Projects Rear/Mid Engine 1927 T Roadster
Discussion in 'The Hokey Ass Message Board' started by Noah*, Oct 4, 2024.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    Thank you for including this !
    neilswheels and Okie Pete like this.
  2. gimpyshotrods
    gimpyshotrods
    You're funny! :)
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Look in the mirror ...
  4. Zuffen
    Zuffen
    from Sydney
    I have a rear mounted (technically a mid/rear engine, by our Laws) and I have the engine facing the rear with an auto trans behind it (toward the driver) coupled to a 4x4 transfer case that I use the front output shaft to drive the tail shaft down the side of the engine to the offset diff. The diff centre is flipped to give 6 forward speeds. The harmonic balancer is almost above the diff housing. This allows the trans and transfer to take up less room at the front and effectively shortens the whole driveline, whilst still allowing a 5 bar rear end with coil springs.
    None of it is HAMB friendly so no photos.
    Ned Ludd, unforgiven, AndersF and 2 others like this.
  5. nrgwizard
    nrgwizard
    from Minn. uSA
    Like a Lamborghini... Funny how some can learn from other "disciplines...
    Marcus...
    Just Gary, X-cpe and 2OLD2FAST like this.
  6. justabeater37
    justabeater37
    Looking forward to progress on this car. If we could get the people who like to argue on someone's build thread to be quiet and let the builder show his stuff, that would be great. Build on fine sir.
    AmishMike, Stogy, swade41 and 4 others like this.
  7. nrgwizard
    nrgwizard
    from Minn. uSA
    As far as the problem having the mill occupy the same space as the drivers' kidneys; 55Willys had some good ideas awhile back; https://www.jalopyjournal.com/forum/ . & it'd allow the driver/p***enger to be in a bit more "normal" position. Is not the shaft spacing smaller on the A-V8 QC? Or, I suppose a homemade QC would be appropriate, then you could match the shaft- centerlines to what you wanted/needed. ??? IDK, but was thinking if time-limited parts are required, *if* spacing works, a T86OD or maybe a T85OD might be useful, as they are rather short boxes. I can see where the strength of a T86 might be in question, but T85 should be near overkill(hope I got those designations correct here). Could go w/irs in a swingaxle format - wouldn't be the 1st lakes/bonnie racer to do so, nor even the 1st streetster from the past, either. Might protrude from the trunk panel, idk?
    Marcus...
  8. 1971BB427
    1971BB427
    from Oregon
    And you're a pain in the ***, who doesn't stick to his promise to drop it.
    gimpyshotrods likes this.
  9. 1biggun
    1biggun
  10. Marty Strode
    Marty Strode
    bchctybob, Blues4U, alanp561 and 21 others like this.
  11. hrm2k
    hrm2k
    I’ve seen this picture before on a V8 Corvair site. Big block, short case power glide, Quick change chunk
    rod1, Stogy, porkshop and 1 other person like this.
  12. 1biggun
    1biggun
    I want it for the local 300" no prep street drags . ;)
    Stogy, porkshop and Outback like this.
  13. Mr48chev
    I'm thinking that the Kentz & Leslie truck runs a side shift trans behind the flathead connected to a banjo center section with what may be more swing arm than independent rear suspension. Still the engine, trans and rear are pretty well short coupled. Still that would work with a quick change in the setup you are thinking of. If it is a tube frame the torsion bars could be run inside the rear frame rails to clean things up a lot. That engineering has already been done for front torsion bar hot rod suspension.
    From what I can see it uses torsion bar on the frame rails for rear suspension. I didn't get any photos from the rear to show what it had for a rear end though.
    Deutscher, porkshop, rod1 and 4 others like this.
  14. Elmo Rodge
    Elmo Rodge
    In my Tank I'm running a C-4 with a shortened tailshaft and a Greek coupler into a Cyclone quickchange. It measures 34 1/2" from the back of an 8BA to the centerline of the rear axle. This would require swing axle or something. Just offering up an option.
    Wayno
    Stogy and SilverJimmy like this.
  15. Robdski
    Robdski
    Are there any more details or concept drawings you can share, about the direction you are headed with this?
    I'm curious to see what you have planned for the front end body panels.
    In a previous post, you mention the concept of using the engine block as a structural component, can you give more detail on your plan?
  16. James D
    James D
    I love the idea of this and judging by your previous build, it'll be killer.
    rod1 and Stogy like this.
  17. swade41
    swade41
    from Buffalo,NY
    Not sure if Dave Lohr (Littleman) had a build thread on here or not on his
    Screenshot_20241221_193603_Facebook.jpg Screenshot_20241221_193516_Facebook.jpg Screenshot_20241221_193653_Facebook.jpg Screenshot_20241221_193554_Facebook.jpg
    Just Gary, hrm2k, bchctybob and 8 others like this.
  18. Marty Strode
    Marty Strode
    I built this "Engine Behind The Driver" Modified Roadster with a swing arm. It is now a Lakester. IMG_0420.JPG IMG_3882.JPG IMG_3885.JPG
    bchctybob, Blues4U, alanp561 and 17 others like this.
  19. PotvinV8
    PotvinV8
    Stogy likes this.
  20. mohr hp
    mohr hp
    from Georgia
    Stogy and Outback like this.
  21. Blue One
    Blue One
    from Alberta
    Why? In an all out BS slinging compe***ion you’d end up so deep in your own spouting that you’d barely be able to breathe.
    No compe***ion from here :D
  22. DDDenny
    NOW CL***!!!
    CoolForSchool58 likes this.
  23. 1biggun
    1biggun
    So IF that SBC had a electric water pump the area above the dampener could be about 4" or so shorter run the alternator off the drive shaft/ coupler . that lets the seat back move back a little.
    as taboo as is it is here a V6 would give another 4" .
    Or my idea years back was a V four made from a v8 that would gain about 8" or more on a SBC .
    V4 midget engines made about 300 HP . so 200 on gas would be doable . Mini blower maybe more .
    move the wheels back say 3" also
    V-4 Cylinder Chevrolet Wilson - Museum of American Speed .0000000000000000000000000000000000000000000000dscn0750_orig.jpg
  24. Outback
    Outback
    from NE Vic, Oz
    @Noah* I love your creativity & am looking forward to seeing your vision come to life
  25. Magfiend
    Magfiend
    How about two-speed Halibrand coupled to the engine and IRS...
    69fury, rod1, Okie Pete and 1 other person like this.
  26. Outback
    Outback
    from NE Vic, Oz
    Maybe 15 yrs ago here there was pictures of an IRS using entirely early Ford Parts, wouldn't have a clue who built it, but it was a work of art.
    neilswheels likes this.
  27. chrisp
    chrisp
  28. 34Phil
    34Phil
    PG is only 27" and shortened ones are 9.5" less so probably way to go. Cotton's T had no transmission.
  29. nrgwizard
    nrgwizard
    from Minn. uSA
    "Cotton's T had no transmission."
    Since when, & which one?
    Yellow Ardun used a '40 ford box w/zepher(?) gears; iirc, mid-engined blown hemi used a shortened 'flite.
    Marcus...
  30. Outback
    Outback
    from NE Vic, Oz
