Technical Did I get Lucky? Can I get 1932 Ford registration papers in California?
Discussion in 'Traditional Hot Rods' started by The37Kid, Dec 13, 2024.
  1. MCjim
    MCjim
    from soCal
    For those not familiar with Google translate:
    But it is a one, on my 31 4 Banger it is also stamped as the engine number.
    Ford changed the numbers 1-6-9 from February 1931, that's what it says on Fordgarage.com.
    Greetings Harald
    I also speak a *******ized version of German...
    RodStRace and Budget36 like this.
  2. Beanscoot
    Beanscoot
    Is this the image which we're trying to decide is a 1 or an I?
  3. alchemy
    alchemy
    That is a 1 in Ford serialese. Do some research if you don’t believe me.
    lurker mick likes this.
  4. clem
    clem
    you may be right……
    Initially I thought it was a M, but couldn’t find an M in the van pelts info.
    Couldn’t decipher all the other numbers.
    But I still don’t think that he has a ‘32 serial number on his 1947 block !
  5. Jeff34
    Jeff34
    It’s a 1. I have one in my vin number as well. DMV kept insisting that it was an I. Idiots
  6. Jeff34
    Jeff34
    Some old typewriters didn’t have a number 1 on the keyboard. You had to use a capital I
  7. Beanscoot
    Beanscoot
    ...or a lower case l (ell).
    RodStRace likes this.
  8. 65standard
    65standard
    2B6A7A26-C508-4530-A61D-D814D3C3937C.jpeg Someone stamped the ‘32 serial number on the 1947 block. Was it a replacement motor from the dealer or Ford and they stamped the number on the block? I don’t know.
  9. clem
    clem
    Thanks for the clearer photo.
    From the link that I posted
    “ 1947 Ford V8 - 100hp - Mercury V8 - 100hp “
    numbers are…….
    “ 799A-1,412,708 to 799A-2,071,117 “
    I believe that yours falls in between those numbers.
    …….if you look further down the same link, (which I didn’t do a few days ago until @alchemy pointed it out)
    - it shows the new and old versions of the number 1 or I
  10. alchemy
    alchemy
    Ah, he was thinking the first 18 was referring to the 1932 model number, but now we see it’s just a regular 1947 block and serial number.
    clem likes this.
  11. 65standard
    65standard
    Yes. I was think the 18 was the start of the serial number. Thanks for helping me make sense of it.
  12. LOU WELLS
    LOU WELLS
    from IDAHO
    PONTNAK123, NJ Don, clem and 3 others like this.
  13. The37Kid
    The37Kid
    Thank you! That was the point of my asking. That "32" number makes the case valuable.
    Bob
  14. Deuce Lover
    Deuce Lover
    The fact that trans number is stamped alone will not work in France,no way. Ch***is needs to be stamped and paperwork has to match. The last domestic 32 V8 trans number to roll off the production line after the number"eighteen" is 212,238.Yours appears to be 2575...?
  15. lamaison
    lamaison
    from Canada
    Those numbers appear to be raised, not stamped (?)
  16. clem
    clem
    Look stamped to me.
    X-cpe likes this.
  17. Budget36
    Budget36
    Thing is, if it’s a ‘32, then put it for sale and you’ll soon find out if it’s valuable to someone or not.
    I ***ume you don’t have a use for it? So list it up, send it down the road.
