door is 28
    32 2 door is 35 ish & would be about
    3/4 Back into side gl***
    warhorseracing and hotrodjack33 like this.
  7. clem
    clem
    I think he wants to make an extended cab type coupe.
    Perhaps OP could try the photoshop guys first………
    Outback and SS327 like this.
  8. dirt car
    dirt car
    from nebraska
    I've heard it having been done on a 5w by narrowing or blanking out the quarter window & retaining the original wheelbase, stranger things have been done.
    Outback likes this.
  9. alchemy
    alchemy
    Why? Couldn’t be to improve the looks!
  10. wildwest
    wildwest
    It's just an interesting concept, that I figured would have been tried before? obviously it could look super weird and gangly, but I also think that if done well, it could look elegant like the same era of Lincoln. I have had 3 window coupes, 5 window coupes, and Tudor sedans and I like the Tudor sedan doors the best, but I like the trunk of a coupe. It would be interesting to see either way, a long door coupe with full fenders on an extended wheelbase (with big tall whitewalls..maybe even sidemounts !) and on a standard 106" wheelbase using sedan doors with the b pillar contoured to look more like the back of a 3 window door, and the 1/4 window eliminated. I might have to draw them out or do some cut and paste !
    Outback likes this.
  11. Jokester
    Jokester
    Narrowing it would make sorta like a Dodge or Plymouth coupe. I would like to see the Photoshop guys try it.
    . bjb
  12. The37Kid
    The37Kid
    How long is a 3Window door?
  13. Anderson
    Anderson
    I have a big plan for a build doing pretty much exactly this, with a LOT of tweaks. I much prefer the body lines of a 5w, and I hate suicide doors. I’ve done a photoshop of it and man….it’s got a ton of potential.
    BigJoeArt and porkshop like this.
  14. RICH B
    RICH B
    The "Green Grenade" Model A looked good with the sedan doors; but I can't even imagine messing up a deuce 5W. That's not something to mess with!
  15. A Boner
    A Boner
    Yep…it really worked on the Green Grenade! Making the whole body taller kept it in proportion. That was even before Elmer was Equipped!
    porkshop and Outback like this.
  16. Outback
    Outback
    from NE Vic, Oz
    Could try the photoshop thread & report back, those guys are fast
  17. The37Kid
    The37Kid
    I thought the cellphone people could photoshop this image in no time at all. Maybe they aren't here, that is a good thing.
  18. wildwest
    wildwest
    Don't think of it as messing up a 5 window,... think of it as saving a rough sedan using United Pacific parts !!
  19. clem
    clem
    Do we get to see the concept photos ?
  20. Anderson
    Anderson
    I used a well known concept artists renderings to piece it together...and I don't think he'd appreciate seeing his stuff ripped off.
    But I'll say that it seems obvious that you'd need to reshape the back/top of the door. The hard corner doesn't work. And then there's the fact that the sedan door is pretty flat along the top, and it really needs to start arching down to the back to match the 5w roofline. And I think it needs to lean forward at the back above the beltline, and have a rounded corner like a 32. So then while you're at it reworking the roof...might as well get rid of the driprail and flair it out like a 3w too. So full custom door top and extensive roof work is in the cards. And if you're going to chop it (because why wouldn't you?) then it can all be made to be very cohesive. Another issue is that the rocker on a sedan doesn't follow the frame quite as tight as a coupe. The back corner at the fender is farther away from the frame, which can be seen in the shadows of the attached pictures. This means that pretty much everything from the beltline down is on a different plane than the coupe quarter panel...and so that has gotta be sorted.
    I've bounced back and forth between starting with a tudor and grafting on a coupe roof and back half, or starting with a coupe and stretching the doors, maybe with the help of a pair of sedan doors...but making new skins would more than likely be a better route.
    03-Customized-1932-Ford-sedan-delivery-with-factory-made-sheetmetal-and-original-hood.jpg
    Sorry for the o/t wheels, best picture I could find as an example of the rocker difference.
    Outback, porkshop and MMM1693 like this.
  21. dirt car
    dirt car
    from nebraska
    Easy enough to modify a pair of straight on side view coupe & sedan photo's using the cut/paste & overlay method for the curious minds. That quarter window will be a bit tighter than say the Mopar coupes mentioned, however access/egress would be a big advantage with the wider doors.
    Outback likes this.
  22. Anderson
    Anderson
    really dirty quick "cut and paste"
    wheeldog57 and hotrodjack33 like this.
  23. alchemy
    alchemy
    All you guys who enjoy rescuing old tin and welding it back into a body should keep tabs on anyone who says they will attempt this project. As Anderson pointed out, it will quickly snowball into a project from hell, with no reward. A pile of hacked up sheetmetal will be for sale in a few years. Maybe you can turn it back into a five-window.
  24. dirt car
    dirt car
    from nebraska
    By the time the quarter window front radius is manipulated barely a sliver of a quarter window will remain without repositioning the back half of the roof, then it becomes interesting, ala Lincoln vibe.
  25. treb11
    treb11
    And after all that, it looks like a Plymouth coupe with its skinny quarter windows.
    Outback, tubman and The37Kid like this.
  26. Don't get me wrong, I'm not advocating for the project/plan...but I wonder about moving the rear of the roof back to preserve the 1/4 windows?
    clem and SS327 like this.
  27. dirt car
    dirt car
    from nebraska
    The 1931-32 Chevrolet offered what was called a 5-p***enger coupe, a tad bit coupe & more so a Vicky look with an abbreviated trunk, the Landau Phaeton likewise offered a folding top, truly unique body types competing with the Ford Victoria & 'B' 400.
  28. Anderson
    Anderson
    So a Vicky then?
  29. dirt car
    dirt car
    from nebraska
    Let's say a Close Coupled Victoria with a trunk
  30. No, 5 window sized windows.
